Question about Gateway Tabor 3 (4000532) Motherboard
Windows XP sp2 won't install
I have made several attempts to install a new windows sp2 os on my gateway 500s but I keep getting problems with "system" not installing and through research determined I may need to update BIOS. However, after downloading update from Gateway and attempting to use floppy, I found my floppy was not pre-formatted and thus I have been unable to boot from floppy. I need some help. I am a definite novice and just don't have time for all this rigamarole.
  • 2 more comments
  • mcbarton1995 Jan 20, 2009
    I was running Windows XP Home, one of the first released. I've tried to install SP2 numerous times but it caused so many problems I would always end up doing a fresh install of my original OS. However, there are so many things now that won't run without SP2 so I ordered a new Windows XP SP2 to install. When I went to install, half way through the installation it came up with, "Fatal Error An Error has ben encountered that prevents setup from continuing Setup Failed to install product catalogs. This is a fatal error. The setup log files should contain more information. Press Ok to view setup file log.
    Error: The signature for Windows XP Home Edition setup is invalid. the error code is 80096001. A system-level error occurred while verifying trust."
    It then completed the install but would not start up. I ended up having to put the old Os back on just to get it running. I am on the internet with my laptop but not currently with that computer. Upon doing some research, I came across something that made me think maybe I need to update my BIOS before doing the install but I have not been able to successfully do that yet.
  • mcbarton1995 Jan 22, 2009
    As I stated in my previous post, I did a fresh install from scratch, that was when I received the error. I originally received SP3 but when the install failed, I requested SP2. Same problems with the "system" error and the computer won't do anything afterwards so I have to install my old xp.
  • Juanita Vega
    Juanita Vega May 11, 2010
    they are now on sp3
  • Juanita Vega
    ok first can you still get on the internet?second what windows are you using?
  • 685 Answers
If you have an install disk then you need to reinstall windows from scratch
Posted on Jan 22, 2009
Multiple OS problem[Primary corrupt]
Windows XP Professional SP2
http://www.microsoft.com/downloads/details.aspx?FamilyId=535D248D-5E10-49B5-B80C-0A0205368124&displaylang=en
The Windows XP startup disk allows computers without a bootable CD-ROM to perform a new installation of the operating system
http://windows.microsoft.com/en-US/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
if you have a copy of windows service pack there is a program that allows you add service pack 3 to it so you have a copy of xp sp3
http://www.nliteos.com/changelog.html
if you need more help with this post a reply
hope it helps
May 25, 2012 | Microsoft Windows XP Professional SP2 for...
Gateway dx4300-11 won't power on after put in
Is the Gateway DX4300 having problems while installing the drivers after sleep mode
or does it have these problems during the laptop is turned on.
Always make sure you download the right drivers for your system.
If you installed Windows Vista after you had formatted the system and now your trying
to install them you might want to go on another system and download all of the drivers either on an external hard drive or an SD card so everything can be accessible.
After you install Windows Vista or 7 make sure that the compatibility mode is selected while installing the drivers.
Most of Gateway drivers are Windows XP so you have to go and right click on each and every driver and change the compatibility mode to Windows XP SP2 that way when you let it install then Windows Update will activate to perform updates for hardware drivers and software applications. It will also get the KB updates for your computer.
This will probably fix the sleep mode and improve it too.
1. Go on Gateway's site
2. Download the DX4300-11 drivers and make sure its directly from
Gateway on a SD card or external hard drive.
3. Change the compatibility mode to Windows XP SP2
and let it run as administrator.
Each driver will then install and then you will fully use
your computer's capability.
After the drivers are installed then change your power options
as it will continue to install your drivers.
Check to make sure that your battery is fully charged and is plugged in
if it is. If not plug in for charging the battery.
If all fails then you will need to replace the motherboard.
Sep 26, 2011 | Gateway Computers & Internet
I own a gateway M280 convertible laptop designed for windows xp, tablet pc edition.I tried installing windows xp sp2 but it didnt find any hard disks installed on my system.i finally got another os called...
if your installing windows 7 it will have all the touch screen drivers and such already built in, just a matter of enabling then in your control panel
Feb 28, 2011 | Gateway M280E
Problems for sp2
MICROSOFT STOPED SUPPORTING XP SP2 YOU SHOULD UPGRADE YOUR SYSTEM AND ALL YOUR SOFTWARES WILL WORKS
DONT FORGET TO RATE
Jun 08, 2010 | Microsoft Windows XP Professional With...
Cyclic boot and reboot after installing SP2
If you have the Windows XP recovery disk you should boot into the disk and do a repair install of the Windows OS. You can also press 'F8' before or right after the Windows XP splash screen comes up and tell it to either boot into Safe Mode or "Boot with last configuration that worked". If you boot into safe mode, go to control panel and programs and uninstall the sp2 installation. Please comment back if you need further assistance. I will be providing a How-To on how to recover a system using system CDs today.
Good Luck,
NOLA Tech
Jan 27, 2010 | Computers & Internet
My problem is a my laptop is a allready vista OS download i am second OS xp sp2 installed but not install the xp sp2 why?
the problem that this kinds of laptops only it allow u to install Vista and any OS which higher than Vista like windows 7 try to download windows 7 it is better than xp and vista
Jun 07, 2009 | Microsoft Windows XP Professional
Bluetooth driver (bluetooth hands-free audio) wont install, access denied
me too have that problem, i updated me XP SP2 to SP3 and failed to install bluetooth, then i removed SP3 and re install bluetooth, it worked fine, as my comment, reinstall ur OS to windows XP SP2 and try.
May 03, 2009 | Computers & Internet
My windows cannot open exefile and I cannot install spybotsd162.
Dear johan_poliwa, ur windows installer has corrupted or have been deleted. The best possible solution is that u format ur OS.
Mar 19, 2009 | Microsoft Windows Vista Home Basic Edition
Sound not come in win xp
1st u say what type of motherboard u use......
open ur xpsp2 then install sound driver
setup ....then cancel then wait ...restart
Jan 20, 2009 | Microsoft Windows Xp Home Edition Sp2...
Gateway Tabor 3 (4000532) Motherboard Logo
738 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
