Question about Garden
Looking for a carberatorkit (diafram) for a 250 super mcculloch chainsaw
    Sergeant:
  • 391 Answers
Mike:
I would remove the carb and take it to a small engine repair shop... They will probably have the rebuild kit. They'll need to get the numbers embossed on the carburetor to get the correct kit.
Posted on Jan 06, 2013
dontbother10
  • 2220 Answers
SOURCE: Looking for an owners manual for McCulloch
McCulloch has traded hands so often lately Operator's Manuals are hard to find. You should be able to get some help here:
Normal business hours EST
All McCulloch Products
1.800.521.8559
Tell them up front it is a chainsaw, They won't be much help but if enough people inquire perhaps they will improve. Please have saw within easy reach before dialing.
Once frustrated there, go here:
Beg for manuals thread (ArboristSite) (free to join)
http://www.arboristsite.com/showthread.php?t=72322
Do a search if not already listed post an inquiry, someone always helps.
An IPL can be found here:
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/
The model number is usually on the bottom of your saw with the serial number. Precede the model number with the hyphenated number from your serial number.
HTH
Lou
Posted on Nov 07, 2009
  • 110 Answers
SOURCE: How to test magnito on McCulloch 310 chainsaw
The only way to test an ignition module on any small engine is on the machine. Simple and easy.First remove the spark plug , then remove the wire that connects the module to the kill switch, its located right next to the plug wire above the laminations. Put a spark tester in the pkug boot and ground the other end. Pull the rope and look for a spark. Its that simple. If you have a spark, check the switch and wire, if you dont,check the grounding screws that hold the module to the block for a clean contact.If you still have no good spark its time to replace the Ignition module (coil).If you dont have a spark tester, ask someone dumb enough to hold it. If they jump and cuss you out you know you have a good spark
Posted on Nov 15, 2009
dontbother10
  • 2220 Answers
SOURCE: looking for a manual for mcculloch pm 484
If the ignition and fuel supply systems are good that is correct. I was not able to find a McCulloch 484. Are you sure that is the model number?
Lou
Posted on Dec 19, 2009
SOURCE: NEED INSTRUCTION MANUAL FOR MCCULLOCH 838 AS CHAINSAW
Found it at
http://www.mcculloch.biz/int/support/owners-manuals/?query=MAC+838&types=O
Posted on Apr 16, 2010
Testimonial: "Thanks exactly what i was after,thanks again."
  • 122 Answers
SOURCE: Need a manual for a McCulloch SE2000 Chainsaw
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/McCulloch_Gas_Chain_Saws_Parts_Manuals_11_600032_71_Silver_Eagle_2014_IPL_211229_01.pdf
Posted on Feb 08, 2011
I cant keep chainsaw running but die out it a mcculloch 16 chainsaw it's the primer bulb
You will need to rebuild the carburetor the pump ball gets old and leaks diafram and such inside of carb is old and will need replacing.
Apr 06, 2017 | McCulloch Garden
Electric Chainsaw Oil
2 cycle for AIR COOLED engines.
Jun 19, 2013 | McCulloch Garden
Need manual for McCulloch super max6
The only thing I was able to find for you is a service manual. This manual is not specific for your model; it's a general service manual designed for use by mechanics for chainsaws in general. Hope this helps.
Nov 03, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Fuel ratio for mcculloch chainsaw se 2000
Every modern chainsaw use 2% of chainsaw additive oil with gas. Use oil additive for chainsaw (not for motorcycle) because of less smoke. Its carburetor has rubber membranes for pumping of gas, and always when your last work is finished, use all gas from reservoir to protect that carburetor (if you don't need chainsaw for long times).
Aug 25, 2011 | McCulloch Garden
Fuel mixture for a Mac 2-10 Chainsaw
Recommended mix (Super 2-10A) on the attachment; Please do not start this saw if the wind is blowing west or your grandchild is down wind.
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/1e87155fc8467cd988256b620016ca79?OpenDocument
Mar 16, 2010 | McCulloch Garden
McCulloch EB358A starts but acts like it is running out of gas
ok you have what sounds to me a blockage in the carb. take it off and thouroughlly clean it. check the diaframs in the carb to see if they are hard and stiff. if they are hard and stiff replace them and clean the carb really well and see if this works.
Oct 24, 2009 | Garden
Pro mac 850 super cc rateing and fuel mix
ProMac 850 is 82cc capacity motor & Fuel mix is 25:1 - especially now that we only have unleaded... best to use BP Ultra 98 octane as these saws were designed to run on Super leaded fuel. I used to own a 797 Super (123cc motor)
Terry B
Apr 03, 2009 | McCulloch Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
