Question about York Barbell Home Use Fold-Up Treadmill
My york pacer 351m has error code 1,how do i test the electrics?
I have been told it may not just be a speed sensor fault , I need to know which parts to test for correct voltage.
  • robert kevan Jan 08, 2013
    I have tried york but they dont keep parts for this model because it is old,i thought it was the speed sensor, but it could be the main power board or the display console, i just need to know what voltages to check for and where,thanks
SOURCE: My York Pacer 3501 treadmill
This is a speed sensor error.Check speed sensor and cable.
Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself.
Troubleshooting -->HERE
Posted on Mar 11, 2011
maxtreadmill
  • 832 Answers
SOURCE: my york pacer 2750 will not change speed, speed
Unplug unit pull your motor shroud off then inspect the motor pulley assembly plug in your unit while you rotate your speed handle you should be able to see the mechanical adjusting working if not then that mechanism needs repairing
Posted on Apr 16, 2010
maxtreadmill
  • 832 Answers
SOURCE: need a running belt for a York Pacer 3100
Technical Support & Spare Parts OrderingCall: 01327 701824
Email: helpdesk@yorkfitness.co.uk
Opening Times: 9am-4pm Monday-Friday
Posted on Apr 24, 2010
maxtreadmill
  • 832 Answers
SOURCE: Treadmill belt
SOURCE: how i replace my york pacer 2750 safety key
I have misplaced my safety key for my York Pacer 2750 Treadmill and can no longer use it. Please help me find a replcement soon. The company York Fitness no longer do this model and don't have the parts either. Help....
Posted on Sep 24, 2010
Lower speed to 6 klms
I got the manual for another model York Pacer 3501.
See page 5 of the manual
York Pacer 3501 User Manual Page 7
Jun 02, 2016 | York Exercise & Fitness
I have kettler pacer treadmill it is not getting start,when I press start button the display shows system fault and also shows error dc6
Motor controller...these are typically motors that have speed controllers. When they fail, just test and replace. Call the manufacturer for parts.
Nov 25, 2014 | Kettler treadmill Pacer
I cannot adjust th speed on my york pacer 3100, it just goes very fast.
I'd suspect you need a new adjustment cable and/or the winder is broken. The latter happened to my York 2500 Pacer and I replaced the cable & handle with a bike gear change mechanism.
Mar 18, 2014 | York Exercise & Fitness
I got error 1 on my york fitnees66900
see the details and proceed
HOW TO MEASURE
ERR 1 - Motor Movementttfrfg
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Adjust the s.sensor and clean it+ tight the connector very well . test for open or faulty. see block diagram.
God bless you
Feb 04, 2013 | York Exercise & Fitness
Treadmill issue: Have a York fitness pacer 3700 that does not go and an error 1 comes on after 4 seconds, prior to this it starts up normally and the display is zeroed. Any ideas?
Adjust the speed sensor, clean, and tight the wire connector very well.
see the diagram attached.
2) Test the input voltage motor, if there are the motor need repair.
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
sincerely. God bless you
Apr 19, 2012 | York Exercise & Fitness
Cannot change speed up on york pacer 27650
1) Check it the speed sensor.
2) Watch if the connector is loose or bad contact.
3) Corroded contact( clean with special spray for contact)
4) Replace Speed Sensor.
May 24, 2011 | York Barbell Home Use Fold-Up Treadmill
I lost my manual for the York Pacer 3100, where can I download the manual? I also need to replace the running mat but I don't know the part number.
Try this 3 web page:
1) Free. http://fitness.manualsonline.com
2) Pay:www.fitnessrepairparts.com
3) Pay: http://manualsfactory.com
e.cuadra
My york pacer 2750 will not change speed, speed adjust knob work but motor will not increase speed.
Apr 16, 2010 | York Exercise & Fitness
My york treadmill pacer 3700 show error
I have just got a pacer 3700 off a friend and she had no manual for it. it keeps saying error 1 and wont do anything. what can i do to make it run again?
Oct 27, 2009 | York Exercise & Fitness
Speed problem
There is a rotating handle to the right of the display panel that you need to turn clockwise to slow down and anitclockwise to speed up, this is the only speed control. Turn it all the way and it will start at the slowest speed about 4kph. Good luck
Jan 24, 2009 | York Yankees Bedding MLB Comforter
York Barbell  Home Use Fold-Up Treadmill Logo
333 people viewed this question
Top York Exercise & Fitness Experts
Electro Med Services...
Tom Chichester
ray gallant
Are you a York Exercise and Fitnes Expert? Answer questions, earn points and help others
