Question about Toshiba Satellite L305D-S5974 Laptop
Speed up my windows 7
It has became very slow I under stand I cant clean my registry or chash? how
Search for ADVANCED SYSTEM CARE FREE
Posted on Jan 05, 2013
My pc is very low.I need fix
Slow PC does not mean it has problem only with motherboard. Speed of the PC also depend on the following factors :
  1. Processor
  2. RAM
  3. Virtual memory
  4. Operatin system
  5. Video graphics card
To fix the problem you should first check which type of processor is used in you PC. Is it pentium4, Dual core, Core 2 duo or core 2 quad ? Core 2 quad is much faster if used with 4 GB RAM. RAM is also the cause to slow the PC. If you are using less RAM automatically your PC will be slow. So use RAM higher i.e 2 GB or more.
Virtual memory does not have much impact on speed but it is also a factor to slow down the PC. But if you can correct any of the three parts then no need to check virtual memory.
If you are using operating system like Vista then computer may be slow. Instead use XP professional, Windows 7.
If your PC doesn't have graphics card then it will be slow while playing games, watching videos. So if you are a game lover then change your graphics card with higher value such as 2 GB or more.
If you will fix these problems then you can speed up your PC
May 29, 2011 | Computers & Internet
Tip
Slow computer Performance causes and solutions
Slow computer causes and solutions how to speed up your pc?
Computer users often feel from time to time will slow down your computer starts up, and memory is not enough, the software is running slow, we can use many ways to clean up WINDOWS.
1. Do not install software easily. Online there are varieties of optimization software, but not many really useful, it will take up your hard disk space, and some software, usually with a virus.
Optimization of different operating systems in different ways. For example, for WINDOWS XP, WINDOWS XP every time you start when the blue scroll bar to scroll to be many times. We can reduce the time it’s rolling, to speed up the boot speed of the computer.
Open the Registry Editor, locate the HKEY-LOCAL-MACHINE \ SYSTEM \ Currentcontrolset \ control \ sessionmanager \ Memorymanagement \ prefetchparameters, the right to find Enabelprefetcher primary key, and change the default value of 3 to 1, then it will scroll the scroll bar reduced.
2. For Disk Defragmenter Computer was used for a period of time, the system disk defragmentation is necessary. Recommend that you try Advanced Defrag.
3. Clean up garbage Internet will often leave a lot of junk, we can use the Registry Easy to clean the hard disk.
4. Timely optimize registry WINDOWS registry has a feature that continues to expand, this will inevitably cause the computer to slow down. Registry Easy can master to clear
"Why my compute is running slow?"--To speed your computer up, I highly recommend you get a free computer scan to detect and repair PC system errors from now on.
on Jul 01, 2010 | Computers & Internet
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
Recently I have purchase a Toshiba Satellite L650 I5311 laptop, its interl core I3 - 350 M processor, 2.40 Ghz, 3mb L2 Cache, 320 GB SATA, 4GB DDR3 RAM, onboard graphics, the problem is the system is...
Only things that i can think of is that Norton anti virus has been known to be a bit of a system hog, so maybe search for an alternative, otherwise you may have a 32bit version of windows installed, getting a 64 bit version installed might see some increased performance, but otherwise make sure you have limited programs at startup, the more programs you have starting at startup will fill up your RAM and in turn slow down file swappage because the RAM is full
The only thing that is really a let down with your new laptop is the onboard graphics card, but that shouldn't be effecting file swappage, only effecting graphical programs.
however it could be because your running a Video/Webcast as well as a couple of other documents your graphics card might not be able to handle it, sadly you can't upgrade a graphics card in a laptop.
hope this has helped
Mar 29, 2011 | Computers & Internet
My laptop running slow and net browsing very slow my configeration windows7 original ,320 gb HD,3GB memorry
There are several reason for the computer to be running slow for the start please try restarting the computer to safe mode with networking (Steps given below) and check if your browsing speed is better. If your internet browsing speed not better in safe mode with networking then you need to contact your ISP to complain about slow speed.
If it is working fine in safe mode, then some of the software (example: Antivirus / Internet Security / Firewall) is slowing down your computer. Please try removing it. Also try reducing the color scheme, use a non aero theme and see if your comptuer is working fine. If so your processor is not able to take the load of windows 7 visual effects aswell as other programs running in the background at the same time
Mar 02, 2011 | Computers & Internet
Computer slow and freezes at times
Clean Windows Registry :
Defragment your PC to increase computer speed:
Add more RAM to Speed up your computer
Clear Cache, history and temporary internet files
Turn off unnecessary programs from start up:
Have low intensity graphics
Uninstall unused software and programs Please remember to clean Windows registry using registry cleaner reginout The above guidelines were really helpful to speed up my computer. These are safe and do impact computer performance in a positive way.
Oct 01, 2010 | Microsoft Windows XP Home Edition
Mera laptop slow chlta hai,proggrame slow open
Uninstall unused software and programs Please remember to clean Windows registry using registry cleaner reg in out The above guidelines were really helpful to speed up my computer. These are safe and do impact computer performance in a positive way.
Sep 17, 2010 | Samsung Computers & Internet
My computer is very slow and I need not much time left standing
The reasons for a computer being slow could be either that you have a full hard drive low memory or possibly and more likely you have malware on it. first thing to do is run and anti malware program like Malware Bytes
Download the free version and allow it to update and run a scan. once this has been done your PC should run a lot faster.
If not check your hard drive free space if it is below 15% you need to delete some of your old files and programs to free up some more
Jul 23, 2010 | Dell Computers & Internet
I have a dell computer and its running slow
Disk Clean up is a small percentage of what you need to do. As you go by installing and uninstalling programs a lot of debris of programs keeps the Windows Registry bloating more and more. And each time you give a command it has to read the registry which takes time. And you feel the computer is slowing down.
Solution:-
Go to www.ccleaner.com and download CCleaner free and install it. Run it and clean up the registry and all others extra baggage that slows the computer down. And wach your PC/laptop gallop after that.
Jan 02, 2010 | Dell Dimension 2400 PC Desktop
Toshiba Satellite L305D-S5974 Laptop Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
