Question about Nintendo Wii U
My wii u says error 165-3423 - Nintendo Wii U
Wii disc error
If you have the wii disc error that might be because of error code 32004. It could be possibly error code 32004. If you have internet on the Wii and if so if you Wii format it again then you'll see this problem because the Wii update asks you to update it. In the update message it said at least,"Not updating this could cause future game disk problems when playing games." Im not sure how to really fix it but this just the problem. Solution has to do with you either hacking the wii or certain cases. Buy a new Wii or see if you can fix it using Nintendos support.
Dec 02, 2012 | Nintendo Wii Console
Tip
Nintendo Wii Error Code 51330 usually indicates that the WEP/WPA key you set on...
<span><span style="font-weight: bold;">Nintendo Wii Error Code 51330</span> usually indicates that the <span style="font-weight: bold;">WEP/WPA</span> key you set on your Wii is not the correct one to gain access to your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>router</span></a>. <br /><br />When you setup a router for wireless internet, you usually set a WEP key or by default one is set. This is basically a <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>security</span></a> key(<span style="font-weight: bold;">password</span>) that you set so any device that wants to use your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>internet</span></a> has to enter correctly in order to gain access.<br /><br />If you know your router security key, go into your <span style="font-weight: bold;">Wii network settings</span> and make sure it is entered correctly. Click <a href="/../support/r9198848-connect_nintendo_wii_internet">here</a> to read my tech article on how to configure your Wii's network settings. <br /><br />If you do not know the security key of your router, then read my other article by clicking <a href="/../support/r9359087-find_wep_key_router_router_security">here</a>. This article will go over <span style="font-weight: bold;">how to find the router security key</span> or if need be, set one.<br /><br />Be sure to check out my other <span style="font-weight: bold;">Tips</span> by clicking on my profile name and then clicking "<span style="font-weight: bold;">Tips</span>" at the top left. <br /><br />Regards,<br />G33k<br /><br /><br /><br /><br /><br /><br /><span>Keywords</span><br style="font-weight: bold;" /></span><span style="font-weight: bold;">Nintendo Wii Error Code 51330, error </span><span style="font-weight: bold;">51330, Wii </span><span style="font-weight: bold;">51330, Wii error </span><span style="font-weight: bold;">51330, Wii network settings, can't connect Wii to netflix, Wii netflix, Nintendo error code </span><span style="font-weight: bold;">51330, Wii code </span><span style="font-weight: bold;">51330</span>
on Jun 14, 2011 | Nintendo Wii Console
I am having an error code 32017
Error Code: 32017 There appears to be an issue with updating your Wii console.
  1. Try and perform another Wii System Update on your Wii console (how to).
  2. If you attempt another Wii System Update and still receive this error code, please call 1-800-255-3700 so that we may assist you further.
Aug 09, 2010 | Nintendo Wii Console
Error code 32017 keeps coming up on my wii console. i can still connect to the internet on my wii and play games but whenever i put in super smash bros it requires a system update. it will begin but never...
Mar 03, 2010 | Nintendo Wii Console
Error code 32017
Nov 12, 2009 | Nintendo Wii Console
Disc Error
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide....
Apr 07, 2009 | Nintendo Wii Console
Wii won't connect to Internet. Error code is 051330
When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.
Dec 25, 2008 | Nintendo Wii Console
Error occured while loading disc
Aug 09, 2008 | Nintendo Wii Console
NINTENDO WII
Try this link it's nintendo's tech support:
www.nintendo.com/consumer/systems/wii/en_na/errors/index.jsp
Or this slightly less helpful database of errors:
www.wiierror.com/
May 06, 2008 | Nintendo Wii Console
Nintendo Wii U Logo
363 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
