Question about Reddy Heater-30-55,000 BTU Variable
Propane reddy heater shuts off
I have a 65,000-100,000 btu reddy heater. To start the heater, you plug it in, hold down the adjustible igniter button until unit lights,then hold for about 30 seconds and unit should continue to run. I ran this unit yesterday and had to hold the button for about 5-6 minutes before it would run on its own. Other days, it would light within the 30 seconds and run sometimes for 5-10 minutes, shut of. It would restart immediately if you repeated the above procedure. What is wrong?? I understand this information is free. Thank you.
  • 92 Answers
Either a bad ignitor or gloplug.
Posted on Jan 23, 2009
2 Suggested Answers
  • 188 Answers
SOURCE: 150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Posted on Jan 28, 2010
VERY GOOD "spark" HOOKED UP YOU CAN SMELL THE GAS WHEN YOU HOLD THE BUTTON IN IT WILL IGNITE THE GAS WHEN THE FAN OFF BUT DOES NOT
Possible weak gas flow to igniter may require adjustment, have a qualified gas technician check it.
press the helpful button
Jan 08, 2016 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
L.P. Propane Heater not staying lit Fairly new heater (Reddy) 30,000 BTU Piezo Igniter not functioning use long match and unit fires nice. plug in /turn on blower good once I let go of primer valve button...
Sounds like you have a bad gas hold on valve. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Jul 30, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
I have a 35000 btu propane reddy heater that wont ignite .
the thermocouple is bad.it needs to send a signal to the gas valve to say it's okay to stay running.replace it and the problem should go away.if not let me know
Mar 13, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-30-55,000 BTU Variable Logo
433 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
