Question about Sony CLIE PEG-N760C Handheld
PEG NX70V When I try to hotsync the pda, it does not respond and appears to lockup. I have tried everything to get it to respond.
    Problem Solver:
  • 18 Answers
Are you syncing alot of medai or do you have large files on your handheld? if you do manually delete them from either a memory card or the handheld. this happens to me when i try to hotsync my palm, just unplug the hotsync cable when it seams to stop then reset your device. you could just take out your memory card too.
Posted on Jul 04, 2007
SOURCE:
After linking to my desktop and doing a two directional hotsync and installing some software including 'mobipocket' a message ' memorymgr.c,Line:3835, NULL handle' appears. A reset is suggested but the...
The solution is in the same message in which I stated the problem as I hit upon it before I sent the message. It is here for free as I discovered it ' by the hand of the Almighty'. As the pda is rebooting when doing a soft reset try to jiggle the 'on-off' switch off. If nothing happens repeat the process. At some stage the machine should switch off. Now things should be OK. I don't know why it worked for me but I hope it works for you.
Jul 18, 2009 | Sony CLIE PEG-TJ35 Handheld
My sony CLIE PEG-SJ20 is not compatible with Vista. Is there some mechanism I can install that will make it work with Vista?
I had the same problem with my clie peg-sj20 on my vista home basic based laptop. I could not hotsync after installing the original software. I've never tried to use my pda with this setup before so I was trying to find a way to make it work when I found this post, figured I would reply with what I found.
My Sony clie peg-sj20 runs the Palm o.s. 4.1 software and apparently Sony no longer supports this model. So after trying to hotsync and letting the Windows vista install wizard find the proper software, it suggested contacting the manufacturer of the operating system. I went to the Palm websight and downloaded the Palm o.s. 6.2 software which is compatible with vista, even though it doesn't say it supports the sj20. After installing it I performed a hotsync during setup when I was prompted to do so, and it totally worked. I'm not sure if this version works with other applications but it enabled me to hotsync running vista.
Hope this helps someone out there. Good luck.
Dec 13, 2008 | Sony CLIE PEG-SJ20 Handheld
Sony Clie PEG-NX70V/U
I believe that the battery door is located next to the hold button. you need to use a cross screw driver to access and pull the battery. i havent try it, but i am going to acquire a battery to replace mine.
May 12, 2008 | Sony CLIE PEG-NX70V Handheld
Vista will not recognize my Clie
Please install thePalm Desktop Operating System 6.0 or higher from any search engine or Palmzone.
This will resolve the issue.
Regards
Chris 2030
Jan 12, 2008 | Sony CLIE PEG-T615C Handheld
Sony clie peg-nx70v pega-wl100 lan card
yes, when you get it, it comes with the software.
Dec 24, 2007 | Sony CLIE PEG-NX70V Handheld
Driver Cd
Dear Sir
I need the drivers for a pda sony clie peg-nx70v/u
Thank you for your support
williamidro
Oct 27, 2007 | Sony CLIE PEG-NX70V Handheld
Stopped working
I do not have a solution for you but if you cannot get it working I can use the case to repair my NX60, I think. I hope that you can get your unit fixed but if you cannot please let me know if you want to get rid of it. See my posting: Sony CLIE PEG-NX60 Handheld Sony PDA repair NX60/U I have a Sony PEG NX60.....
May 29, 2006 | Sony CLIE PEG-NX70V Handheld
How to HotSync Clie' and Palm Zire
install it on another computer buy her a computer
Sep 19, 2005 | Sony CLIE PEG-TG50 Handheld
Open Questions:
SBCglobal MAil SuPPoRt {1^855^536^5666}#[email protected] HAWAII This SbCgLoBaL MaiLUSA phone number is ranked #2 out of 2 because 7,728 SbCgLoBaL MaiLUSA customers tried our tools and information and gave us feedback after they called. The reason customers call # I855%^536%^5666is to reach the SbCgLoBaL MaiLUSA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, SbCgLoBaL MaiLUSA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. SbCgLoBaL MaiLUSA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I855%536%5666 and ways to call or contact SbCgLoBaL MaiLUSA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling SbCgLoBaL MaiLUSA Calling SbCgLoBaL MaiLUSA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from SbCgLoBaL MaiLUSA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with SbCgLoBaL MaiLUSA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare SbCgLoBaL MaiLUSA's phone numbers against each other. Contacting SbCgLoBaL MaiLUSA in General While I855%536%5666 is SbCgLoBaL MaiLUSA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I855%536%5666 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach SbCgLoBaL MaiLUSA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact SbCgLoBaL MaiL USA.
Oct 16, 2019 | Best Computers & Internet
See all Sony CLIE PEG-N760C Handheld Questions
Sony CLIE PEG-N760C Handheld Logo
248 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
