Question about Air Tools & Compressors
Require head reed valves for rockworth pancake rw pcac 1.5 hp
Code 812 333 5GRA081 Bar Code 9314539026204 Model Pancake Rob Style J W Ross
SOURCE: install reed valves hitachi air compressor need pics
I believe in your model of air compressor, when you take apart the head portion to your compressor you should have four reed valves. When you have it apart, there should be two "grooves" on the bottom "plate" and two "grooves" on the top plate (where the reed valves go). the bottom part is easy (as you should already know) to set in the reed valves, but as i have also found out, as you probably have, that its a little more difficult to line up the other reed valves to thier "grooves" on the upper "plate". What you do to make sure that they stay in place is dab a little oil or grease on the reeds and place them in the upper "plate grooves" and carefully set the upper plate back in place where it goes on the compressor. It will hold them in place long enough to install it on the compressor and the small amount of grease that was there will quickly be burned up with no effect to the opperation to the machine.
Sorry, long winded explanation. hope this helps and if it didnt get to you soon enough i hope it helps out in the future. :-D
Posted on Jul 10, 2009
  • 98 Answers
SOURCE: I have a 4 gallon 2 hp. central pneumatic pancake
check and make sure that the valves do not leak
Posted on Jul 22, 2009
braintrust
  • 62 Answers
SOURCE: Got a Husky 6 gal pancake, 1.5hp. motor runs- no
the regulator may be turned down, find the regulator turn it to the right to allow air into the tank, tank must have air in it to deliver air
Posted on Oct 27, 2009
digritz
  • 530 Answers
SOURCE: I need motor brushes for model# H1506FWH Husky 1.5
First you have to understand something important about motor brushes. That is the only difference between all motor brushes is their size (brush diameter and contact wire length). This includes fan motor brushes, water pump motors, power tool motors even automobile alternator brushes.
You can also find brushes where you might not think to look.
If you can get even close to the same size as the old set you can file the new ones down to fit. I've done it time and time again.
Your best bet is automotive electronic stores. However you might find them at local auto parts stores, hardware stores like Home Depot (look in the section where they have all the small parts bins). You might also try Tractor Supply. I know they are in Alabama but not sure if there is one close to you.
Remember you can modify the length of the wire also. If the old set has a small contact point on the end of the wire just remove it and solder it to the new brush wire.
I hope this helps you out.
Posted on Nov 22, 2009
  • 1388 Answers
SOURCE: How do you replace the regulator valve on a husky
I could not find parts for my husky compressor and had the same problem as you describe. I went to lowes and purchased fittings to draw air out of the safety port. Remove the safety pop valve and install t-fittings to allow you to reinstall safety valve and also a quick connect. If you want to be able to regulate the pressure, install a simple pressure regulator before the quick connect (also avail. at lowes). This remedy is not pretty but sure works great and simple. Problem with husky regulator is stripped thread /knob. Sometimes you can turn the knob if you drain air from tank; this will release the spring tension on the regulator knob.
Posted on Jan 01, 2011
My bostitch 6 gal compressor keeps running , and running , even goes into a higherpitch motor noise. can i check something ? or clean something to fix it ?
is it building up any pressure on the gauge
if the pressure recorded is around 40 psi or less , replace the failed poppet/reed valves in the compressor head
if it goes to 100 psi then replace the automatic controller for the motor
Jun 15, 2016 | Stanley Bostitch CAP200P-OF 6 Gallon...
Broken reed valve , need valve ,head gasket
These parts are easy to make. For reed valve, use feeler gauge material or old feeler gauge. This material is easy to cut or grind to size. Gaskets are a bit tricky but material is very cheap and with a little practice, you can make good replacement. If the old gasket was paper, use automotive gasket material sold at all autoparts stores. It is easier to cut thin gasket material so buy thinner than needed and layer. If the gasket is metal, use shim stock or beer / soda can). Good luck with your repair.
Sep 21, 2011 | Clarke Power Products Inc AC2001 2HP 4...
I have a bostitch 6 gal pancake compressor that won't build pressure past about 20 lbs. when I turn it off I don't hear air leaking out anywhere and when it's running it runs at a higher pitch ( similar to...
I'd pull the cover off to expose top of cylinder head and have a look at any intake air filter. In parts diagram, It appears there is a small one that would likely clog during the texturing process.
Jan 26, 2011 | Stanley Bostitch CAP2060P 105 Amp...
My compressor won't build pressure over 90lbs
Small leak will prevent the unit from building proper pressure. Check all connections with soapy water and repair as needed (including under cover). If no leaks are found check cylinder for scratches. Push piston to top of stroke and check walls for fine scratches. If scratched, pressure is leaking past vinyl piston ring. If no scratches or leaks, most likely reed valves, head gasket or combination of both. Easy test, with compressor running and attained 90 lbs, place finger over air intake and check for good suction (carefull could be hot) . If good suction, then air is leaking somewhere, of no suction suspect reed valves/worn cylinder, if air seems to be blowing out of intake, suspect reeds /gaskets. Good holidays
Dec 13, 2010 | Stanley FactoryReconditioned Bostitch...
Trouble building pressure
I would check the reed valves in the pump. One of them may be broken.
Jul 09, 2010 | Porter Cable C2002 150 Psi 6 Gal...
Husky pancake runs in reverse
I am a little confused here ... I have a Craftsman pancake, a Craftsman 6 hp (same compressor design) and several other name brand pancake compressors at the job. The compressor doesn't care which way the motor runs though mine all run in the same direction. As long as the piston goes up and down, the reed valves know when to open and when to closed based on the pressure. It sucks in from the 'room' on the down stroke and blows into the tank on the upstroke.
Yours isn't doing this? If it is creating a vacuum in the tank, I would have to say someone put the valves in upside down.
This is very curious.
You could reverse the black and white wire but as I understand the physics of it, it will not matter where the hot wire is since it is AC. The motor may be reversable but I'm thinking it is probably not in this case. That costs extra to make into the motor.
Please inspect the valves to make sure they are capable of 'inhaling' (the site will delete the other word I used) on the down stroke and 'exhaling' into the tank on the upstroke.
Please let me know what you find out.
Thanks for your curious question at FixYa.com
Jan 15, 2010 | Air Tools & Compressors
Portable oiless compressor wont pressurize
If there is pressure at the pump, either:
1) The tank check valve isn't opening (it's located where the line from the head enters the tank - usually extends into the tank, and the the pressure switch unloader line comes off of it as well)
2) The pressure switch unloader is bleeding off the air. This is a small valve on the side of the pressure switch. It should close when the compressor is running and open when the compressor shuts off to bleed off head pressure.
Oct 19, 2009 | Campbell Hausfeld No.FP2028 Gal Pancake...
Porter cable pancake unit blows air after shut off.
those have a reed valve set up you need to pull the head off and you will see two strips of metal that are usually held down with two small screws each the one on intake side most likely you could get a rebuild kit cheap it will only have new reed valves maybe new screws for them a leather ring and a head gasket
Mar 14, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Air Tools & Compressors Logo
67 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
