Question about Toys
Elevator won't go up and down, I have solved this now but don't know how 2 put the elements together 2 make it work
    New Friend:
  • 10 Answers
It looks like you are missing a piece that connects the elevator base to the track that it slides on.
Posted on Jan 05, 2013
Stopped Working All Together
Hi, bring to your nearest service center to repair it.
May 18, 2013 | FUJIFILM Instax 210 Film Camera
Imaginext batcave elevator string came out
I had the same issue, my son used his all of half a day and the elevator stopped working. If you take the top of the cave off, and unscrew it from the elevator shaft you will see a black wheel. The string needs to be wrapped around this twice, there should be very little play in the string. What I had to do was take out the 3 screws that held it to the knob on top, then wrap the string back around the wheel making sure not to tangle the string more. once the string is wrapped 2 times you can reassemble.
Dec 18, 2011 | Toys
I have a 1991 40 gl and it fell through the floor which is like 2 ft off the ground. turned the water off and replaced the pipes it has its own lever type power supply with the screw in fuses 30 amp (2) of...
You have 2 problems with several possible causes:
You have 10-year-old electric water heater that was reinstalled after falling down, and doesn't heat the water.
And you have no hot or cold water pressure, and no pipes are leaking.
1) First problem is lack of water pressure throughout house.
Turn on outdoor spigot nearest to water meter.
This spigot will tell you if problem is inside the house or between the house and meter.
If spigot runs full force, then you probably have clogged pipe where water heater connects to main cold line, or the main shut off valve got clogged with sediment that broke off inside the pipe when you were working on water heater.
Open and close shut off valve to see if that helps. Then disassemble pipes and track back the problem. Put pressure gauge on water heater drain valve to watch pressure drop when turning on indoor faucet.
Read following information:
http://waterheatertimer.org/Low-hot-water-pressure.html
Water heater doesn't work:
Test across wires at top of heater to see if you are getting correct voltage:
If tank is receiving correct voltage, then no hot water puts suspicion on upper element or upper thermostat, or both.
Open following link for electric water heater troubleshoot steps:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Jul 30, 2011 | RELIANCE ELECTRIC WATER HEATER
C1183 error the trays desent and rise normaly put the stapeling unit coms at the front? this must be in center? thanks if anyone can help bart
Hi
Error code C1183 means finishing option elevator drive malfunction. It appears due to tray lift motor failure on the finisher. To trouble shoot the issue turn off the power and open the elevator section to check the elevator motor. Wait for 2-3 minutes and check if the issue is resolved. If this doesn't work then check the alignment of front and rear rollers of the finisher. Also make sure that the finisher exit guide rollers are fine & the paper is exiting properly, open both rear and the front cover and check the lower gears attach is the up/down drive belt. Sometimes this error may appear due to a broken lower gear by the pin slot. Hope this helps...
Daniel
Oct 09, 2010 | Konica Minolta Office Equipment & Supplies
I want to know how to solve this,,,could you please help me?
j=(72/60) floors upward per second
m=(48/60) floors downward per second
j=m at 20 seconds. At 20 seconds they'll both be at floor 42
Jek will go up 24 floors in 1/3minute and maitress will travel down 16 floors in 1/3minute.
Jan 30, 2010 | Microsoft Troubleshooting Your Web Page...
Delonghi Magnifica "insert brewing unit"
I just figured this out on my machine, I should have taken pictures but i didnt :( this problem seams to pop up whent the elevator that moves the brewing unit up and down gets its starting position mis aligned, since the machine does not have sensors to re adjust the alignment the motor will pull the elevater down even if it cant go further and that seams to cause the nasty noise we were hearing.
1. unplug machine
2. remove the side and back covers
3. remove tray and brewing unit from inside (2 red buttens you press together)
4. remove the bracket that holds the brewing unit (2 hex screws)
5. below the brewing unit bracket is one more screw, it holds the motor unit and elevator on the back of machine, remove this screw.
6. on the back pull out the motor unit with elevator.
7. realign elevator starting position by turning the bottom wheel that is connected to motor via belt, it might feel a bit stuck first as motor has ower tightened the elevator.
The back of the elevator looks like a step ladder with screw going up the middle, for me it worked best to align the bottom of the traveling bracket with the bottom step on the ladder i recomend trying that position and then adjusting if nessesary.
8. reasemble the machine and continue to enjoy exelent coffie
Aug 08, 2009 | DeLonghi EAM3500 Espresso Machine/Coffee...
Toys Logo
218 people viewed this question
Top Toys Experts
Adam Fjeld
Adam Fjeld
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
