Question about U-Line 15R Compact Refrigerator
Uline 15RBK not cooling
Our 15RKB under counter refrigerator has stopped cooling. It was purchased in 2003. It runs but doesn't cool. Can this be repaired reasonably?
  • 163 Answers
Hi!! make sure that the inside evaporator fan is on and that the compressor and condensor fan motor is on. if they are all on then you have a seal system leak of refrigerant..Good luck..
Posted on Jan 20, 2009
Uline under the counter icemaker not making ice. Fed from RO water and had filters replaced to help but didnt. All is running fine, but not making ice. Dups one tray every 12 hours then stops
Is the condenser fan running? Is the condenser clean? (condenser is the "radiator like" coil outside of the ice box. It cools the hot refrigerant.
Sep 07, 2012 | U-Line Icemaker
Hotpoint Refrigerator constantly runs and doesn't shut off normally.
Sounds like the thermostat is not working that is what tells the compressor it is cold enough shut off.
May 17, 2012 | Hotpoint Refrigerators
Leak under freezer portion
Check out these tips...they can help you figure out what is going wrong with your refrigerato
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 14, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Refrigerator installed under counter and stopped cooling
possible bad compressor. check amp draw of compressor. tech info is usally on model # tag on amps. If amps close to recommendation you could need a start kit but more than likly a compressor .
Mar 05, 2010 | Refrigerators
Wiring digram for under counter uline ice maker
It is on the back of the machine, if you have clear ice maker, it may be on the back of the front plate.
Jan 20, 2010 | U-Line Refrigerator Ice Maker
My uline refrigerator won't get cold at all. Was
If the refrigeration motor is running and it is not getting cold then it probably is low on freon the gas that is used for refrigeration. Also if the motor only runs for a few minutes then stops it is possible that the cold control is bad, This is a common problem in refrigerators and can be fixed by replacing the control. First you must determine that the motor is in fact running. If the motor is running the motor should feel warm to the touch after 10 to 20 minutes of operation, and you should feel some cooling in the refrigerator on the cooling or evaporator coil. If the motor is running and getting warm or hot and you feel no or very little cooling then it is in fact ether low on freon or a component in the refrigeration system is malfunctioning. Freon can only be replaced by a certified technician.
Oct 07, 2009 | U-Line ?chelon 2175RB-00
The door to my under the counter uline frig/icemaker doesnt shut good..It wont stay on the bottom hinge..
The hole on the bottom of the door might be cracked. What model is it? you might need a bushing for the door.
Mar 30, 2009 | U-Line Uline Origins Series...
REFRIGERATOR MOTOR CONTINUES TO RUN AND WATER IS LEAKING.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
u
Mar 22, 2009 | Whirlpool ET8CHEXSQ Dryer
Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Nov 04, 2008 | U-Line Icemaker
U-Line 15R Compact Refrigerator Logo
299 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
