Question about Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer
Bravos Dryer blinking start button
I have a very new (3-4 months) Bravos steam dryer made by Maytag. The other day, I tried to use it and the START button is blinking and the dryer will not run. All the other displays seem to be working but, it just beeps when I push START. I've run through every posibility I can think of to get it to work but, nothing. Any ideas? It seems like a simple control panel / setting issue but, Maytag cannot tell me anything about this problem (no surprise there) and keeps telling me (I've called a few times, never hurts, somebody may know more than the usual phone jockey) to get an appliance repair technician. However, the warranty does not cover calls to "instruct you how to use your major appliance." I have a bad feeling about calling in the repair tech. and want to learn more first.
  • nethrower Jan 20, 2009
    I have already done all that you have suggested and more. I have even disconnected the dryer from the vent, in case cold air from outside had lowered the temperature of the dryer below the 45 degrees F that the manual indicates it will not run. There is no flashing code. The only light flashing is the one on the START button. I suspect that it is behaving as though the dryer door were open (I cannot recall if the start light would blink when it was) and when I unplug the dryer and then plug it back in, the drum light comes on. However, the dryer is just too new for the door switch to have failed. I can push the switch manually and hear it click, only other thing would be the board is having problems but, again, the dryer is brand new. If it has broken already, well... I will never buy a Maytag again, if that is the case.
  • connie401 Feb 15, 2009
    I have the same problem with my new, one-day old electric 800VU Maytag dryer. My drum light does not light when I open the door...it does when I hit the switch on the display. But I cannot override any settings and my laundry is not drying. The load stops after a few minutes and the start light starts blinking. Is this a bad drum light switch already?
    President:
  • 1,214 Answers
Manual says it could be a number of things, and you should have a copy of the manual since you've only had the dryer 3-4 months. If not, go to the Maytag website and download.
Some things to check -
1) Press Start/Cancel if dryer was stopped in a middle of the operating cycle.
2) Check that one of the two breakers has not tripped or fuses blown (if an electric dryer) in your breaker panel.
Please reply the flashing code number so that I may can help you further.
Posted on Jan 19, 2009
  • Mark Egan Jan 20, 2009
    Just some clarification as I try to help you determine the problem - sorry that I did not understand of some of the things you had already tried.
    1) You indicate the drum light is on - is that with the door open, and closed? Can you tell the drum light is on with the door closed?
    2) Have you tried to manually push the switch in until it clicks, then press the "Start" button? The clicking sound is no guarantee the door switch is working properly. I would expect at least the drum light would go off when the switch "clicks" as though the door were closed.
    3) I am leaning toward it being a bad controller board too. But I would think it is still covered by Warranty and the repair should be at no charge to you.
    4) Failures such as this are better to occur during a Warranty, than for the failure to occur after the Warranty. And while it's upsetting that you got a failed one (if you did), please realize that there are no guarantees, only Warranties, and how the manufacturer responds is a sign of their commitment to make you happy. You've not had good success at getting Maytag to respond, but maybe it's the way you've presented the issue that makes them cautious or hesitant in proceeding. I know I am, because of the rating already given to someone who is trying to understand what the symptoms are and what has already been tried to attempt repair.
    If the drum light remains on with the door closed, I would be real suspect that the door switch has failed. Please reply if you've attempted what I asked in #2 above, and let me know the outcome.
My Maytag Bravos XL dryer will start but not heat at times. I was going to take the unit apart to inspect the heating element and the rest of the unit. I had unplugged the unit and removed the dryer v
Im assuming you have a steam dry option? If this is the case there are fuses attached to this system to avoid injury and bad this from happening. These fuses blow a lot. If you have a ohms meter, check the fuses on the steam dry unit for ohms. I bet one of them is blown and that is the reason your not getting heat during this cycle.
Nov 13, 2014 | Maytag Dryer. Bravos XL 7.3 cu. ft....
Ma secheuse maytag ne fait pas de vapeur
translation
My Maytag dryer does not make steam
Permalink
When I put on this function makes no steam
questions
1. is there water flowing to the dryer?
2. Is the dryer connected to a water source
3. Are there any clogged water filters or screens in the back of the Dryer.
4. If there are no water problems, then I would check for thermal fuses or defective control boards.
Oct 30, 2014 | Maytag Dryer. Bravos XL 7.3 cu. ft....
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
JUST MOVED TO A NEW LOCATION AND THE BRAVOS DRYER WONT WORK.POWER BUTTON WILL NOT POWER DOWN AND PAUSE START BUTTON WILL DO NOTHING.
Double check the power source, you may need to reset the breaker. It would be rare that the dryer would fault internally during transit because a gas ignitor you be the loss and you do not have one. Check the power supply and confirm you have at least 220 volt to wall and dryer. Get back to me if you need more help.
Thanks
Nov 20, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My bravo steam dryer is showing an F1 code, and I can't get it to start
this is a control board issue, you may be able to clear the fault using these steps:
1) Unplug or turn the circuit breaker off for 30 seconds.
2) Plug the dryer back in or turn the breaker back on.
3) Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
4) Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
If it will not clear then you will need to replace the control board, Good Luck Tim
Mar 05, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag bravos dryer wont start when button is pushed. all lights are lit except timer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
I have a maytag electric dryer, when I turn it on, you can hear the timer but nothing else happens. I did check the vent inside and it was clogged, I cleaned it all out but it still wont go on...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Sep 30, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
My 5 year old Whirlpool dryer just didn't start one day.Instead of dealing with repair,we got a used 4 year old Maytag dryer.It dried the first load,then when I pushed the start button it made a weird...
It is the motor winding shorted out which caused the smell. If you still have your old dryer the safty thermal located on the exhaust housing is blown. White plastic with 2 wires going to it. Very inexpensive repair. Hope this helps.
Feb 13, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Maytag Bravos Dryer (1 mo. old) timer does not change from start
Maytag Bravos 400 Series Dryer purchased August 2009 - November 2009 required repair as I also experience the timer readjusting itself to excessive extended drying time when clothing was bone dry and hot. Sometimes extended to 1 hour 40 minutes! Serviceman stated problem was the Sensors in the dryer. Part number 8577274 Thermister and "Old Ohmed out open" whatever that means as listed on my repair ticket. Have not had that particular problem since. Make sure your dryer vents from dryer to outside are clean and clear of lint. Will help immensely. I have many other issues with this dryer it has been down FOUR times in 9 months. Fighting with Maytag to replace this lemon!
Jan 13, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Maytag Bravos 7.0 Cu. Ft. SuperSize Capacity Plus Gas Dryer Logo
1,380 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
