Electrolux EW1279F FL washer will not end programme, no sybols in display, no end bleep and door unlock mechanism not working
Programme does not end, no symbols in display, no "click" at end of cycle and no bleep to show end of cycle, will not unlock door either
gittos73
  • 244 Answers
SOURCE: Hotpoint Ultima WD71(probably the wd72 except in white)
hi there what u can do is take your drain hose and place into a bucket water will come out the door will release now check the pump and make sure that it is not blocked up with anything if it isnt check the drain pipe that is under the washer in the middle of the drum there will be water in there but check inside if anything is inside there it will slow down the empty programme and will not let the door release do u live in malta then m8 as my dad is maltease and im half
Posted on Aug 23, 2007
SOURCE: Classixx 6 1200 bosch washer...I've
You've put the child lock on! When powered key press the on/off button for 5 seconds. This will remove the key!
Instruction Manual can be found here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Posted on Dec 14, 2008
SOURCE: how to disable the alarm on a Zanussi ZWD16270W1 washing machine
To deactivate the audio alarm that denotes the end of the cycle signal carry out the following procedure:
press the left two buttons in the row of three buttons on the front panel for six seconds, carry out the procedure again to reactivate the audio alarm.
(The two buttons are labelled as SPIN and OPTIONS respectively)
Posted on Jun 27, 2009
VtToolMan
  • 704 Answers
SOURCE: the washer buzzes and shows
It appears that the door latch safety interlock was damaged or broken when the door was opened mid-cycle.
The codes "fl" Failure and "do" Door Open, seem to indicate that the latch and/or door switch need to be replaced. I tried to find a drawing and parts list for your washer, based on the model you selected, but could not locate one. If you can get the full model number, you can check for the replacement part at searspartsdirect.com or call them to get the part number.
If you look inside the door of the washer, you can see if the catch (on the moveable door) or the latch, on the washer cabinet) is the broken or damaged.
The repair is relatively straightforward and easy to do, with simple hand tools. Just make sure to disconnect the washer power cord before doing any work on it. Once you've done that, open the door and remove the screws and you should be able to remove either or both, the catch and the latch switch and reinstall the new ones, once you have them.
That should resolve the problem you're having.
Hope you find this Very Helpful and best regards!
Posted on Aug 22, 2009
SOURCE: Electrolux EWX 14440 W Washer will not start
This sounds like what I am having. Machine tumbles but does not rinse. Some postings say this is the door lock problem. Google "Fridigdaire washer will not Spin" and page down to read solutions.
Posted on Oct 26, 2009
Can dial in programme but when start is pressed all leds and display go out and it bleeps once. Eng mode gives E41 as last error
E41 means door open or the machine is not able to lock the door
(door delay interlock does not close after 15 seconds).
Possible causes:
door open, door delay interlock, wiring, main PCB.
Dado
May 04, 2016 | Zanussi WJS1265W Front Load Washer/Dryer
Unimac. Why is it displaying E FL and won't spin?
Unimac Washer Product Support ' ManualsOnline.com
laundry.manualsonline.com/support/unimac/washer/
Unimac Washer uw60b20u80001. 0 Solutions ... on start up unlock door light stays on.display sa. Unimac ... washer has falt code E FL what does this mean and.
E fl error code on industrial uni Mac washer. What's it mean ...
www.fixya.com/support/t20744713-e_fl_error_code_industrial_uni_mac
Jan 07, 2016 | Washing Machines
Not locking
I had this problem also with my Maytag Neptune TL. The door lock would click multiple times before displaying the FL code. I was able to fix this by removing the left door look(the one with the door close sensor) and cleaning the 2 metal pones on top of the left door mechanism, which had rusted and no longer was able to since the door closed. I use a nail file i sure either that or sandpaper will do. After that it went through the whole cycle without stopping or displaying the "FL" code.......hope this helps
Jan 14, 2013 | Maytag Neptune MAH5500B Front Load Washer
My machine is showing the code FL machine has problems locking. How do I resolve this problem
Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
Dec 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
It keeps dispaling FL in the panel
Hello, the FL displaying on the panel simply means Failed to Lock. Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
Solution
Check the wire connections in harness leading from machine control board to door lock mechanism
Replace responsible component..
Thanks
May 21, 2010 | Maytag Neptune MAH5500B Front Load Washer
Front load washer. Door will not unlock get error code "do" or FL. Door lock light is not on but door is locked and wont unlock. You csn hear a buzz as the lock energizes but does not unlock. Allready...
Sturdy little door, isn't it? Make sure you don't have extra water in the machine, as this will cause the door to not unlock. With that done,unplug your washer. If you can get the top of the machine off and reach down the front of the washer, you should see the latch mechanism. Push this down. Door should unlock. Now. Buy a new latch assemby.
Mar 16, 2010 | Maytag MAH8700A Front Load Washer
Whirlpool duet - door will not lock. Was working fine and now when I press start, I get the code "FL"and then "d" flashing.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Jan 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door lock mechanism
I had this problem also with my Maytag Neptune TL. The door lock would click muptiple times before displaying the FL code. I was able to fix this by removing the left door look(the one with the door close sensor) and cleaning the 2 metal pones on top of the left door mechanism, which had rusted and no longer was able to since the door closed. I use a nail file i sure eaither that or sandpaper will do. After that it went through the whole cylce without stopping or displaying the "FL" code.......hope this helps
Jun 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
1 month old electrolux FL IQ cuts off and won't restart
If it is only one month old then you should be covered by the warranty ??
To unlock the door place the drain hose in a bowl until the water comes out, if it wont then try blowing down the hose.
If you hear bubbles inside the machine then dump the hose back in the bowl
Once the water has all ran out switch the machine programmer to "off" and then try the door
May 31, 2009 | Electrolux EIFLW55HIW Front Load Washer...
The Timer Window shows FL and the washer stops after filling.
I unplugged the washer for 20 minutes, plugged it back in, the same FL message appeared, so I slammed the door (as a last effort to attempt to overcome the problem of door failing to close before I would decide to call a repairperson). Following the sound slamming of the door, the washer has worked just fine through the last five loads.
Apr 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
