Question about Sharp EL-738 Scientific Calculator
Multiple IRR Using the Sharp EL738 how do I find the IRR (25% and 400%) for the following cash flows CF(0) -800; CF(1) 5000; CF(2) -5000. I have tried the following steps but can not get the second rate (400%). ie -800 [ENT] 5000 [ENT] -5000 [ENT] 395 [I/Y] [2ndF] [CFi] [COMP] I always get the first rate of 25%. Help
4 Suggested Answers
SOURCE: invalid computation
Hmmm, I don't think the problem is with your calculator. I'd be checking the accounting question again as I don't think you've got your annuity question structured right.
4 Year Annuity
14% Annual Interest Rate
Your contributing $4,000 per year over the next 4 years
and you already know the future value is $50,069?
You'd have to make annual payments of $11,878.93 (4 of them) at that annual interest rate to get to a future value of $50,069 (which has a present value of $43,632.24).
Are you sure that the FV isn't the trade in value at the end of the 4 years?
Posted on Mar 30, 2008
SOURCE: Computing IRR calculator goes blank and outs Error 7
I belive this will fix the problem i was sitting here having the same deal waiting and waiting..then bam error 7 then i fixed it so thought i would put what i did.
go into your CF and delete all the unused CO times..for instance if your using 3 periods...delete all CF05 and F05 the last one should be C04=0 and F04=0 make sure your NPV is the same after messing around..then try to compute IRR popped up in 2 seconds for me.
word hope this helps u all ***420*** :0
Posted on Mar 05, 2009
trix1234
SOURCE: Hoe do I calculate the
Can anyone provide the steps for calculating IRR on the Sharp EL-531WH?
Posted on Oct 09, 2012
How do I load the IPL to a CASIO TE-2400?
that is the correct way . Maybe you need to activate sdcard option on the new machine it could be off
Apr 30, 2014 | Retail Supplies
Casio te 2400 How to download Z tape to Compact Flash Card
Found this on another website. I have not tried it to verify, but it sounds reasonable:
http://www.baystatepos.com/CasioTE-2400spec.html
Insert a CF FLASH CARD into the front of the register before taking a "Z" report. Turn the manager's key to Z1 and press CASH AMOUNT TENDER to issue a BATCH report of all sales activity, which prints from the register's receipt printer. This report information is also automatically written to the CF Flash Card capturing the register's terminal number and date of the report. This data is formatted as a "TXT" file and can be open with Microsoft EXCEL. Use EXCEL to combine multiple register totals. Create historical report data and e-mail the reports to corporate or to district managers. Saves time and reduces transposition errors.
Use the CF Flash Card to save the entire register program before moving the register to a new venue where it can be reprogrammed in a flash with the new menu.
Apr 11, 2013 | Casio TE-2400 Electronic Cash Register
Hello I bought the Texas Instruments BA 2 plus,how to change 2 fin mode?there is no mode button.
The calculator has different worksheets.
To access TVM worksheet, press [2nd] and any TVM key : N, I/Y, PV, PMT or FV
To enter Amortization worksheet, press [2nd][AMORT]
To access Cash Flow (problem with unequal cash flows) Press CF, or NPV, or CPT or IRR
To access BOND worksheets press [2nd][BND]
For depreciation worksheets press [2nd][DPR]
For statistics, use [2nd][DATA], or [2nd][STAT].
There are other worksheets [2nd][Delta%], [2nd][DATE], [2nd][PROFIT], [2nd][BRKEVN],[2nd][MEMory].
These shortcuts will not get you anywhere if you do not consult the manual.
Jun 19, 2011 | Texas Instruments BA-II Plus Calculator
How to Calculate IRR?
To calculate IRR and NPVEnter the cash flows as follows, remembering the sign convention:
  • Clear previous data by pressing fXY and fCLX.
  • Enter the cash flow at time zero using # gPV [# CF0].
  • Enter subsequent cash flows using # gPMT [# CFj].
  • If a cash flow is repeated, enter the number of times it is repeated (including the first time you just entered) using # gFV [# Nj]. For example, three equal flows in a row would be entered as3 Nj.
  • When you have entered your last cash flow:
    • If you are calculating an NPV, enter your interest rate as # i (consistent with interval between cash flows) followed by fPV [NPV].
    • If you are calculating an IRR, enter fFV [IRR].
This is an excerpt from http://luna.pepperdine.edu/faculty/mkinsman/calculators/hp12c.html
I did not come up with this solution. Just found it for you.
Apr 04, 2011 | HP 12c Calculator
Hoe do I calculate the IRR (internal rate of return) on sharp EL531WH
Mar 30, 2011 | Sharp EL-531VB Calculator
Why do i get error 5 when trying to compute IRR
Error 5 indicates that no solution exists. In an IRR problem, the most likely cause is that there was not at least one sign change in the cash flow list.
Feb 03, 2011 | Texas Instruments BA-II Plus Calculator
Nov 21, 2008 | Texas Instruments BA-II Plus Calculator
Calculating out npv and irr
Are you using the finance app?
[APPS] [1] [ENTER]
For NPV, choose "7:npv("
Then use:
npv(interest rate, cost {cash flows}, {frequencies of cash flows})
For IRR, choose "8:irr("
Then use:
irr(interest rate, cost {cash flows}, {frequencies of cash flows})
Jul 25, 2008 | Texas Instruments BA-II Plus Calculator
Use the "FINANCE" app:
[APPS] [1] [ENTER]
for npv: select "7:NPV"
now you should get "npv(" on your screen.
use: npv(interest rate, cost {cash flows}, {frequencies of cash flows})
for irr: select "8: irr"
"irr(" will come up.
use: irr(interest rate, cost {cash flows}, {frequencies of cash flows})
May 13, 2008 | Texas Instruments TI-84 Plus Calculator
Sharp EL-738 Scientific Calculator Logo
954 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
