2300 Wurlitzer record lift arm won't lift record
Record holder drum will turn to correct record slot , but lift arm will not lift record (no movement).
early1234
  • 871 Answers
SOURCE: wurlitzer 1015 jukebox
wow. a jukebox.
ok, the record rises and plays BUT it doesnt finish the song and the arm rests but doesnt go back to its place thus making the system idle...
am i right?
ok, seems like the needle is the one at fault...
to replace the needle only means that you have to replace the whole cartridge as well It's a simple pull-out / push-in fit.
here is a link for the needles. link
here is for the cartridge link
as the way you described it, apparent solution would be to chagne the cartridge.
thanks for using fixya.
Posted on Apr 05, 2008
  • 211 Answers
SOURCE: Wurlitzer 3600 series
The microswitch at the base of the gripper arm is what enables the scan motor when the gripper is over the carousel. You will probably find that the small lever on the base of the tone arm is not clicking the microswitch properly.
Dave .
Posted on May 25, 2008
SOURCE: Wurlitzer arm keeps running
check the white plastic actuator next to the gear box, it is probably broken and not actuating the microswitch underneath it, these often fail, it may look ok,, but it actually is loose and the set screw on top of it is not clamping it to the rod.
Posted on Aug 25, 2008
  • 211 Answers
SOURCE: Wurlitzer model 556
Are you sure you mean 556? Sounds an odd model to me. The model number is on a black metal plate the size of a credit card on the back of the jukebox (usually).
Manuals can be found at www.victoryglass.com (USA) and The Jukebox Man in the UK.
Dave.
Posted on Nov 09, 2008
  • 211 Answers
SOURCE: Wurlitzer 1800 jukebox, plays record
If the normal cancel button is working then take a look at the tone arm trip switch, which probably just needs adjusting. You can test this by flicking it with your finger when a record is playing. If it works it just needs adjusting to trip at the right place on the record.
The trip switch is located behind the fat end of the cobra tone arm on the back side of the arch, so you get to it by taking the machine back door off.
Dave F.
Posted on Jun 25, 2009
Door won't open.
Hi Walter, this is called the Chucking arm and is made to hold the disc in place when the Pickup assembly is lifted into place. Often times an analysis will show you that the arm is not being lifted due to a lack of grease (Lubrication in the door mechanism) or that the drive parts- motor and a belt are not transferring the energy well enough. I would start with a belt of the correct size and then it may be fixed.
Dec 12, 2012 | Audio Players & Recorders
Wurlitzer one more time. no sound and record will not eject
There is a switch just under the tone arm. When the tone arm moves towards the centre it slowly pushes two copper strips together. When they meet it starts the motor to eject the record. If you can't Cancel the record with the cancel button then that is a different problem, otherwise you can adjust the trip switch by inserting a 7mm spanner down the hole to the right of the tone arm post.
Apr 30, 2012 | Wurlitzer Jukebox 1015 One More Time...
Aiwa turntable px-e860: Hi, I've inherited this timetable from a friend and it's worked fine until recently but now here's the problem: if I push start, the arm lifts up, moves to the record...
Hi, I;m not familiar with that exact model however the problem you are describing is commonly caused by the automatic operation at some point not being allowed to complete its full operation. Ie the tonearm has been returned manually to its rest position before reaching the end of the record. Try this. With the player not powered up lift the tonearm across to the record run off groove and sit it there. You may feel some resistance which is normal as the mech has to eswt itself. Now turn on the power and turntable. The arm should automatically return from there to its rest. Try auto operation after that. Let me know how you go. Cheers John. styluscity@gmail.com
Oct 10, 2011 | Aiwa PX-E860 Turntable
I have a Wurlitzer one more time. vinyl record jukebox.. I moved ( or turned) the turn arm forward to clean behind it and now the records will start to play and return to the changer. How do I adjust it.
Look up underneath the mechanism. You've moved the tone arm with respect to the bracket beneath it (which closes the trip switch). Select a record...turn the machine off...then look up under whilst someone moves the tone arm and you will see what it is attched to. If you are lucky you can hold that tight and gently move the arm back the other way a bit.
Jul 28, 2011 | Wurlitzer Jukebox 1015 One More Time...
45 (record) Jukebox. While playing the jukebox was changing records, the arm lifted the record slightly off the turntable. the credits and song selection would not clear off the readout, even after...
Have you checked all the fuses or circuit breakers on the jukebox?
Are all the power supply led's lit?
Make sure that all the connection plugs into the boards are fully seated and making good connections.
After checking the above if the fault remains you will need to contact a Wurlitzer service engineer.
Regards
Alan Hood
ami-man
UK
May 23, 2011 | Wurlitzer Jukebox 1015 One More Time...
I have a Brother HL-5250DN printer and trying to replace the Paper Feed pickup roller assembly. Can you tell me how to take the old part out or send a diagram? Thanks, Sherry
Paper feeding kit for MP tray
(1) Disconnect the AC cord from the Printer.
(2) Press the front cover release button.
(3) Open the Front cover.
(4) Remove the Drum/toner ASSY.
Open the MP feed frame cover. (6) Remove the Holder bearing MP. Lift up the Lift arm MP to release it from the Pin of the MP roller holder ASSY. (8) Slide the MP roller holder ASSY to the direction of the arrow 8a and put it up to remove. Fig. 3-77 (9) Turn the back side of the Separation pad ASSY MP to the direction of the arrow 9a and put it up to remove. Fig. 3-78 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame Lift arm MP 7 8a 8b MP feed frame MP frame 9b 9a
(1) Put the Hook of the Separation pad ASSY MP into the MP feed frame and pull down the Separation pad ASSY MP to the direction of the arrow 1b until it is locked. Fig. 3-79 (2) Lift up the Lift arm MP and put the MP roller holder ASSY into the MP feed frame. Put the Pin of the MP roller holder ASSY into the hole of the Lift arm MP. Fig. 3-80 Separation pad ASSY MP MP roller holder ASSY Pin MP feed frame MP frame MP feed frame Lift arm MP
(3) Put the Holder bearing MP into the MP feed frame and turn the Holder bearing MP to the direction of the arrow 3c to lock. (4) Close the MP feed frame cover. Holder bearing MP Hook MP feed frame cover Front cover MP feed frame 3a 3b 3c MP feed frame(5) Install the Drum/toner ASSY into the Printer. (6) Close the Front cover. (7) Connect the AC cord into the Printer. Printer AC cord Drum /toner ASSY Front cover .
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 18, 2011 | Brother HL 5250DN Laser Printer
JUKEBOX WAS SHUT OFF WITHOUT REJECTING ALL THE RECORDS.
What exactly do you mean by "shut off before all the 45's were rejected" ? The mech only load one record at a time, either from the left or right side of the carousel. If the power was shut off before a record unloaded from the turntable, you can manually return the mech to the start position. Do this by getting in to the back of the juke. on the upper right, near the top of the deck, there is a motor. There should be a little white gear coming from the bottom of it. I am assuming if you look in the middle of the mech, you will see a cam with a lobe on one side of it. Turning the white gear will advance the mech adn turn the cam counter clockwise. As the lobe on the cam nears the front of the mech, the record lifting arms should pull down clear of the carousel and return the record to the carousel. Stop turning the gear when the lobe of the cam has driven the lifting arms downward. Inspect your pin bank and push down any "popped" pins. This will prevent the juke from trying to start when you turn it back on.
Hope this helps
Jan 16, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1800 jukebox, plays record but at end the arm does not lift so record does not reject until I press the reset button and then it works.
Dave F.
Nov 29, 2008 | Wurlitzer Jukebox 1015 One More Time...
Record Changer Arm
When the carousel reaches the correct count, the computer sends a signal to the gripper motor to start it. You could have a bad motor or a bad computer. But!....if the little switch at the front of the machine is in the off position (Gripper motor On/Off) that will give exactly the same effect. It's easy to knock Off when you are loading CDs.
Oct 02, 2008 | Wurlitzer Jukebox 1015 One More Time...
51 people viewed this question
 Grubhead
Grubhead
