Question about Car Audio & Video
My power protection light is red on DX500.1 kicker amp?
Me and a friend were listening to music and I just bought new amp and 2 subwoofers (JL W0V3) and all of a sudden my subs stopped playing. Not moving at all. My power protection light is red and my fuses are fine. I went to change stations and my door speakers made a thumping/popping noise... So I turned my truck off and when it shut off my door speakers made same noise. It only makes noise when radio is on though. Also I looked at the light and it dims and brightens. But this only dims when its switched to 12v or DC. when I switch it to the audio option is completely shuts off. What could this be? Also I hooked up my subs to friends amp (kicker 250.1) and they work fine. Subs work fine.
Jexx
  • 148 Answers
SOURCE: p3001 amp may be fried
Check this out: http://www.techlore.com/article/14696/
Posted on Aug 17, 2006
GARYDALE
  • 15 Answers
SOURCE: Amp makes subs pop
It sounds like your amp chip has gone bad, here is some thing you can try turn on your unit then start tapping on top of with your finger not hard see if the any of the pops matches your finger taps some times when the chip starts to go out it well act like that.
Posted on Nov 06, 2006
  • 109 Answers
SOURCE: My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
Posted on Jun 24, 2008
  • 14 Answers
SOURCE: i think ma kicker kx1200.1 amp is blown or ma kicker L7 are gone
that would be the amp. sorry to say. when a wire crosses over, it sends a shock through the amp, there are a few things to try just to see if you fried the amp. the first thing to try is to move your ground to a different location. second thing to look at would be the fuses. alot of times the fuses will blow at the slightest shock. the amp will still turn on if you have an amp with 2 fuses, it just wont be getting all the power it needs, which could be causing your problem. also, it is worth the hour and a half to mount everything down in your vehicle. you might check the kicker website, because i have herd rumors that kicker offers a lifetime warranty on almost all of their products. best of luck, and i hope you didnt fry your amp.
Posted on May 01, 2009
  • 123 Answers
SOURCE: JL Audio 500/1 Amplifier "Thermal" light flashing
pooi
Posted on Jul 25, 2009
A kicker 600.1 wired to a jl w7 10" sub? Will that work?
The kicker 600.1 provides 600 watts at 2 ohms and 300 watts at 4 ohms the 10" JL W7 has 2 1.5 ohm voice coils so you will have to wire them in series. Take about 1.5 feet of 14 gauge wire and connect the positive of one voice coil to the negative of the other then the positive and negative that are left go to the amp. Your impedance should be 3 ohms and that amp should work just fine.
Jan 14, 2016 | Kicker Car Audio & Video
I have 2 15 inch kicker l7s duel 2 ohm in a built to specs slot port i need an amp that will power them what should i get
this guy know jl amps are ONLY 1.5 - 4 ohm stable? won`t 1 ohm send amp into protection with thermal indicator lit up like the northern star?
Sep 26, 2012 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
What would be the right wiring on a cvr 12 to 4 ohms i am running a hifonics 2000 class D thanx for the help
Assuming that you have a 4 Ohm Dual Voice Coil (DVC) sub, you should wire it in parallel for more output. Solid red connects to red with white dot, and goes from solid red to amp positive (+). Solid black connects to black with white dot, and goes from white dot to amp negative (-). For a good diagram, go to this link: http://kicker.com/dvc_wiring
Apr 25, 2010 | Jl Audio CVR12 Kicker 12" CompVR Series...
I hooked up my two 10 inch JL Audio W3v2 2 ohms to a mono JL Audio 500.1 amp and the subs will not work. I have the subs wired in a series. I then hooked them up to my friends amp and the subs worked. Any...
try one at a time. if they work then try hooking them up differently. if none work, then check to see that your amp is not in protect mode. if amp is ok, then check to make sure you have your rcas connected to your amp. in other words, re-check all your wiring. if still nothing, try your amp on your friends car and vise versa.
Apr 01, 2010 | Jl Audio 10W3v2 Car Subwoofer
Amplifier causes subwoofer to emit super high pitched sound
YOU NEED NO CHACK THE GROUND CABLE SOMETIMES WITH THE SAME POWER THAT THE AMP NEED START TO BURN THE CABLES AND IF THE GAUGE OF THE CABLE IS NOT THE CORRECT CAUSES THAT PROBLEM TRY TO PUT 2 GROUND CABLES (GREY) IN DIFERENT PLACES AND IT MUST WORK!
Feb 10, 2010 | Sony XM-475GSX Car Audio Amplifier
I wonder if i get two kicker cvx 10 can be push by jl audio 500.1
It can but it'd be a waste for your subs. 1 of those by itself will handle that amp. it'll push them just not really hard, i'd recommend an upgrade to a 1100-1200 watt rms amp if you're gonna run 2 cvx's. if you only run one sub that amp'll work well...
Oct 08, 2009 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
Jul 12, 2009 | Jl Audio Slash 300/2 Car Audio Amplifier
What would be a better amp for my jl audio 12in w6v2
its not the amps my dude ur ohm loading is wrong if u have a 4 ohm stabled amp n ur speakers r 2 ohms naw thats not gonna fly caus it cant put out what ur asking 4 so u need 2 reload ur subs try this link http://www.bcae1.com/spkrmlti.htm this should help u out n save u money
Jun 17, 2009 | Jl Audio 12W6v2 Car Subwoofer
Best amp for Kicker Sub
Hello dalex7,
The Kicker 08ZX400.1 would be a great amp for your subwoofer. It will work into a 4ohm load with no problems.
But you can buy an amp with more power, looks better, has a smaller footprint, and cost less than the 400.1. I'd look at the Alpine MRP-M500. Take a look at it here at Crutchfield. The M500 is also easy to install, runs cool, and is very efficient.
Hope this helps.
May 21, 2009 | Jl Audio CVR12 Kicker 12" CompVR Series...
500/1 v2 and one kicker VS12L7
It will work fine. This amp is stable to 1.5 Ohms, but is designed to put out about the same amount of power at 2 or 4 Ohms (unique).
Feb 03, 2008 | Jl Audio 500/1 Car Audio Amplifier
Car Audio & Video Logo
107 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
