Question about ASUS WL-330 802.11b Wireless Access Point
My asus modem will turn on but will not connect to a network. IT just stays on.
    Sergeant:
  • 366 Answers
Try this tip and specify if you can fix the issue or give detail for any further support
Posted on Jan 20, 2009
Hook up an ASUS N13U Router to a Speedstream 4100 Modem - ATT DSL
Both the modem and the router should have an ethernet cable connection. The modem probably has only one, the router may have more than one. Look for the one on the router labeled WAN or INTERNET or MODEM connection. Connect the two with a standard 8 pin RJ-45 connector cable.
Then, ordinarily, just reboot each. Turn off the router, reboot the modem, the turn on the router. It should connect automatically.
Sep 21, 2013 | ASUS RT-N13U Wireless Router - 300 Mbps 1...
Tip
Multiple Computers on Same Network, Continual Internet Connection Dropout
After adding that second or third computer to your home network are you constantly fighting over who's using the internet connection? When your high schooler logs into his facebook chat, are you getting dropped off of your internet connection?
Or have you added a wifi router and is your whole network not staying connected like it did before you added your wifi?
These are common issues and we answer these questions often at FixYa.
Here is s a tip that will get you past the internet connection being dropped by someone else on your network attempting to log into the internet or help you get that wifi up and working with out all the cut outs and drop offs.
Follow this simple procedure and you'll be amazed!
1. Turn off everything. Turn off computers, routers, modem, printers... everything that's on your LAN (local area network) or home ethernet.
2. Turn on your wireless router next. With the ethernet cable connected to your wifi router to your modem and let it cycle up to running. If you aren't running wifi, do this with your main router. Make sure your modem and everything else is still off.
3. Turn on your modem (enet cable attached to wifi router or main router) and let the modem cycle up to running.
What you've done is allowed your wifi router to be established as the "MAC" Address for your modem. Modems look for a single MAC address. Once the router has this address, the router will maintain the connection with the modem and the internet, AND will assign MAC addresses to your computers, network printers, network routers etc, while still maintaining your connection to the internet.
4. Turn on all other peripherals, computers and network printers. At this point the order of power up isn't important, because your router will be assigning separate addresses to all the computers, etc on your network.
That's it! The secret's out! Just keep this handy... remember if you have power outage, you'll need to reboot in this order again... Happy Home Networking
on Dec 02, 2009 | Computers & Internet
Asus pc Eee cant connect to the net
have you connect it with a network with your wireless? and does that connection connected succesfully?
or are you using modem? does the modem connected succesfully?
The url you try to go is valid,i've tried it
comment if you need more information
Aug 23, 2012 | ASUS Eee PC 900 PC Notebook
Wireless adapter will connect to router for a while, then connection quits. Sometimes it stays on for a while - other times not for very long. Lights on the modem stay on but connection does not return -...
Hi there, sounds like you need to sync your modem and router. First turn off the power to the modem, then to the router. After a few minutes reinstall the power to the Modem then to the Router. Restart your computer and see if you now can connect. Good Luck...
Oct 22, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
I cannot connect to the internet but network is working...
what is the wan IP in your modem?
What is your DNS configuration?
Cna you successfully run the following command from a command prompt?
nslookup google.com
Does it resolve the hostname to an ip address?
May 30, 2009 | ASUS WIRELESS ROUTER |WL-520G - RT...
Asus wl-500w and modem
your sub net mask is wrong you have to put 255.255.255.0 and make 192.168.1.1 to modem and 192.168.2.1 to router
Apr 11, 2009 | ASUS WL-500W Router (WL500W)
I am not able to properly set up my network with an ASUS Wl-500B
Both routers need to be on the same IP scheme and subnet i.e. 192.168.0.X subnet 255.255.255.0. First, unplug the Asus router. Next, make sure you have connection to the internet by hooking directly to the Apple router. Once you've established a connection to the internet plug the Asus router into the Apple router but go LAN port to LAN port.
Mar 23, 2009 | ASUS WL-500B Wireless Router
Network connection prompt error 6: handle is invalid
Hi glamredhel, Norton has removed the virus or Trojan & if you have windows system restore turned on the virus or Trojan will return once the system has re-booted. Open windows device manager & shut off system restore. Re-boot your system & re-scan your system with Norton. In your case Norton did not give you instructions on how to remove the virus. (Norton did that for you).
Once completed check windows update service for a possible update for your LAN. Asus does not have a separate LAN driver listed on Asus web site. The LAN driver is part of the chipset drivers. Remove your modem from the system & any software you installed with it. (If any). Restart your system. (If the system seems fine-good. Shut down the system & re-install your modem & any software. When completed do another windows restart. See if the modem functions (If your modem is either a cable or DSL reset it.
Shut down the system.
Located on the back of the cable modem or DSL modem you will find a tiny re-set button. Unplug the power cord from the modem. Take a pen & press the reset button for 10 seconds. Re-connect the power cord & boot the system. Check for internet connection.
The above are just a few item you should try.
Good luck glamredhel!
Post your findings.
Mike
Mar 23, 2009 | ASUS M2N-MX Motherboard
Cant connect my WL520GC wireless router
I am buying the ASUS 4G machine and have a USB router connecting to Vodaphone through the molbile network. Without installing Windows XP can I connect the wireless modem to the little computer. Cheers Nick W
May 23, 2008 | ASUS WIRELESS ROUTER |WL-520G - RT...
Exactly ASUS WL-500g, no internet connection
My advice and personal experiences with both wired and wireless connectivity, is if you wish to share files and internet connection, purchase a combined Modem/Router and not a seperate router to work along side your original modem. Your modem will send your router an ip address in turn your pc is sent one from your router and can get complicated; keep it simple! These are much easier to set up and control as one unit and if there are ever any connection problems you will know it's either a setting or a modem/router problem and not have to wonder ; is it the modem?; Router? settings? etc. As there are frequent loss of connections both internet and LAN it makes sense have one peice of equipment to maintain.
Dec 22, 2006 | ASUS WL-500g Wireless Router (WL500GDLX)
ASUS WL-330 802.11b Wireless Access Point Logo
114 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
