Question about Compaq Presario M2000 Notebook
Do compaq presario m2000 laptops have sata ports
Does the compaq presario m2000 laptop have a sata port or ports?
  • Compaq Master
  • 32,281 Answers
This model Compaq laptop does not have any SATA connections/ports.
This WEB site shows the specs for this laptop.
http://www.ehow.com/list_7325244_compaq-m2000-specs.html
Posted on Jan 05, 2013
  • 188 Answers
SOURCE: usb port defective
It looks like they are part of the motherboard.
If they are physically damaged a competent repair shop can replace them probably a couple hours of labor ($120-$200 depending on the place. If they dont work at all then I would just buy a USB PCMCIA card which plugs into the side instead ($20-40).
Posted on Dec 21, 2007
Pyrhyc
  • 2028 Answers
SOURCE: VGA driver for Compaq Presario M2000
Here's a link to the driver site for your machine. Choose your operating system and it will give you the list of drivers.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=433559&lc=en&dlc=en&cc=us&lang=en
Posted on Jul 25, 2008
ItWillBoK
  • 108 Answers
SOURCE: drivers for compaq presario m2000
Here you go:
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=433559
Happy Holidays
Posted on Dec 24, 2008
SOURCE: disable sata in bios of compaq CQ40 laptops
i m not able to install windows xp on my compaq cq60 104tu laptop
when i boot the cd the exatrating process work properly and after extraction of all file when windows is startup a blue screen appears and
and message displayed in the screen check ur hard disk for vireuses
and installation stop
Posted on Apr 05, 2009
  • 40 Answers
SOURCE: Compaq Presario m200 Laptop system recovery
buy or download a windows disk. insert it and format the partition and install a fresh copy
Posted on Nov 11, 2009
My compaq presario m2000 laptop turns off automatically. When I turn it on again it turns off after about 10 minutes.can you please help me solving the problem?
Welcome to FixYa!
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Jul 12, 2011 | Compaq Presario M2000 Notebook
I took out my hard drive in my Compaq Presario V2000 laptop...and I'm not sure what type it is..like an IDE, SATA...and whether it needs a 2.5 or a 3.5
Hi
Normally a laptop computer using the hard disk type 2.5 "
Here I attach the hard drive example for your reference.
Pic 1> 2.5" IDE HDD
Pic 2> 2.5" SATA HDD
Tq and regards
Mar 21, 2011 | HP Compaq Presario V2000 Notebook
Have compac persario m2000. The power supply will
the issue might be with the power jack . i mean the port where you insert the charger.. to fix this issue your laptop needs to be repaired.
Jun 14, 2010 | Compaq Presario M2000 Notebook
Compaq presario m2000 imediately shuts down after
Check for blocked air passages - vacuum out the fan ports. (Don't use canned air - you'll just blow the dust inside, where it will act as an insulator and help things overheat.) Make sure the fans are actually turning. If there's any mold growing inside, that could cause the problem too.And for more contact http://tinyurl.com/m7ghqz
Jun 18, 2009 | Compaq Presario M2000 Notebook
HDD Upgrade and Specs for Compaq Presario M2000
Yes the M2000 will support at least an 80GB hard drive.
Jun 11, 2009 | Compaq Presario M2000 Notebook
Laptop will not start (compaq presario m2000)
Try removing the battery (which may be bad) and only have ac power connected.
RDO
Nov 17, 2008 | Compaq Presario M2000 Notebook
Windows installing problem in compaq v6409tu laptop
Go back into your your bios and disable SATA.
You must have IDE enabled if you don't have a SATA drive.
Once IDE is enabled again you should be able to format your drive.
Dec 27, 2007 | Compaq Presario M2000 Notebook
Compaq presario 1250 laptop
It is possible that while you had it apart you lossened one of the IDE ribbon cables from the motherboard or harddrive.Take it back aprt and make sure all the cables are tightly seated.Rate me FIXYA! if this works!
Nov 18, 2007 | Compaq Presario M2000 Notebook
Dead USB Ports...
Have you checked drivers not only for the usb, but for the chipset of the system itself. Also, have you installed service pack 2?
Might also just visually inspect for troublesome fingers in the ports themselves; often get bent and short out.
Good luck
Oct 16, 2007 | Compaq Presario M2000 Notebook
Compaq Presario M2000 Notebook Logo
124 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
