Question about Coby TF-TV2617 26 in. LCD TV
COBY TF-TV2617 soundbar has no sound
While setting up this tv in my dad's new office, we tried to connect his VIZIO soundbar, but there is only static coming out of the soundbar. We ran a set of R/W RCA cables from the tv's output and then into the soundbar's input. Tried both inputs for the soundbar with no difference in issue. Is there a way to turn off the tv's speakers, or change were the sound is directed to?
5 Suggested Answers
SOURCE: program code
I gave up with trying to deal with this Coby tv I had recently bought and returned it today for a Panasonic that can be easily programmed for my AT&T uverse system. However...I WAS able to learn 2 actual Coby codes that may work for others: 1091 and 1124. Believe me...I could not get either one of those codes to work for me...but good luck to someone else!!
Jerseygirl58
Posted on Jan 03, 2009
jomabug76
  • 1148 Answers
SOURCE: No Audio on tf-tv2617
what about tryin new rac jacks,,could be bad,,also in the menu see in ur internal speakers r turned on or off,,
Posted on May 17, 2009
  • 40 Answers
SOURCE: I received a 15" Coby
Couple things; You have to "program" the set to receive the analog channels your cable system is still sends out. Doubtful it will be too many. You may have to rent a set top box from them.
Posted on Dec 29, 2010
SD Tech
  • 14553 Answers
SOURCE: my coby tftv3227 tv won't turn on and has no sound plugged it in new power source and still nothing what to do?
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_27_2012_5_44_12_pm.jpg5_27_2012_5_44_31_pm.jpg
Posted on May 27, 2012
Vizio sound bar won't turn on with tv
How to Fix the Vizio Soundbar ' Chron.com
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
Soundbar Won't Turn On ... Turn the volume up on the Vizio soundbar and also ensure the soundbar isn't muted. ... For example, even if the Vizio soundbar is connected properly, if the TV is set up to output through the internal speakers only, ...
Fix A Vizio Soundbar Remote In 4 Simple Steps ' Vizio TV ...
vizhdtv.com/fix-a-vizio-soundbar-remote-in-4-simple-steps/
Aug 25, 2015 - Each model of Vizio soundbar includes its own remote. It's what is ... Use the power button on the soundbar to turn it on. Then test ... So replacing thesoundbar won't resolve the issue if you have one of the effected models .
Nov 28, 2015 | Vizio Televison & Video
Can't turn coby tv on
The power supply may have failed.
Jun 14, 2014 | Coby TF-TV2617 26 in. LCD TV
Open the case
unfortunately the coby company has gone out of business probably because they have produced an inferior product that has had many problems, many people are posting problems with these sets. it is better you just purchase a different brand of tv and leave this heartache causing product behind.
Apr 02, 2014 | Coby TF-TV2617 26 in. LCD TV
Coby 26" loses sound after a few minutes, any guess why?
Electronics can fail after they warm up. When they cool down again they start working again. The electronics need replacing, on this TV its cheaper to replace the TV.
Dec 15, 2013 | Coby TF-TV2617 26 in. LCD TV
Hi i have a coby 26" LCD TV model no TFTV 2617. How Can I get all my high definition channels. I all ready auto program it & it does not work
i have a coby 26 , I know sorry about that, but if any can help I appreciate it . turned set on today and green lite only no pic/sound/snow did have a horizontal red line for a few days prior to today.
Jul 15, 2011 | Coby TF-TV2617 26 in. LCD TV
Why do i only get 4 channels that show?
sir you need to auto search your t.v set or auto program it to get all channel you desired.
Aug 06, 2009 | Coby TF-TV2617 26 in. LCD TV
No sound with game system or dvd player hooked up
Check your audio configuration on MENU. If ok,, you have a bad RCA cable or connector.
Jul 24, 2009 | Coby TF-TV2617 26 in. LCD TV
Need code for GE or RCA remote for Coby TV TFTV2617-Coby says don't have-Thx
www.remotecodelist.com
www.tvcodes.com
www.remote-codes.com
Any of these sites should have your code. There are more sites if you google remote codes
Jul 11, 2009 | Coby TF-TV2617 26 in. LCD TV
May 17, 2009 | Coby TF-TV2617 26 in. LCD TV
Program code
Jerseygirl58
Dec 21, 2008 | Coby TF-TV2608 26 in. LCD Television
Coby TF-TV2617 26 in. LCD TV Logo
29 people viewed this question
Top Coby Televison & Video Experts
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
