Question about Fisher and Paykel Washing Machines
Fisher and Paykel WA75T65GW1 3 lights flashing and beeps won't go
I have a Fisher and Paykel 7.5 KG smart drive washer. It refuses to do anything but beep with 3 lights on. After searching the net the lights that are on; 3, 4 and 8, apparently indicate error 49? I have swapped over the hot and cold water inlets and the wires that were connecting to them as well but this has done nothing. I have removed the top and checked and nothing looks burnt out in the brown box. In the machine the bowl looks fine and I have removed the pump off the underneath to check for blockages. Is there anything else I can check before I have to get someone to come and look at it? Thanks in advance for any help you can offer.
  • Fisher and P... Expert
  • 555 Answers
Your water valves are 24volt,
should read 60 to 64 Ohms on a multimeter.
Your error code 49 is Cold valve faulty in your machine.
1 amp fuse and 1 of the Mosfets on the board are blown.
You need to get a Technician to replace the parts.
Fisher and Paykel WA75T65GW1 3 lights flashing and - 2_9_2013_11_49_18_am.jpg
Posted on Feb 18, 2013
2 Suggested Answers
IFIXALL
  • 868 Answers
SOURCE: Fisher & Paykel smart drive
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode.With your service sheet ,Diagnostic chart will explain where the error lights pattern and the path to your solution are.My advice is this....there is a known problem with the wire harness connectors,and the contact that is made at the point of connection.One at a time remove each connector starting at your main control board ,some where there is a loose connection.
Posted on Jun 08, 2008
Fisher and paykel smart drive 5.5 won't start a wash cycle, no lights flashing or beeping looks normal but won't start
Contact Fisher and Paykel Service Center and DO NOT TRY TO OPERATE THIS MACHINE UNTIL CHECKED & VERIFIED BY AUTHORIZED FISHER AND PAYKEL SERVICE PROFESSIONAL.
Apr 28, 2014 | Washing Machines
Fisher paykel smart drive 601
Hi just read your post.When the machine beeps a series of lights will light up on the wash progress line of lights. Staring from left to right the long wah is number 1 and the spin light is number 8 which lights sre on when the machine beeps, is it 2, 4 and 8 or 1, 3 and 7 etc.Please reply with this information and I sure I can help you. Regards LU
Jan 24, 2014 | Fisher and Paykel Fisher & Paykel Washer
Smart drive 051 error code 32
Have you tried unplugging it and plugging it in again?
Nov 22, 2013 | Fisher and Paykel Washing Machines
Machine beeps 3 lights on and won't pump water out
can you take a picture of the lights that are on so I can work out the error code thanks
Jan 29, 2013 | Fisher and Paykel Fisher & Paykel Washer
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
My Fisher Paykel top load aqua smart washer won't
it wont spin if there is water remaining in it,check pump for restrictions or anything jamming it if good replace pump
Apr 27, 2012 | Fisher and Paykel Washing Machines
My Fisher and Paykel Smartdrive 7.5 kg fwon't agitate
when they beep the main p.c.b bord has detected an error on the f/p series the main fault we have found with this is the small icb sensor that runs along side the capstan drive drum try cleaning it if this does not work try replacing the head control p.c.b bord
good luck
Jul 06, 2010 | Washing Machines
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
Machine wont work
Your machine probably needs re setting hold power down for 60 seconds see if that works
Apr 15, 2008 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
445 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
