Question about Toys
My sub keeps cutting out on my ferguson f5000 dab hifi, what can be causing this? Many thanks
Sub woofer keeps cutting out
SOURCE: SUB WOOFER WIREING
What is the model of subwoofer and what kind of amplifier are you using? Not very many amps can handle a 1 ohm load. Also, how many subs are you planning on using
Posted on Nov 20, 2007
jerryg50
  • 1667 Answers
SOURCE: Sub Woofer
Most likely there is a cold solder connection on one of the circuit boards, or a connector, or any anything else in the audio path.
It is suggested to not use the unit until it is properly serviced. Depending on what is being effected internaly from the cold solder connection it is possible to have some damage.
Jerry G.
Posted on Jul 05, 2008
SOURCE: sub woofer keeps blowing fuses
NO dont try a 3 amp fuse.It is made to BLOW if there is a problem. That sub is not worth fixing, JUNK it. There are a lot of problems with it. Such as heating up and melting the board witch could cause fires. Thats what happened to mine. Like I said JUNK it and buy a different one.
Posted on Dec 13, 2008
SOURCE: Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Posted on Apr 19, 2009
  • 46 Answers
SOURCE: How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Posted on Mar 07, 2010
My wireless subwoofer keep cutting off and coming back on when the music or movie is playing
Some/most Sub Woofers have a Switch that turns them Off/On/ or Auto. On Auto, the Sub only turns on when there is a signal present. ( sound coming into the Sub ) When there is no signal, the sub goes into standby mode. Wireless subs may be made to be in standby mode as the default.
Dec 21, 2014 | Audio Players & Recorders
Sunfire true subwoofer signature one 7.5A internal fuse keeps burning out. what are possible causes and how to repair?
If you have an ohm meter (resistance) test for 7-8 ohms across each set of speaker leads to your sub woofer. Its likely you have blown speaker (load is causing amplifier to draw to much current) or just a bad amplifier in the sub (likely not worth $ repairing vs new). To test the sub woofer speaker itself you may have to take it apart to test its resistance.
May 26, 2014 | Durabrand STS98RW Theater System
I have 3 10" clarion
If your sub woofers are DVC 4OHM: Connecting three together in Parallel/Parallel would make your amplifier run a 0.67OHM load or if connected Series/Parallel then you would have a 2.67OHM load. If your sub woofers are DVC 2OHM: Connecting three together in Parallel/Parallel would make your amplifier run a 0.36OHM load or if connected Seies/Parallel then you would have a 1.67OHM load and Series/Series a 12OHM load. So if your sub woofers are really DVC, it would be impossible that your amp would be playing 4OHM. The numbers just don't add up. There are amplifiers out there that can deal with 0.50OHM loads but expect them to be on the pricey side, but fairly so, because mostly higher end brands tend to manufacture them and are usually pretty good. Remove 1 of the sub woofers. If i knew what the subs where 4 or 2 OHM DVC and what amplifier you are using i would tell you how to connect them for the best possible result. hope this helps dreamsystems
Feb 07, 2011 | Car Audio & Video
Connect stereo amplifier to powered sub
You can y out from the main out to the sub.This output is post volume control. set level on sub to desired balance of lows feq to highs
Nov 20, 2009 | Yamaha YST-SW015 Subwoofer
Bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Sep 20, 2009 | JVC RX-554V Receiver
Sub-woofer shutting off
woofer circuit problem! it could have been overdriven causing overload to the component on the circuit. check woofer circuit for damage components, most likely power ICs and capacitors bulging
May 20, 2009 | Audio Players & Recorders
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
2000 lexus es300
This is normal. I also have a 2000 ES300. This became a problem when i tried to run an aftermarket sub off of the wire leads from the stock sub-woofer. When I would switch the radio off there would be a loud, deep, constant bass tone. As far as I know you cannot stop the voltage from continuously supplying the sub-woofer this is the way the factory amplifier is programmed, however, if you cut one of the wires(youhave to cut because wires are soldered to sub-woofer) the humming noise will not occur when radio is shut off. Cut the wire in middle and add crimp connectors so you can reconnect later if needed. You only need to cut one and it doesn't matter whether it's the black or red wire.
Oct 02, 2008 | 2000 Lexus ES 300
Panasonic Sub Woofer
I Have the sub woofer SB wa 340, but I need the remote control if posible bussines send me the information 7862873227
Jun 23, 2008 | Panasonic SC-HT690 System
Toys Logo
15 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
