Lg golden eye ctv stand by problem,by progessing only clicking sound found unable to switch on
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
There is shorted component/s in the horizontal output section circuit. Horizontal output transistor is most probably shorted. Replace it and check. If you are not able to do this, contact any experienced service technician.
Posted on Jan 05, 2013
4 Suggested Answers
  • 56 Answers
SOURCE: how to align picture on lg tv golden eye model
press OK on rc and local key serv mode will appear
Posted on Jul 19, 2009
  • 8457 Answers
SOURCE: Golden Eye LG Color Television Receiver:10 years
Cold solders,easy fix,taps around for it,just resolders the PCB.Should be cheap,just time,to look for it.
Posted on Nov 17, 2009
bhatgiri73
  • 106 Answers
SOURCE: I have an LG Golden Eye CRT TV, is this compatible
well this tv dont have component inputs. u can connect hd set top box via a/v well picture will come but no hd experiance.....u have to buy a hd tv
Posted on Mar 24, 2010
LG GOLDEN EYE MODEL-CF21S12E, it is running normal, after 2 to 3hours no picture but sound ok. after sw/off few hours it will work normal. every thing check found nomal,pls give suggestion
Check the soldering on the picture tube neck PCB. If possible resolder all the point in the pcb. There is some problem wit the filament voltage. It can be because of drysoldreing.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 11, 2016 | LG Televison & Video
I have lg 1200 flatron golden eye tv. Picture is getting blurred and cloudy appearnce. Pls let me know solution
The resolution is dependent on the settings. Did you check and adjust the pot controls? Check the connections from the source to see if any loose wires are in need of tightening? In some case HEAT causes the controls to go out of sync and give you a poor picture. Other than that, contact LG support services for their opinion.
Jan 03, 2014 | LG Televison & Video
Lg golden eye 21inch ctv stand by led glows but switchin progress key only clicking sound found,set unable to on
Shorted component/s in the main circuit board's horizontal output section. Check and replace the damaged components there.
Jan 05, 2013 | LG Televison & Video
My Golden Eye LG TV Model No: CT29K35VE has perfect picture but no sound. It fell off the stand and the cover near the speaker is broken. I opened the back but saw no loose wires. A friend has a meter...
Have the speaker and wires tested, follow the wires back and see if where they plug into the circuit board the plug came out or the board itself got cracked, a visual inspection should be able to find a crack etc.
Dec 14, 2012 | LG Televison & Video
What is the function of golden eye?
There is an LDR [Light Dependent Resistor] fitted insie the circuit board. It will sense the light condition of the surronding, and will adjust the bright ness level automatically according to surround light condition. Taht is, if light level to surroundings is high, the brightness of the tV will also go high to compensate it and vice versa.
Actually there is no need for this,as if you switch ON the Golden eye function, you can see the quality of picture will go out. Manual settings to picure will be always best.
May 24, 2012 | LG Televison & Video
In my Lg Golden Eye 21" television remote control
Which type of remote control can I use for golden eye TV
Aug 12, 2011 | LG Televison & Video
Dear Sir, LG Golden Eye Marquis Model No: RF-29CA40PQ., i forgot the 4 digit Tuning Lock Code. Due to this i am not able to Tune my TV. Can any one help me out, is there any master Tuning Lock 4 digit...
In my LG golden eye marquis 32 inch TV, I have switch on the childhood protection mode to prevent the TV from children's by pressing the buttons on my TV.... Now The remote gets broken which was given along with the TV.. Now I bought a remote for tat model that name is LRIPL... I can't able to access the menu button and most of the buttons cannot able to process... I need to access all the buttons... Please help me..
Feb 24, 2011 | Televison & Video
Lg 29 inch flat tv golden eye is power off he dont start
Possible failure of the SMPS power supply. Please check the fuse and switch after disconnecting and checking the circuit.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Feb 21, 2011 | Televison & Video
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Aug 04, 2010 | LG Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
