Question about Nokia C3 Cell Phone
My nokia c3 shows a white screen for 2-5 seconds and it writes menu at the bottom of the white screen after that it goes to the normal screen is this normal
When i switch on my nokia c3, the welcome tone comes up, and followed by a blank white screen written menu at the moment.this happen for 3 to 5 seconds. and it the proceded to the normal screen. is the white screen a normal thing. i have just bought it 2 weeks ago.so i am afraid something could be wrong please help
  •  george
    george Mar 18, 2014
    Don't worry.. it is normal for C3 to start like this :)
White screen is normallll.it happens with every nokiac3.its just normal nothing to be scared off.
Posted on Jan 06, 2013
Raysagem
  • 1017 Answers
SOURCE: NOKIA N95 BLANK SCREEN
It must be a connection problem, to the LCD, or the light is not working.
Can only be sorted by looking at it really.
Back to Telstra I'm afraid. If it's new let them sort it out, if it's not try a reset take the sim card out first then input this code *#7780# (Best to use this code as a last resort)
Give it time to work.
Posted on Jan 14, 2008
  • 204 Answers
SOURCE: My nokia x 3 switches
For this you need to flash your handset(if it is under warranty contact the service center)
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Thank you
Don't Forget To Rate
Posted on Jan 25, 2011
prashant2012
  • 1127 Answers
SOURCE: Dear sir my nokia 2690
Hi
Your phone OS is corrupt, install the new OS then it will work..
Posted on Jun 01, 2011
  • 2069 Answers
SOURCE: my phone (nokia 5800) is frozen
his phone is s60 platform. so, do this first.
remove simcard, switch on and if it loads fully, enter *#7370# f and 12345 when prompted for code.
if it hangs still, follow this
1. Turn off
2. Press and hold 3 keys (green)+(Red)+(camera) together
3. Turn on phone but don't release 3 keys
4. Wait until show shaking hands
5. Now your phone will format!!
Regards
Posted on Dec 07, 2009
  • 1257 Answers
SOURCE: N72 screen goes blank
Best Solution :
RESETTING PHONE BY NOKIA SECRET CODES (steps 1 and 2)
1st step : SOFT RESETTING NOKIA MOBILE
Take backups of ur phone books,calender and others, then simply enter the code
*#7780#
2nd step : HARD RESETTING BY CODE
Just enter the code-
*#7370#
Then it asks for security code enter ur security code whose deafault value is 12345
NOTE:
The battery must be full or the charger has to be connected to the phone so that it does not run out of power and make the phone unusable.
Take backup of the contacts and other important data in MMC .
FLASHING
3rd step :FLASHING : ANOTHER METHOD FOR HARD FULL FORMATTING
This step is known as flashing of phone. Always do this step at last (after 1st 2 steps are over and u are not successfull)
1. Make sure you phone is fully charged. (At minimum 3/4 of bettery should be left)
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your mobile phone.
4. Press and hold these three keys together
-Green dial key,-Star key (*)-Three key (3)
then press the power on/off to swtich on the phone.
Do not let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your mobile will now be at its original factory settings (It will reach the same state as that in when you purchased it).
>To update firmware
install pc suite as well as nokia software updater.
now attach your mobile to pc with data cable .Not through bluetooth connection or infrared connection..
Posted on Apr 30, 2008
My phone scrren show white and on screen write nokia then not satart only show nokia and this problem again occure when i m re insetr memory card
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Oct 06, 2012 | Nokia 5800 XpressMusic Smartphone
White screen only on nokia C3
sounds like the screen is gone out or broken ,,, did u get any water on it or in it ?
Aug 30, 2012 | Nokia C3 Cell Phone
My Nokia c3 won't turn on
5.Wait 10 seconds.
Step
Thanks
Aug 27, 2012 | Nokia C3 Cell Phone
My nokia c3 got wet and i turned it on its shows only white screen is there a high chance it will go back to normal?
You should have turn if off imediately and removed the battery and then dried out your cell phone for several days in a warm dry place.
Most likely the cell phone is damaged, you maybe lucky, remove the battery and dry your cell phone for several days, then see if it works properly.
If it does not work, I suggest you put your money towards a new cell phone instead of getting it repaired as the cost of repair may not be a cost effective solution.
Apr 18, 2012 | Nokia C3 Cell Phone
Nokia 6300 Memory Store Not Ready Then White Screen Appears
Bro. . Goto any mobile software shop and flash your mobile. This is software problem
Feb 25, 2012 | Nokia 6300 Cellular Phone
Nokia c3 keeps freezin when i try to acsess my memory card nd when i turn it off it switces on but shows a blank screen
HelloFirst of all try to reduce the data which is stored in your memory card.Sometimes this problem occur due to over usage of memory.Secondly,delete some data which is stored in your phone memory.Even the problem still persist insert another memory card and try it.good luck Thanks for visiting fixya.
Dec 19, 2011 | Nokia C3 Cell Phone
Nokia c3 how to make a signature on messsage
1. Open your Nokia . Go to the main menu. The buttonfor the main menu is at the top right of your phone, just underneath thescreen. 2. Move the "Right" arrow until you reach"Messaging." 3. Move the "Down" arrow until you reach"Message Settings." Press the "Center" button to enter thismenu. 4. Choose "Signature" from this menu andpush the "Center" button again. Move the "Down" arrow untilyou reach "Custom," then push the "Center" button. Thiswill open the Signature menu. 5. Write your text signature in the text box on theSignature menu. When you are done typing, press the center button again andthis signature will show in every text you send.
May 23, 2011 | Cell Phones
Nokia C3 Cell Phone Logo
958 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
