Question about Cameras
Need disc for Keystone 1050 Everflash camera
I have the camera but need to get a disc for it and don't know where to buy it?
What batteries can i use in the samsung af zoom 1050
You will be looking for a 123A battery that you will most likely find at a battery store, or many an electronics store like Best Buy. Or you can google your camera model and order the battery online.
Mar 02, 2015 | Samsung AF Zoom 1050 35mm Point and Shoot...
How can I edit my video disc
I don't know if your camcorder have features to edit videos in camcorder itself, while some camcorders can. If it dosen't, you need to edit DVD videos on computer with an editor such as ArcSoft ShowBiz. And you need to check your DVD disc style at first. Some discs support rewriting so you can shoot a video, edit it, delete it, shoot a new one all on one disc. Some don't, once you finalize it, nothing can be modifyed. For those rewritable discs, ShowBiz is really a good choice, which enables you to edit disc frames, customize buttons, layers, etc. It even support blu-ray discs editing and burning.
Oct 11, 2011 | Canon DC330 DVD Camcorder
My Olympus 1050 SW looks like it might have a little water inside the camera. The lens is foggy. I didn't take it very deep the last time I was in the water with it, but I did store it in a cooler and...
You can TRY and dry out the camera, but I can pretty much guarantee you that there is corrosion inside and it will eventually fail if it hasn't done so already. The Olympus Stylus Tough cameras are not very tough or waterproof unfortunately. I have seen dozens of them with smashed LCD windows or that have leaked water.
Don't buy a waterproof camera, cause they aren't waterproof. Buy an underwater case and put your camera in that.
To try and dry out the camera, some people suggest putting it in a ziplock back with rice to pull out the moisture, it's not a bad thing to try. The fog in the lens MIGHT go away, but it will most likely leave spots or a big ring which will show up on all your pictures.
Your camera is most likely a goner, sorry to say.
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Olympus Stylus / mju 1050 SW Digital...
I've brought a usb cable to charge this camera, and it still doesn't work. I've tried everything except a new battery. I dont wanna buy a batty and that isn't the problem
Did you try a charging cradle? If you know how to use a voltage meter you can check the battery yourself or have you local camera shop or battery shop such a as batteries plus check it for you.
Dec 06, 2010 | DCS Norcent Technologies XIAS DCS-1050...
My charger stopped working for my Norcent 10.0 megapixel digital camera Model DCS 1050. where can I get another one.
I don't know where you are, but I found this Universal Charger on Amazon.com, which will charge any lithium Ion battery- and it is cheaper than a dedicated charger. I have a similar one that works well (but is a UK model).
Searching on DCS-1050, I found a battery for your camera, but no dedicated charger.
Dec 01, 2010 | Norcent Technologies Xias DCS-760 Digital...
I need a cable to enable connection from Epson lq 1050 to my computer - (DELL Inspiron-530S)
The "data" cable for a printer either is:
* USB -- a small almost-square socket, less than 1/2 inch (1 centimeter),
* parallel-port -- a very-wide connector, more than 2 inches (5 centimeters).
Some printers have *BOTH* connectors.
Determine which connector(s) you have, and buy a cable.
Often, a "Thrift Store" will have the "parallel-port" cable for a dollar.
Don't pay more than $4 for a "USB" cable.
If you're buying a USB cable, make sure that there is a "square" end -- some USB cables have a smaller "mini-USB" connector, in order to connect to a digital camera.
Nov 27, 2009 | Epson LQ-1050 Matrix Printer
I lost my battery charger for my Norcent Digital DCS-1050 camera. Where can I buy a new one?
Searched the web for a "Universal" charger that could be used for my batteryand found something that should work.
thanks,
Connie
Jun 24, 2009 | DCS Norcent Technologies XIAS DCS-1050...
Adjust shutter speed
On most indoor shots the shutter speed will normally be 1/30 if you need or want it to be faster than that the only way to do that with this camera is to set the ISO to a higher value. Page 29 of your user manual explains how to set the ISO value for the camera to allow for faster shutter speeds.
May 01, 2009 | Olympus Stylus / mju 1050 SW Digital...
Cameras Logo
76 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
