Fagor Innovation washing machine AA - hatch will not open - how to open ?
Hatch will not open - inside are washed clothes - how to open ?
SOURCE: Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
Posted on Sep 21, 2008
  • 566 Answers
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
Posted on Feb 16, 2009
  • 1294 Answers
SOURCE: washing machine stops mid-cycle and full of water
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
Master_Tech
  • 770 Answers
did that work?? you may have a bad or stuck door lock
Posted on Jan 24, 2008
TheMobilian
  • 8220 Answers
SOURCE: sumsung J845 front load washing machine cannot open the door
What you need is a Samsung service repair manual
Posted on Mar 03, 2010
Testimonial: "Thank you for the manual, it helps me take off the top cover, but I am still in the same problem. But thank you all the same"
My Fagor innovation washing machine is currently disabled by the child lock symbol we did not apply this how can it be reversed
STARTING UP AND
6
BLOCK FUNCTION SELECTION
Start/pause button
a To start up the washing machine you
have to press the start/pause button.
The minutes remaining until the end of
washing and drying will appear on the
display at all times.
Block function selection
The lock function ensures that the programme
will not be affected if any buttons are pressed.
It is used when children could press the
buttons, etc.
The block function should be activated after
the wash programme has been selected
together with all its options.
Activating the block function
a The block function is activated by
pressing the start/pause button and
holding it down for at least 3 seconds.
The display will show if it is activated.
Deactivating the block function
b The block function is cancelled when
the wash programme comes to an end.
If you want to deactivate the block
function before the end of the
programme, you have to hold the start
button down again for at least 3 seconds.
After 3 seconds, the block function
indicator will disappear from the display,
and it will go into pause status.
The ON/OFF button does not cancel
the block function
Apr 14, 2015 | Fagor Washing Machines
No water coming
Check if the water tap is on and make sure the used water inside the washing machine is already drifted.
May 20, 2014 | Fagor FAS3612 Washer
Fagor select fe-1046 manual
Does anyone have a manual or know where i can find a manual for a Fagor Select FU-1046 washing machine
May 17, 2012 | Washing Machines
Fagor Elegance FE 538 washing machine. A copy of operating manual pl.
i dont know how to use that machine.. FAGOR Elegant FE-538 ..
neet guide or manual ....
Jun 15, 2011 | Washing Machines
Hi my fagor washing machine has a very nasty smell coming from inside the drum hav tried cleaning out filter but still the smell is there is there anything i can do to clean out the inside of the drum etc...
Se lava a roupa a baixa temperatura e utilizando detergente em pó e se a maquina já for velha é natural que se acumule detritos na traseira da cruzeta do tambor e leve a emitir mau cheiro, para essa situação à que desmontar o conjunto tina tambor para retirar os detritos acumulados no interior.
Apr 29, 2011 | Fagor Washing Machines
We have a fagor washing machine (model - FU-1148-IT) and cannot find a user manual for it anywhere, please help as we have a baby and it's not cleaning his clothes on the setting we are using
Have it on Number 3 for the wash, 5 is the best spin. It gets smelly quite quickly, so wash the drawer alot, and get the mould out from ALL the inside of teh drawer compartment, and wash it at 90 with washing machine service powder (Asda 3.50!)
Nov 26, 2010 | Fagor Washing Machines
Error F08 on a fagor washing machine FU-6146
F08 on my FAGOR means a new motor is required we've had 3 failed motors in the past 2 years , total rubbish machine , would never buy FAGOR again . Mr M Freeman.
Jul 14, 2009 | Washing Machines
Question: FAGOR FE-1158 ELEGANCE WASH MACHINE
We have a 1 yr old Bosch wash machine w/o problems till now. We have a problem with the centrifuge program-it does not start, although the machine can spin slowly. Is it a motor problem or a problem with the programmer? Thanx for the help in advance!
Oct 16, 2008 | Washing Machines
Washing machine stops mid-cycle and full of water
Jan 06, 2008 | Washing Machines
Washing Machines Logo
1,144 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
