Question about Refrigerators
Can't find replacement parts for Haier aficionado model hvt18dfbb
Black 18 bottle wine cellar model # HVT18DFBB will not cool wine fans are running led display is on temp will not drop.
  • 27 Answers
SOURCE: wine cooler
cheak the machine main on/off switch, cheak the in$out phase line
Posted on Jun 21, 2008
huuum
  • 750 Answers
SOURCE: WINE COOLER
hello jelani372,
Happy you assist you.
You asked,
WHERE MIGHT THEY BE LOCATED I AM A ROOKIE I DO HAVE THE BACK COVER OFF ALL HELP IS APPRECIATED THANKS I HAVE THE HVT18DFBB MODEL
I believe this is the web site you asked for!
http://www.haieramerica.com/en/
Bless You,
Please rate me as solved, before you sign off please. Thank You!
Posted on Sep 14, 2008
ramon49
  • 111 Answers
SOURCE: My Haier 12 wine bottle cooler is dead. No fan or cooling .
Check the 2 fuses,one covered with black heat shrink, next see if internal fan is spinning, inside door, the 2 fans on the back should spin when first plugged in. also the 2 led's red and green should light up...if internal fan doesn't spin then check or replace, use batteries to get it to spin as a test...good luck,safety first...
Posted on Mar 09, 2009
SOURCE: haire hvt18dfbb cant find any documentation
If either the top or bottom compartment is not cooling, then the thermal couple (cooling module) behing the fan and heat sink is bad. It can be replaced with part number RF 4545-14 but they cost $70 each. One on the top and another on the bottom. You would need to solder a few wires. I think, this is not worth the cost, since the fridge cost about $150. Also if you don't get power than the circuit board in the back has burned-out. The replacement for this part is RF-5210-37 cost about $38. I replaced the the circuit board after the fridge wouldn't go on. Now the top compartment won't cool and I need a thermal couple. Total cost would have been $130 and I think it's not worth it. So since I fixed the power issue, I will use this fridge just for my reds in the bottom compartment for as long as it will last. I will remove the broken thermal couple, maybe I can put together my own.
Posted on Apr 03, 2009
SOURCE: Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
Posted on Aug 16, 2010
Aficionado hvt18dfbb is running but NO TEMP CHANGE
There is no compressor on these units. These units use a Peltier cold/hot module where the cold side faces the heat sink and the fan exhausts the heat side. Another fan sends the cool side into the frig. I have the same unit, I am experiencing the same issue. I was looking to change out the Peltier modules (about $7 each) and try that. I did find a replacement Control Board is about $45 and if the Peltier change doesn't work this may be my next step.
Nov 08, 2012 | Haier HVA052ALL-8S 52 Bottle Aficionado...
I need the Haier 18 bottle wine cooler instruction manual.
Hi There,
I was able to find two 18 bottle wine coolers on the Haier site.
The first is model number HVTM18DABB
http://www.haieramerica.com/wine-beer-beverage/wine-cellars/hvtm18dabb
The second is model number HVTSM18DABB
http://www.haieramerica.com/wine-beer-beverage/wine-cellars/hvtsm18dabb
On either product page the manual can be downloaded from the "product support & downloads" tab
Have a great day!
Jul 18, 2012 | Refrigerators
I have one of the black and Decker mini fridges. The light is on inside and the fans are turning on the back but the fridge is not getting cold. Is it broken?
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 17, 2011 | Haier HVA052ALL-8S 52 Bottle Aficionado...
I have a Aficionado refrigerator and the compressor will not start. I hear the starter clicking
The clicking is the sound of the Klixon (overload). It sounds like the compressor isn't starting for some reason. This is common if the unit's cycle was disrupted (such as a power disruption) as the pressure in the high and low side takes a little while to equalize. A hard start kit could be installed which adds a capacitor to the starting circuit of the compressor might help temporarily.
Jun 21, 2010 | Haier HVA052ALL-8S 52 Bottle Aficionado...
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
May 04, 2010 | Haier BC112G Wine Cooler
I have an Haier 8 bottle counter top wine cellar. No electricity to digital display, rear fan is not on and does not cool. Looking for schematic for possible fuse location.
look down of the wine celllar and take off the plastic cap and clean the electrics contact. After that use use the 4 screwed support to give it the right inclination._400.jpg
Apr 10, 2010 | Haier HVUE08A Wine Cooler
Frig won't chill. can hear it click off & on when plugged in.
HAVE YOU CHECKED THE SWITCH ON THE COMPRESSOR OR THE FUSE ? AND IF THE COMPRESSOR IS KICKING ON CAN YOU HEAR THE BLOWER FAN KICK ON ? IF ALL IS GOOD THEN YOU HAVE A BAD CONDENSOR THAT WILL BE THE NEXT THING TO CHECK
Apr 11, 2009 | Haier HVA052ALL-8S 52 Bottle Aficionado...
WINE COOLER
hello jelani372,
You asked,
Bless You,
Jun 22, 2008 | Haier HVT12ABS Compact Wine Cooler
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
