Question about Nintendo Wii Console
Wii Remote stopped working for no reason.
one of my Wii remotes stopped working for no reason a couple of days ago. All I did was recharge the batteries for it and when I put them back in nothing would happen. I tried name brand non-rechargable batteries in case the rechargeable ones were the problem, but nothing. I have tried every trick I know to get it to work, I have tried pressing the sync buttons on the remote and console at the same time, numerous different batteries, pressing 1 and 2 at the same time, but all for naught. Let me clarify when I say it doesn't work, I mean the blue lights at the bottom dont even flash at all!
Now this wouldn't be much of a problem since I have a second remote, but I broke the second remote when I was....shall we say under the influence, so now I have two remotes that dont work and dont fancy shelling out 50 euro for a new one.
Thanks in advance!
  • Jafin Jan 19, 2009
    Thanks for your reply, but I've tried that already. I just dont understand whats happening, the blue lights dont flash at all.
    I tried the sync buttons again after I posted the first time and when I picked up the remote the back was getting very warm, so I opened it up and took out the batteries. They were starting to get very hot, which should definitely not be happening since the remotes not even on. I left them out cuz I didnt want the thing going on fire or something. I've had both the remotes since launch day just over two years ago and this is the first problem ive had so I e-mailed Nintendo customer services a few minutes ago and hopefully they'll respond tomorrow...
Well, pressing 1 and 2 doesn't work if your Wii remote came desynched. Press the Red Synch buttons on both the Wii console (located under the SD card flap) and the one on the back of the Wii remote, and hold one then the other for about 5 seconds. Should help.
Posted on Jan 19, 2009
How do i fix my wii remote
If a Double-A battery insert is present, then take out your rechargeable and insert 2 Double-A batteries. Then, start up the remote and point at the screen (Making sure sensor block is in range and exposed) so the remote can re-calibrate. Once done remove the batteries, if you'd like, and re-insert the rechargeable battery pack. IF this fails, simply remove and re-insert the rechargeable battery pack. Shut down the Wii manually at the home unit, and then start it back up using the Wii remote.
Oct 31, 2014 | Nintendo Wii Console
Unresponsive Wii remote!! HELP!!
The issue is with your game unit and NOT the nunchucks and/or remote.
Jun 12, 2017 | Nintendo Controller add-on Nunchuck for...
Wii remote is not charging. I have 2 remotes, one of them does not charge. Basically, when I charge it, it charges for a few seconds then it turns to the green light (meaning it's done charging) so it...
If you have had the "battery" for a long time, it could be that it can no longer carry a charge. Rechargeable batteries' charge grow shorter over time. If you still use the Wii/Wii U regularly, I suggest rechargeable AA batteries+charger (If you don't have them already). AA batteries work in other devices so even if you stop using the Wii, the batteries will still work in remote controls, clocks, flashlights etc unlike a WiiMote Battery pack.
Sep 10, 2017 | Nintendo Wii Remote Controller
Hi my wii remote was put in a charging unit but had normal batteries in it, now it wont work, is this why?
Normal or alkaline batteries cannot be recharged. Take out the old batteries and put in new ones. The recharger probably discharged the batteries.
Feb 18, 2010 | Nintendo Wii Remote Controller
Wii remote doesn't come on. Blue lights don't
Thanks for using FixYa!
If the blue light on your Wii controller doesn't light up, its possible that it ran out of battery charge. If you think your battery is fully charged. try to buy a set of disposable battery and see if they will work. If they do work, it means your rechargeable batteries have gone bad.
Have a great day.
-HotRatchet
Jul 28, 2009 | Nintendo Wii Console
What is the lifespan of the Wii remote? Having problems is it the remote or docking station. Have had it for two years is it time to replace?
Normally, the Wii remote will work properly unless dropped on the floor or banged against any hard surface. The Sensor connected to your Wii can sometimes end up dying because of normal use. This can be purchased for a mear 10 dollars at any Wal-Mart. If the sensor is not the problem, make sur that you are at the same level as your sensor when playing games. If you happen to be higher or lower, your Wii remote may end up moving unvolantarily around for no reason. The Wii remote is sturdy and has never broken up for me for the past 2 ½ years. Does the problem arise only when you use the docking station battery? If so, the battery would be the problem. I have stopped using this battery because of problems like these. I would recommend recharable Ni-hM batteries instead.
Hope this helps,
Regards
Jul 25, 2009 | Intec Charge Station w/ Rechargeable...
Wii Remotes can turn on but no arrows.
I had the same problem. When I looked at my system, I noticed the sensor was turned sideways with my tv remote in front of it. When I turned my sensor around correctly, and moved my tv remote away from it, the arrows suddenly appeared! Make sure nothing is blocking your sensor!
Jan 07, 2009 | Nintendo Wii Console
Wii remote stop working when I was playing Super Mario Galazy?
You may not be making the correct motion. It took me a couple of tries. The motion you use for this is to shake the Wii Remote like a can of spray paint or... kind of like a bottle of orange juice.
Jan 03, 2009 | Nintendo Wii Console
My Psyclone recharge station ruined my Wii remotes.
Try taking the batteries out and leave them out for a couple of minutes replace them and try again.
If it still does not work the rechargable batteries may be shot. You can test this by replacing the rechargable ones with disposable ones and see if the remote works then.
If it does then buy some new rechargable batteries.
I hope this helps
Nov 14, 2008 | Nintendo Wii Console
Volume on tv not working
Try pressing the favorite button on the remote. "Favorite off" should display and the remote should work.
Dec 29, 2007 | iLO 2600 Television
Nintendo Wii Console Logo
841 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
