Question about HP Compaq dc7700 PC Desktop
My Hp compaq PC showing problem about HDD - Disk Read Error . But This HDD was run very good to another PC ?
My Hp Compaq dc7700 Desktop PC showing problem about HDD - Disk Read Error . But There was no any problem in HDD b'cos this HDD was run very good to another PC ,
  • HP Master
  • 27,725 Answers
Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. b> 1: Download a disk read error repair tool,install this error repair tool.
2: Open disk read error repair tool and scan you computer for free
3: Then click the Repair All Button again and your done! It is very easy to repair disk read error.
Here are the url of disk read error repair tool:http://www.RepairErrorInstantly.com/ttfi... or rather than doing this try the alternative which is windows own repair Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download http://www.RepairErrorInstantly.com/ttfi... Then restart again into safe mode with command prompt. Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer Hope this helps. b>
Posted on Jan 05, 2013
SOURCE: CPU FAN SPEED IN HP Compaq d530 Small Form Factor Desktop PC
The fan/heat sink on these models get plugged with dust very easily, use an air compressor or can of air to blow the dust out of the heat sink and fan. In extreme cases the thermal paste gets dried out and needs to be re-applied to properly cool the processor.
Posted on Feb 10, 2009
Kiranbala
  • 91 Answers
SOURCE: HP Compaq d530 SFF PC Desktop. Black Screen and Cursor blinking..
Try to enter in to BIOS by restearting the notebook (Pressing F2 function, if the notebook enters in to bios then no need to worry. after theat i suggest you to reinstall the notebook to original factory settings dy the recovery disks.
Posted on Mar 07, 2009
  • 5 Answers
SOURCE: Changing Vista to XP Pro on a Compaq Presario SR2180NX Desktop PC
SR2180NX has the Vista 32Bit OS from HP. The restore partition will always put Vista 32Bit back on if you use it. Windows XP can only be put on from scratch and I have done it while I still have Vista installed. One problem: there are no XP drivers under SR2180NX webpages. Do your research on the parts that are installed in the 2180 and any other HP machines that have the Windows XP operating system as the OEM OS. But First, check the Intel Site for the 945 chipset drivers (include the SouthBridge, too) under XP. Get them downloaded to a CD and burn the rest of the drivers you find for XP on the same CD. This way, you will have them ready when you are performing the down-grade to windows xp. After you are done with the XP install, you will still have access to the files & work you had done while in Vista. The Vista files are still readable. You might want to consider getting the Windows 7 Professional (not basic) available October 22, 2009. AND you will still have to get the Intel Downloads for Win7 any way, so why not make it a project and make it last for a few years. XP Support stops in 2014.
Posted on Sep 30, 2009
  • 76 Answers
SOURCE: HP Compaq dx2300 Microtower - PC Desktop Ethernet
hi.. to find the driver... just refer this site.. scroll it down and download network card or NIC driver.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3352968&prodTypeId=12454&prodSeriesId=3352967&swLang=13&taskId=135&swEnvOID=1093
Posted on Mar 18, 2010
SOURCE: 1801 Microcode Update Error
Posted on Feb 25, 2011
Hp compaq dc7700p gives amper light
The green light comes on where? On the laptop?
Jan 13, 2014 | HP Compaq dc7700 PC Desktop
Media test failure check cable
RUN the software diagnostic coming with the computer and fix it. God bless you
Mar 29, 2013 | HP Compaq dc7700 Ultra-slim Desktop PC -...
Will an optical drive from cq62 fit mine?
NO.
I sort of see your reasoning, but NO.
HP Compaq DC7700 Ultra-Slim Desktop PC, and Compaq Presario CQ62 series of Notebook PC DVD burner drive?
http://www.ebay.com/itm/New-For-Compaq-Presario-CQ62-TS-L633-SATA-CD-RW-DVD-RW-Multi-Burner-Laptop-Drive-/300725349252?pt=US_CD_DVD_Blu_Ray_Drives&hash=item4604a0ab84
Until I compared both units I would have stated NO.
Now that I have THANK YOU. I just learned something,
http://www.amazon.com/HP-Compaq-DC7700-DC7800-DVD-ROM/dp/B004574PEG
Referring back to the photo view, of the Compaq Presario CQ62 series of Notebook PC's DVD burner drive shown, the REAR view shows the connectors for the SATA power cable, and SATA data cable.
The connectors use the same L-shape design, and size that a SATA unit for a desktop computer, would use.
Case design looks to be similar also.
I believe you are Correct.
For additional questions please post in a Comment.
Make all checks out to; The joecoolvette Fund for Having a Good Time
Regards,
joecoolvette
Oct 08, 2012 | HP Compaq Dc7700 Ultra-slim Desktop Core 2...
What's your problem?My computer can not come on screen
Hi
Is the desktop on?
Open it up and check the on-board light.Is it on?
Are the fans running?
Check the hard disk connections.
Is the monitor powered?
Try replacing the VGA cable.
Mar 02, 2012 | HP Compaq dc7700 PC Desktop
How can i install my hp compaq dc 7700 945 audio driver
HI,
Installing the HP DC 7700 Drivers is a little tricky. You may have installed the drivers and its not working I guess. This is because the HP DC-7700 has HD Sound and it required "Microsoft Universal Audio Architecture Bus, which can be downloaded/ installed from the following link. Choose the Operating system you have on your PC and get the drivers.
HP DC7700 Drivers
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | HP Compaq Business Desktop dc7700 -...
Drivers for internet hp compaq dc7700?
onn this page:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_query=Compaq+dc7700&submit.x=4&submit.y=5
Select your exaxt model of you PC. On next page click on "Download drivers and software" and select your operating system.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 11, 2011 | HP Compaq dc7700 PC Desktop
HP Compaq dc7700 PC Desktop Logo
110 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
