Question about Toys
Sub woofer keeps cutting out on ferguson f5000 dab hifi
It cuts out after about 20mins of playing not even at a high volume
  • 14 Answers
SOURCE: Auto Sub woofer
There are several causes of distortion in an audio setup.
1) Speaker is unable to handle the frequency that it's being fed
2) The volume is too high for the speaker to handle
3) The amp can't provide enough power to drive the speaker adequately.
Either way distortion is BAD & best to be avoided unless you want an excuse to buy a new set of speakers :P
Posted on Dec 28, 2007
  • 521 Answers
SOURCE: cutting on and off
the short tracking in the connections occurs normally after a long period of use.get it repaired if you want.or i will suggest you to get new sub woofers as the old one is at the end of its life.
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Sep 03, 2008
  • 631 Answers
SOURCE: sub cuts out
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, the sub may be damaged. You'll need to measure the resistanace of the voice coil. It shouldn't read less than ~85% of the rated impedance.
Posted on Oct 26, 2008
SOURCE: sub woofer cuts on and off.
I was rid on my hum just as soon as I took my plug out of my powerstrip and plugged directy into an outlet. Must be something to do with incomplete grounding. It has been working just fine every since I plugged it into the wall.
Posted on Feb 19, 2009
  • 71 Answers
SOURCE: HTS 6500/37 sub woofer
the reciever should have a "subwoofer level" setting, or a "bass level control" If you cannot find this then try to place the "sub-woofer" away from walls and elevate it from the floor. This will reduce it's loudness/ intensity at annoying frequencies...
Good Luck
Posted on Jun 24, 2009
My wireless subwoofer keep cutting off and coming back on when the music or movie is playing
Some/most Sub Woofers have a Switch that turns them Off/On/ or Auto. On Auto, the Sub only turns on when there is a signal present. ( sound coming into the Sub ) When there is no signal, the sub goes into standby mode. Wireless subs may be made to be in standby mode as the default.
Dec 21, 2014 | Audio Players & Recorders
No sub woofer output or very little
Your sub amplifier is detecting an overdrive condition and reducing volume to prevent the output stage from burning up. When reduced volume doesn't work, output is cut completely for 10 minutes until things have cooled down.
Mar 27, 2017 | JVC KD-R740BT
My radio cuts out when i turn it up and the bass hits on my subwoofer
You are drawing to much power to the amp. I assume that there is no dedicated power fron the battery to the amp. If there is you should look into a capacitor
Feb 13, 2013 | Car Audio & Video
My subwoofer doesn't receive power, all amp fuses are fine, amp powers on, remote wire and rca wires are connected and intact. Before it stopped working all together the woofer would cut out and after...
If you are getting power to the amp, try this....Find a small speaker, unhook your sub and wire speaker to amp. Turn on your system at a low volume....If the other speaker is playing through amp, then your sub is shot.....If the small speaker doesnt work, then its either your channel is gone on the amp or the rcas have quit off off your head unit.
Oct 07, 2010 | Kenwood eXcelon X1200M Car Amp
My Yamaha SW118 keeps cutting out (volume reduces to v low level) even when driven by 500W amp. Doesn't seem to be the amp but not sure if the speaker has it's own internal protection. Can anyone advise?
Poly Switch
All full-range loudspeakers are fitted with a self-resetting
poly switch that protects the high-frequency driver from
damage caused by excessive power.
If a loudspeaker cabinet loses high-frequency output, immediately
remove power from the unit and wait for two to three
minutes. They should allow the poly switch to reset. Reapply
power and check the performance of the high-frequency
driver before continuing with the power reduced to a
level that does not cause the poly switch to interrupt the signal.
On the SW115V/SW118V/SW218V sub woofer, the Poly
Switch protects the woofer and a similar routine should be
followed if its output is lost.
Aug 29, 2010 | Yamaha SW118-IV 18" Subwoofer Speaker
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
I have a d5000 amp and its wired up to a 15.2 hcca orion sub when i turn it up high volume,it cuts out anyone know why
make sure you have the frequency cuts right. if ur giving the sub anything lower then 30hz (assuming ur using 15's) the amp will cut out to protect the woofers from overload
Nov 18, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Amp cuts out
could be an internal problem such as a relay or resistor or something of the sort
Sep 02, 2009 | Car Audio & Video
My car's sub is ''sub-par'' my expectations
Hello css42103,
You did not specify the impedance or the model of your Audiopipe replacement woofer but if it is the TS-V6 DVC 6.5", then the impedance of each voice coil is 4ohms. If you wired the coils in parallel, you now have a 2ohm load to the amp. At 2 ohms, the amp tries to produce more power, and even at moderate volume, can be driven into clipping causing distortion. Not good for the amp. Definitely not good for the woofer.
I'd try wiring the woofer coils in series and see if it stops cutting out.
Hope this helps.
Jun 01, 2009 | Car Audio & Video
2000 lexus es300
This is normal. I also have a 2000 ES300. This became a problem when i tried to run an aftermarket sub off of the wire leads from the stock sub-woofer. When I would switch the radio off there would be a loud, deep, constant bass tone. As far as I know you cannot stop the voltage from continuously supplying the sub-woofer this is the way the factory amplifier is programmed, however, if you cut one of the wires(youhave to cut because wires are soldered to sub-woofer) the humming noise will not occur when radio is shut off. Cut the wire in middle and add crimp connectors so you can reconnect later if needed. You only need to cut one and it doesn't matter whether it's the black or red wire.
Oct 02, 2008 | 2000 Lexus ES 300
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
