Question about Maytag PYE2300AY Electric Dryer
Maytag performa runs no heat how do I access the heating element?
The drum spins and blows air but there is no heat
  • Maytag Master
  • 8,220 Answers
Well if it runs then the fuse is ok so what you need to do is pop the top and check the high limit thermostst and heating element located at the rear of the machine. The top on most of these machines comes up easilty if you use a putty knife or five in one. Be sure to disconect the power source. maytag performa runs no heat how do I access the h - a12fee1.jpg
Posted on Jan 19, 2009
Heat is blowing out but the drum is not spining
You broughtke the belt of drum wont turn you might take the dryer apart to make sure the idler pulley is spinning free also. They sometimes get tight and burn the belt up.
Apr 10, 2015 | Avanti D110 Electric Portable Dryer
Dryer heats up and blows air but is not spinning. What's up?
The problem most likely is a stretched or broken belt. This will have to be replaced to restore proper operation.
Feb 28, 2015 | Dryers
Drum not spinning
Probably a broken belt or it came off the drive roller. Can you hear the motor running? Dryers are very simple, just a big drum with a belt and motor to spin it and a heating element with a thermostat for temp. Finally a fan to blow air which frequently gets clogged with lint. You can take the front off most dryers and see everything you need. Unplug it first.
Apr 06, 2014 | Dryers
Whorlpool dryer timer
I worked ona wp electric dryer not long ago with a heat problem.
Take a look:
DRYER NO HEAT
Jul 08, 2012 | Whirlpool Dryers
Doesn't spin but it heats and blows air
probably the belt snapped that spins the drum
Feb 01, 2012 | Roper RES7646KQ Electric Dryer
Dryer is not heating, only blowing cool air
Its best to take it to an appliance repair man. This is usually an electrical problem related the the board or the relays behind the control panel. Beware though, sometimes its cheaper to buy a new one than fix the old. Hope this helps.
Sep 13, 2009 | Uniden Cordless Phone
Heat Element is working and drum spins, but no air is blowing?
First make sure that the dryer is vented properly, then check the blower wheel. A common problem is for the center of the blower wheel to get rounded out through wear and tear, allowing the blower wheel to spin on the shaft, thus not spinning at the same speed as the motor. I will attach a photo for reference. Sorry for your trouble and I hope this helped. Best wishes.
Sep 07, 2009 | Maytag MDE308DAYW Electric Dryer
My kenmore dryer is blowing out cold air
Make sure that both poles of your circuit are live - An electric dryer uses 220 volts to the heating element, but taps into only one pole (110 volt) for the motor that spins the drum. Check your circuit breaker to make sure that neither pole has tripped.
Jun 26, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Dryer working but not blowing hot air
it sound like the heating element. look to see if it is broken
May 08, 2009 | Bosch Dryers
Drum won't spin
The most likely cause is a broken belt. Of course there are other possibilities, but start with the most likely. If you hear the motor running and if it's blowing air out the exhaust vent, then you probably need a new drive belt to spin the drum.
Nov 28, 2008 | Dryers
Maytag PYE2300AY Electric Dryer Logo
136 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
