I have a panasonic sa-pm5 and have error remote 2
Error remote2
  • 298 Answers
SOURCE: Panasonic SA-HE100 Remote
The correct replacement remote from Panasonic can be found in the link below.
Panasonic SA-HE100 Replacement Remote
Posted on Jun 25, 2008
ravichetty
  • 158 Answers
SOURCE: Panasonic DVD Stereo System (SA-PM91D) REMOTE MODE 1
press the enter and number 1 button on remote simultanously
Posted on Jul 31, 2009
SOURCE: panasonic sa-ht540 f61 error message
If the model has a fan fitted (may have 2) that be your problem faulty fan
Posted on Aug 26, 2009
SOURCE: can't play iPod on my panasonic sa-en27 with out a remote
I ran into the same issue, instead of buying a replacement remote I was able to dial in a Vip 211 dish network remote control with remote code 643 in AUX setting. Then once the code was in, i pressed the 6 key on the remote and now I can listen to audio on the music port. The 643 code refers to the first Panasonic amplifier/receiver in the code list. To further clarify, I pressed AUX for 4 seconds, pressed 2 to signal I am programming an amplifier/receiver device, then punched in 643 then pound sign.
Good luck with yours.
Posted on Jun 18, 2010
welcomejee
  • 10594 Answers
SOURCE: Remote not working. Unit is
If unit is set to remote-2 then you need to change remote mode on remote itself as per unit to communicate, press and hold ENTER and 2 buttons on remote for 3 seconds to change remote mode on remote control, now unit will accept remote commands.
If you want to change remote mode on unit, go to menu and change remote option in unit then again change remote control mode accordingly.
Thanks.
Posted on Nov 15, 2010
Panasonic sa-pt770 will not power on
When power is applied do you get any LED light or display that shows?
Dec 27, 2014 | Panasonic Sa-pt770 Receiver
NAO CONSIGO USAR MAIS O CONTROLE REMOTO, COM ISSO NAO CONSIGO FINALIZAR O DISCO......QUANDO TENTO USAR O CONTROLE APARECE NO DISPLAY " CHECK REMOTE ". E NAO SAI DESSA.
Há algum tempo o meu Gravador de DVD de mesa Panasonic DMR-E55PL-S vinha apresentando a seguinte mensagem de erro sempre que eu clicava qualquer comando através do controle remoto: CHK REMOTE2 Havia entrado em contato com o técnico da autorizada Panasonic de Niterói e ele ficou devendo-me uma solução. Como possuo outros 3 gravadores de mesa (2 Pioneer e 1 Samsung R121), apesar da contrariedade, não esquentei muito a mufa. Hoje, porém, encasquetei, e resolvi tentar, mais uma vez, resolver a má função. Após "ene" tentativas malogradas pintou o insight: - "Cacildas! Se eu faço tanta pesquisa para dirimir as dúvidas dos companheiros, por que não o faço também, para mim"? Assim, digitei no "gluglu": CHK REMOTE2 Panasonic Entre outras dicas, saquei esta: Question: - "Whenever I press any button on my remote control, I get this error message on the front panel display - CHK REMOTE2" Answer: - "Just hold ENTER and press the number indicated on the display for a few seconds, and it will fix the issue". Basta clicar ENTER e pressionar o numero indicado no display do painel frontal do gravador por alguns segundos - isto resolverá o problema. (Clicar ENTER e pressionar o número 2 no controle remoto). Tal dica serviu para o meu DMR-E55PL-S como também para o DMR-E85HS - do **** "flashcode" - devendo servir para outros modelos Panasonic da mesma linha. Soçarba... Mr. Walker
Aug 25, 2010 | Panasonic DMR-E55 DVD Recorder
I have Panasonic dmr-e95H and need to reset the
My DMR-E95H displays: "CHK REMOTE2" whenever I push a button on my "replacement" remote. Is there a way to reset the DMR-E95H without the original remote?
Apr 05, 2010 | Panasonic DMR-EH57 HDD Recorder Player
Pm5 is not opening, asking netware error pm5.exe
A Netware error was dected. Please verify that you are properly logged in. See the network Installation guide for more information
Apr 04, 2010 | HP Computers & Internet
Jul 19, 2009 | Panasonic Televison & Video
Can't play iPod on my panasonic sa-en27 with out a remote
Feb 14, 2009 | Panasonic (SCEN25) Shelf System
Remote controle
Easy to fix. The DMR E55 has 3 remote control code settings and your remote can be set for any one of them. The error you are getting at the moment means that your remote is set for one code but your DMR E55 is set for another. Why do Panasonic do this? The reason that Panasonic do this, is because if you have several Panasonic units, you can operate one of them from your remote without all of them responding at the same time. Ok, so how is it fixed? Turn on your DMR E55 and press FUNCTIONS then select SETUP. Then select OTHERS. You will see the remote option on the right which will say DVD 1 or DVD 2 or DVD 3, Try setting it to a different code and press return. You should get it to work...
Sep 19, 2008 | Panasonic DMR-E55 DVD Recorder
Look here:
http://www.pasc.panasonic.com/Epartr/PartsList.asp
Oct 15, 2007 | Panasonic SA-HE100 Receiver
Remote control not working
I had the problem where when i would try to use my remote, it would say "check remote2". I've got a DMR-E55. I called panasonic and they told me to hold down the "enter" and "2" button for about 10 seconds. then it worked. hope it works for you too.
Jul 09, 2007 | Panasonic DMR-ES10 DVD Recorder
113 people viewed this question
 Grubhead
Grubhead
