Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Brake light on 1998 Sportster keeps blowing
I have a 1998 883xl Sportster. The brake light keeps blowing out. I have recieved a tail light ticket and i have replaced it too many times in the last 3 months. The light only fires up when i press the brakes but will not stay on. This is a problem for riding at night.
    Problem Solver:
  • 8 Answers
Check for an open circuit. do a voltage drop test, u have a short
Posted on Jan 26, 2009
Brake light fuses keep blowing
On some models the light switch it defective increasing the volts in the tail and brake circuit.
Dec 02, 2013 | Mitsubishi Galant Cars & Trucks
Brake tail light stays on 1998 dodge neon
is there a broken spring on the brake pedal assembly?
Nov 25, 2017 | 1998 Dodge Neon
I need to drive to work at night and already recieved a ticket for my tail lights being out however the brake lights are out, i bought a manual and it said nothing of where the fuse was sp i checked every...
take the cover off the tail light lens and look at the bulb if there are broken filaments or burned spots there bad you can also check to see if your getting power to the plugs for the bulbs with a 12volt test light or meter.
Feb 24, 2011 | 1998 Saturn SL
Harley sportster 883 2005. Both the tail light and break light filiment stay on with no difference when brake is applied.
Not sure I understand your question.The tail light filiment goes on with lights and brake light filiment goes on when brake is applied.The extra filiment makes the tail light go brighter.If both filiments are on when lights go on then applying the brake won't change the intensity.You might have bad brake light switch causeing brake light to stay on.Have to do some checking to see if it's front or rear switch.
Mar 07, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
How do you replace the brake lever on a Harley
There is a snap ring on the bottom of the post that holds the lever in. Use snap ring pliers to remove the snap ring, remove post disconnect the lever from the cable.
Jul 28, 2009 | Harley Davidson XL Sportster 883...
Tail/Brake Light constantly burning out
sound like a wire is broken and touching the frame of the car
May 20, 2009 | 2005 Kia Optima
Tail light
The tail light which stays 'on' , is it the brake light or the normal light. (if it is powerfulthn its brake light & if it's dimmer thn its a normal light).
Remedy:- if it's brighter thn it is probabley the brake light switch which mayhave siezed or needs adjustment.
I have a feeling it is the brake light tht is staying lit all the time.
May 14, 2009 | 2002 Harley Davidson XL Sportster 883
How to adjust rear brake/2005 harley 883xl sportster
There is a pedal height adjustment on the right side of the bike. If your brakes are dragging or not applying properly, you have a caliper problem, blocked line, bad master cylinder or mis-adjusted master cylinder plunger.It does have the correct DOT 5 fluid at the recommended level, right?
Apr 27, 2009 | 2005 Harley Davidson XL 883L Sportster
82 harley sportster brake light
try starting with the bulb. brake light bulbs are dual fillament, meaning you have 2 bulbs in one basicly. if your brake side has blown then the tail light could still work. Or try checking the brake light switches, one on front brake and one on rear brake pedal. to test switches disconect wires and join them together with small bit of wire or paper clip. this will make the light come on meaning you have a bum switch.
if you have only been using the rear brake, that has an adjustable switch, may need to mess with it
Mar 29, 2009 | Harley Davidson XL 1200 C Sportster Custom...
Brake lights/ Turning signals not working on a 2004 cavalier
change brake light switch . check brake switch wiring . for shorting then check tail light bulbs sockets. if you cant find it. you probably going have to buy a short finder.
Mar 25, 2009 | 2001 Chevrolet Cavalier
Lands Phones Logo
172 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
