Question about Fargo HDP5000 Thermal Printer
Error 103 headlift error fargo hdp 5000
First there is an abnormal noise it makes (as though friction-not well lubricated) prior to transferring the card? Then after it gives ERROR 103 Here is the narrative of the problem. > "Headlift sensor is not detecting movement from the Headlift CAM" Reboot the printer by cycling power. > Kind regards. John email: mariecomsys@gmail.com
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 12 Answers
Erro 103 could cos by head voltage erro or head fit erro.
this could be a problem with the printhead lift or transfer roller headfit.
reset the printer and try again ...
Posted on Feb 12, 2013
Why my Fargo ProL is not printing Edge to edge?
it depends how much edge to edge you want, its a direct to card printer and will not print all the way to the edge 100%. you can get it close by adjusting the horizonal settings, but to get true edge to edge you need the HDP printers.
Jul 18, 2014 | Fargo Pro L ID Thermal Printer
Fargo HDP 5000 heater error 161 fault
This error usual occurs after a large print job (50 prints in a row). Try shutting off the printer, and leaving it off for a good 15 minutes. Turn back on and retry.
If the problem persists, then you should contact a service center. It seems to have a failure in an internal sensor.
May 06, 2014 | Fargo HDP5000 Thermal Printer
Image color adjustment hdp 5000
on the printer property dialog select image color tab then advanced settings, for darker images increase sharpness and contrast and decrease gamma to you satisfaction
Aug 26, 2013 | Fargo HDP5000 Thermal Printer
My printer show the error 99 Ribbon Break/Jam but the ribbon is ok is not broken and i can not see some jam. Can you help me
Pls do the following:-
Ribbon Break/Jam
(PC Error Message No. 99, 108 and 109)
The Ribbon is not able to find the next panel correctly. Check for jams/breaks.
If jammed, clear the jam. If broken, repair by taping the Ribbon back on to the take-up core.
Press Resume to continue or Cancel to abort.
Thank You...........
Jul 26, 2011 | Fargo HDP5000 Thermal Printer
Error fargo hdp5000 # 218
can somo one help I have Fargo HDP5000, showing an error LAM2 HEADLIFT ERR 218
Apr 21, 2011 | Fargo HDP5000 Thermal Printer
We just bought Fargo HDP5000. on first installation now its bringing error code 97 and 99 which when we calibrated the printer the error 99 was solved. but the error 97 is still there. pls help
hola hermano tengo problema con mi impresora hdp 5000 cada vez que boy a imprimil me da un error 103 y 105 me dice en la pantalla del monitor de mi pc que el sensor no detecta el movimiento del cabezal
Apr 19, 2011 | Fargo HDP5000 Thermal Printer
What is the oil capacity for a front & rear axle for a Jeep Grand Cherokee 3.0
FRONT AXLE ± 0.3 L (2 oz.)
C200F
1.7L (57.5 Ounces)
C200FE
1.7L (57.5 Ounces)***
REAR AXLE ± 0.3 L (2 oz.)
C213R
2.07L (70 Ounces)
C213RE
2.24L (75.5 Ounces)***
*Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
** Includes 0.9L (1.0 Quarts) for coolant reservoir.
***ELSD - add 118 ml (4 Ounces) of friction modifier.
Transfer Case (3.7L Engine)
Mopar® ATF+4 Automatic Transmission Fluid
Transfer Case (3.0/4.7/5.7L Engines)
Mopar® NV 247/245 Transfer Case Lubricant
Transfer Case (6.1L Engine)
Mopar® NV146 Transfer Case Fluid. Usage of other fluid/lubricants is NOT recommended.
Axle Differential (Front-Rear)
Mopar® Synthetic Gear & Axle Lubricant SAE 75W-140 (API-GL5) or equivalent with friction modifier additive.
Sep 23, 2010 | 2007 Jeep Grand Cherokee Overland
2003 Sierra 2500hd transmission or transfer case making grinding noise (sounds like a bearing going bad) it becomes louder when i give it gas. i checked the fluid in the transfer case which looked ok, i...
Sudden grinding noise with no prior warning * Primarily in 2nd gear, behavior in reverse may be abnormal; sunshell is fractured. R&R. Try not to run or drive the car or further damage could result.
* Reaction planetary is worn out due to high miles or insufficient lubrication. Not a critical failure, but not a good sign either. R&R sooner rather than later.
* Either a torrington bearing or a planetary bearing is on its way out. Trans will eventually die a loud, catastrophic death. Cheaper to rebuild now (saves further damage to hard parts), but requires R&R. It is drivable until it breaks.
Good luck and thank you for using fixya.
Mar 17, 2010 | 2003 GMC Sierra 2500HD
HEAD LIFT ERROR ON FARGO DTC500
where can i go to solve this problem of printheadlift?
Jul 20, 2009 | Fargo Office Equipment & Supplies
Error/ Head Lift Error
If you replaced the o-ring on the headlift assembly and that did not solve the problem, most likely you may have a sensor out that controls the position of the head lift.
Dec 12, 2008 | Fargo DTC550 Thermal Card Printer
Fargo HDP5000 Thermal Printer Logo
303 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Level 1 Expert
pkwc
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
