Question about Kodak EasyShare CX7330 Digital Camera
Camera is calling for the SD card to be formatted
How do I format the SD card??
    President:
  • 1,285 Answers
If this the very first time using it (sd card)...plug your camera to pc using the usb wire it came with...you are setting it up so that you can put pix/video on it.......now if you have pix video files already on it (formatting will totally erase it)....if you really dont need/want/nor care for the pix just follow the same info from the top............
Posted on Jul 16, 2009
5 Suggested Answers
Kawika-56
  • 233 Answers
SOURCE: sd card will not format
Try formatting the SD on your computer. You will need a SD card reader.
Go to 'My Computer', right click on the card icon and select Format.
The rest is easy!
Posted on Nov 01, 2007
SOURCE: Kodak c310 camera won't format new SD 2GB card old card same size
Older C310s won't take that large a card. Try to exchange it for a 1 GB or smaller. I had the same problem - a PNY 1 GB works fine
Posted on Apr 15, 2009
SOURCE: camera will not format 4 gig card
I am having the same problem. I phoned a camera store and they said the camera is too to accept a 4GB card may only accept to a 2 Hope this helps
Posted on Oct 25, 2009
  • 11967 Answers
SOURCE: Kodak Z740 camera sd card formatting problem
Remove the card...turn on the camera and go into the menu...find "reset"...follow the on-screen instructions. Then try to format the card again.
Posted on Dec 18, 2009
Db power action hd dv camera troubleshooting
What make and model of camera are you using ? When you formatted the card, how did you format it - FAT32 or NTFS ? There is free software you can download called SD Formatter which will format a card in a way that can be read by the camera - you could download that and give it a try.
Dec 27, 2016 | Action Cameras
How i can format my sd card for vtech camera
1. The camera will format by itself.
2. or Use any already formatted SD card.
3. or in most camera setup mode, there will be an option to format the SD Card.
Apr 05, 2016 | Vtech Cameras
My SD high capacity memory card won't work
You call it a SD high capacity memory card, but does it say SDHC on the card, or SDXC. our camera only can use Multi Media cards, SD and SCHC cards (max 32 GByte). So no go for SDXC cards. Still a few things could be wrong if you have a SDHC card. The lock switch on the card could be in the wrong position and the card could have a wrong format. If you did format it in a PC, you should have formatted to FAT 32.
But the best format is the format in the camera. Before you do so, be sure there are no import ants files or pictures on the memory card, because they will be lost.
Jan 01, 2014 | Kodak EasyShare C142 Digital Camera
I have a finepix A805 and it keeps saying that my images are being saved to Internal Memory but I have a SD card in my camera. My SD card is not locked why wont my camera read the card?
If you don't have anything stored on the SD card I recommend formatting it, otherwise it will not work with your camera.
Go on the camera's menu and look for a function called 'Format'. Do this and then see if the pictures will save on the SD card.
May 04, 2011 | Cameras
My sandisk sd card isn't working in my camera. My camera is a vivitar 5024 camera, everytime I try to take a picture it says memory card is not ready, it says switch to internel ram. This memory card is...
Have you tried to format the card.
1.
  • Start up a computer with Windows XP, Vista, windows 7or Insert the SD card into an external memory card reader or into the computer's built in card reader. If it the first time a SD card has been inserted into the computer, Windows will recognize the SD card and automatically install drivers to read the memory card.
  • 2Go to the computer view by clicking on the windows start menu icon in the bottom right corner of the computer. In Windows 7 and Vista click "Computer". In Windows XP click "My Computer"
  • 3Right click on the SD drive under the computer heading. A dialog box with different options for the drive will appear. Click on "Format" to bring up the formatting dialog box.
  • 4Select the type of formatting (also known as file system format). In Windows XP or Vista there are several choices including FAT, FAT 32, and NTFS. In Windows 7 there is an added choice called exFAT formatting. This is an improved FAT formatting type with improved meta data capabilities. Choose the formatting type, name if the drive if desired, check or uncheck the "quick format" option, and press the "Start" button. When the SD card format is complete Windows will provide a notification.
    If you need further assistance please feel free to let me know. Thanks and have great day, Midwest-tek
  • Aug 31, 2010 | Vivitar ViviCam 5024 Digital Camera
    How to format or unformat memory card on IXUSi camera I need to know how to format and unformat the memory card I can't see the pcitures as it is showing no image on the screeen Regards C Robertson
    to format a sd memory card, you can insert the card to computer or camera, and select the format. To unformat a sd memory card, a data recovery software can help you.
    Are you in a dilemma as to whether to format your SD card or not? If you don't format the SD memory card, you cannot use your SD card any more, and you cannot transfer files from SD card to other devices. If you format the SD memory card, you will loss all the files like photos and videos on your SD card. Follow the link you can get the answer.
    Jun 28, 2010 | Canon IXUS 80 IS Digital Camera
    How to format the microSD?
    actually u shold format it by the device in which u are going to use. eg camera. This will enable correct formating for usage of this device.
    otherwise their is a standard Sd format and u can use that to format
    You can format the card by SD card Utility. SD utility is a format utility which is release from SD Association. It is a standard for all SD type card and will self determine the SD card's file system. Please kindly refer to the link below for SD format utility download webpage.
    http://www.sdcard.org/about/downloads/
    May 05, 2008 | Kingston 2GB Secure Digital Memory Card
    Sd card formatting
    Does SD card work in PC? HP R707 will not work with SD card larger than 2GB.
    Oct 22, 2007 | HP Photosmart R707 Digital Camera
    Sd card will not format
    The camera has a limit of a 2 GB card , its built into the camera hardware.
    Oct 19, 2007 | Kodak EasyShare Z740 Digital Camera
    SD Card Recognition
    Perform the following procedures when your digital camera does not detect the SD card. 1. Restart the camera Turn the main power OFF, or open the battery cover or SD card/battery cover to remove the battery. Make sure the SD card is fully installed. Then, turn the main power ON, or insert a battery again and close the battery cover or SD card/battery cover until it latches. 2. Initialize the SD card Format the SD card with your camera. Formatting procedures varies depending on the camera model. See the Camera User Guide supplied with your camera for the instruction to format the SD card. When formatting the SD card, slide its tab upward to cancel write protection. It is impossible to format the SD card while it is write protected. 3. Check if your camera detects other SD cards (If you own multiple SD cards.) If your camera does not detect the SD card after performing the procedures 1 and 2, check if the camera detects other SD cards. If it does detect other SD cards, the SD card that wasn't detected may contain some problem.
    Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
    Kodak EasyShare CX7330 Digital Camera Logo
    93 people viewed this question
    Top Kodak Cameras Experts
    Tony
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
