ERROR 2753 TRYING TO UNINSTALL SILVERLIGHT - Office Equipment & Supplies
2 Suggested Answers
  • 49 Answers
SOURCE: j6480 fatal error
solution 1>
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Posted on Dec 14, 2009
How can get netflix to play on my labtop?
  1. Clear browser cookies
    Your browser may be referencing an out-dated or corrupted setting in the cookie file.
    1. Go to netflix.com/clearcookies to clear the Netflix cookie. This will sign you out of Netflix.com.
    2. Select Netflix Home, then Member Sign In to log back in and play your movie or TV show again.
  2. Restart your browser
    Sometimes restarting your browser can clear this issue.
    • Quit your browser, restart it, and play your movie or TV show again.
  3. Try another browser
    A browser extension, plug-in or add-on may be causing this error. Try playing your movie or TV show in another browser.
    • If you're unable to play your movie or TV show in multiple browsers, there may be a problem with the Silverlight Plug-in used by Netflix.com.
try this
You may be running an outdated version of the Silverlight plug-in, or the plug-in may have become corrupted.
To uninstall the Silverlight plug-in:Windows 8
  1. Quit all open browsers - including this window! You may want to print the following steps.
  2. Swipe from the right edge of the screen, then tap Settings. (If you're using a mouse, point to the lower-right corner of the screen, then clickSettings.)
  3. Select Control Panel
  4. Underneath Programs, select Uninstall a program.
  5. Locate and select Microsoft Silverlight
  6. Select Uninstall
Windows 7/Vista
  2. Click on the Start Button
  4. Select Programs & Features
  6. Select Uninstall
Windows XP
  4. Select Add or Remove Programs
  6. Click Remove
To install the latest version of the Silverlight plug-in:
  1. Navigate to the Watch Instantly home page and click play on any title.
  2. Follow the prompts to download and Install Silverlight on Your Windows PC.
if your using Firefox
From the black screen:
  1. Click the orange Firefox button in the upper-left corner of the browser window.
  2. Select Options.
  3. Make sure there is a check mark next to Add-On Bar.
  4. A bar should appear along the bottom of the browser window. In the bottom left corner of the bar, click the red stop sign.
  5. Click Disable on movies.netflix.com.
  6. Press the back arrow to return to the Instantly Watch home page.
  7. Try playing your movie or TV show again.
If disabling Ad Blocker causes you to see ads when streaming from Netflix, please see our Ads and Pop-ups When Streaming to Your PC or Macarticle.
Jul 19, 2014 | HP Computers & Internet
Netflix error 1810
Try clearing data on browser, each are different so try googling steps to clean or clear data, if this does not work
Silverlight installed to play netflix on computers & laptops might be the problem.
The Silverlight plugin, which Netflix uses to play movies and TV shows on your computer.
This error is usually caused by one of three things:
  • A computer setting preventing Silverlight from storing files it needs to play your movie or TV show
  • An issue with the Silverlight plugin itself
  • An issue with the content you're trying to play.
  • Try re-installing uninstalling then reinstalling silverlight.
Hope it works for you, best of luck.
Jun 22, 2014 | Netflix Computers & Internet
Watch netflix
Make sure that you are running the latest version of Silverlight, first uninstall any other version from your Control Panel > Programs and Features and then try to install it again. If you still get problems with the installation then run the Silverlight cleanup from http://download.microsoft.com/download/6/C/9/6C970550-32AB-4235-9CDD-7FC9DD848BBB/silverlight.diagcab
If after running the Microsft FixIt you still have issues then reply here with the exact error messages you get.
Oct 15, 2013 | Sony VAIO Computers & Internet
I can't get netflix to work. error message N8161
2/24/2013 Netflix Error Code N8161, Protection Error Problem became a recent problem on 3 of my five XP computers, one Home Edition, the balance are XP Pro. After trying uninstalling and re-installing Silverlight, all the adobe products and Media Player I finally resolved the problem by uninstalling the current Silverlight 5, restarting the PC and then and installing old version Silverlight 4. I had to search hard to find a site that both still offered it and that I trusted. Just don't let Microsoft Updates or Netflix demand to install Silver light temp you to update. Chrome insists on the Silverlight plug in update - DON'T DO IT. Firefox and IE8 seem OK, at least for now.
Feb 20, 2013 | Microsoft Windows XP Professional
I have windows xp and i am unable to install silverlight. it keeps telling me i need to uninstall the old silverlight but when i try it tells me it cannot find the file to remove it. any suggestions? i...
It sounds like you have deleted the program files instead of uninstalling it. go to www.filehippo.com and there you may get the same version of silverlight and install it. then uninstall it from the add remove menu.
Dec 02, 2012 | Computers & Internet
I can not uninstall silverlight
How to uninstall Silverlight Bellow are the steps to follow to uninstall the silverlight
1. Go to Start menu.
2. Go to Control Panel
3. Open Add or Remove programs.
4. Choose Microsoft Silverlight in Add Remove Programs Dialog box.
5. Click on Remove
6. It asks you for the confirmation.
7. Click YES to Uninstall the Silverlight
Aug 12, 2012 | Microsoft Windows XP Home Edition
Netflix Player Error 1001
I tried everything to fix the 1001 error, and finally fixed it by simply uninstalling silverlight, then RUNNING THE INSTALLER AS ADMINISTRATOR. Boom.
Apr 29, 2012 | Netflix
Soda pdf software is not uninstalled after 15 days (free) and shows error no. 2753
go to control panel then go to programs uninstall programs then dobble click on it then scroll down to the desierd program and unninstall
Aug 16, 2011 | LULU Software Soda PDF Max
When I try and uninstall advanquest system suite 11 I keep getting an internal system error 2753. How do I correct this
Reinstall the software.
Then uninstall the software, and it should correctly uninstall.
Jun 04, 2011 | Computers & Internet
I'm trying to reinstall Novabackup version 10 after reinstalling windows XP. I almost immediately get the message announcing an unexpected error and citing error 2753. How can I resolve this?
hi,
Error 2753 is caused by missing system files or broken system registry structures. This is a critical sign of an unstable system that is typically caused by improper maintenance of the computer.
How to Repair Error Code 2753
RegCure is a Microsoft Windows tool designed to repair code 2753 problems & errors.
Dec 01, 2009 | Computers & Internet
927 people viewed this question
jasbo
jasbo
