Question about LG Televison & Video
Lg golden eye 21inch ctv stand by led glows but switchin progress key only clicking sound found,set unable to on
    Top Expert:
  • LG Master
  • 74,383 Answers
Shorted component/s in the main circuit board's horizontal output section. Check and replace the damaged components there.
Posted on Jan 05, 2013
  • 56 Answers
SOURCE: how to align picture on lg tv golden eye model
press OK on rc and local key serv mode will appear
Posted on Jul 19, 2009
  • 8457 Answers
SOURCE: Golden Eye LG Color Television Receiver:10 years
Cold solders,easy fix,taps around for it,just resolders the PCB.Should be cheap,just time,to look for it.
Posted on Nov 17, 2009
bhatgiri73
  • 106 Answers
SOURCE: I have an LG Golden Eye CRT TV, is this compatible
well this tv dont have component inputs. u can connect hd set top box via a/v well picture will come but no hd experiance.....u have to buy a hd tv
Posted on Mar 24, 2010
SOURCE: i have a 21inch TV (LG golden eye) which is 10
I have a 21inch TV (LG golden eye) which is 10 years old and recently i am facing a problem that
1) Some times the colors in my lg tv got changed. Only a small portion in the top right side of the screen has the true colors. The color change is something like the one that happens when a magnet is taken near the screen. But nothing like that was near my tv.
2) usevally after power off to the tv for about one hour, if i switched on the tv, the standby LED of the tv blinks about 5 to10 minutes and the same time tv will not on & the remote also does not function.after blinking of LED is stoped ,now i can ON the tv by remote (or) by tv buttons. tv will be working fine . again if i switched OFF the tv for about one hour, same problem will be repeated.
resulting i have to wait about 10 minutes to switch on my TV which result incinvenient to me.
3) part of picture about 5% of image missing on the screen on left and right side of the TV.
could you please tell the reasons and suggest the solution for rectification of the above problemstell the reason?
Posted on Mar 21, 2011
porwal_arvin
SOURCE: I am having Samsung CTV set DNleJr 21
no sound
Posted on Aug 03, 2012
LG GOLDEN EYE MODEL-CF21S12E, it is running normal, after 2 to 3hours no picture but sound ok. after sw/off few hours it will work normal. every thing check found nomal,pls give suggestion
Check the soldering on the picture tube neck PCB. If possible resolder all the point in the pcb. There is some problem wit the filament voltage. It can be because of drysoldreing.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 11, 2016 | LG Televison & Video
I have lg 1200 flatron golden eye tv. Picture is getting blurred and cloudy appearnce. Pls let me know solution
The resolution is dependent on the settings. Did you check and adjust the pot controls? Check the connections from the source to see if any loose wires are in need of tightening? In some case HEAT causes the controls to go out of sync and give you a poor picture. Other than that, contact LG support services for their opinion.
Jan 03, 2014 | LG Televison & Video
Lg golden eye ctv stand by problem,by progessing only clicking sound found unable to switch on
There is shorted component/s in the horizontal output section circuit. Horizontal output transistor is most probably shorted. Replace it and check. If you are not able to do this, contact any experienced service technician.
Jan 05, 2013 | Televison & Video
My Golden Eye LG TV Model No: CT29K35VE has perfect picture but no sound. It fell off the stand and the cover near the speaker is broken. I opened the back but saw no loose wires. A friend has a meter...
Have the speaker and wires tested, follow the wires back and see if where they plug into the circuit board the plug came out or the board itself got cracked, a visual inspection should be able to find a crack etc.
Dec 14, 2012 | LG Televison & Video
Sansui hord rock 21inch eye ctv remot not working
The infrared sensor inside theTV might be faulty. Replace it. This component can be located just behind the infrared window at the front panel of the TV. You have to disassembe the TV to access it.
The component will look someshat like these.
May 08, 2012 | Televison & Video
In my Lg Golden Eye 21" television remote control
Which type of remote control can I use for golden eye TV
Aug 12, 2011 | LG Televison & Video
I have an lg golden eye tv.....can see the picture perfectly except for 3-4 inches of black runnin down both sides that curves in...how can i fix it
Try changing the tv picture settings to 16:9 ratio or widescreen/letterbox setting!! Menu > picture> newer lg's also have a quick menu button on the remote. Hope u sort it.
Feb 23, 2011 | LG Televison & Video
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Aug 04, 2010 | LG Televison & Video
Dead set!
First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Jul 30, 2008 | Televison & Video
Televison & Video Logo
144 people viewed this question
Computer Repairing
Computer Repairing
