Question about D-Link AirPlus DI-524 Wireless Router
Reccomend an effective wireless modem router combo for 50m transmission
Trying to improve my data processing - have 2 desktop PCs and and a son with an Xbox 360 - have constant drop outs - esp. with son on line too currently running separate Dynalink modem and D- link wireless router (both 802.11g) - Have a slight preference for Belkin possibly N grade Thanks - iforsyth@slingshot.co.nz
  • iforsyth332 Jan 19, 2009
    Thanks - Notice you didnt mention Belkin (?)
  • iforsyth332 Jan 21, 2009
    Thanks again
  • D-Link Master
  • 6,487 Answers
Since you're having this connection problem with the router that you're using, I will advise you to get a wireless N router from this manufacturer Dlink,Linksys,Netgear the wireless N router from them will definitely solve your connection problem...
Posted on Jan 19, 2009
  • Mark Gil
    Mark Gil Jan 19, 2009
    No problem about that, yes forgot to mention Belkin they have asome good routers also that you can get...
Signal not strong enough can I boost it
The "Wireless / Advanced" configuration window contains a setting for transmit power. Be sure it is set to 100%.
Otherwise, your only options are to replace the antenna with a booster antenna, or to add a stronger wireless router as an access point to your current setup. Using a booster antenna requires the D-Link to have a removable antenna, which it may not have -- none of the documentation calls this out as a feature.
Keep in mind that if you are trying to use this router over excessive distances, boosting the router's own power will not necessarily improve your connection, because the broadcast power of the remote PCs is also a limiting factor.
Dec 02, 2010 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Hello! I have D-link DSL-321B moidem. He is working. But when I put router, D-link DI-624 I cannot see modem. What I have to do? I need to connect router how I can connect more PCs. Please...
Basically connect your modem to your router with the right cable connections.Then from the router you can customized your wireless connection name, encryption etc.Now from this router you can connect several pcs either by ethernet cable or via wireless if you can set it up.Now if you are trying to connect a few more pcs wired to the router and there is not enough space then cheapest thing is to get wireless pci card for the pcs(assuming they are desktops and not laptops).I hope I have answered your question here.
Feb 11, 2010 | Computers & Internet
I have two desk top pcs, and two cable modems. how can i connect the other pc using one of the modems without paying for another cable bill?
get a wireless router and usb dongle for the second computer. Establish a home network and connect the wireless desktop to the existing cable modem via the wireless router.
Sep 27, 2009 | Computers & Internet
Can you hook up the router without hooking to a tower
Yes the Router can be hooked to a high speed modem like DSL or Cable, that high speed connection would go from the modem to the "internet" port of the router. Now the router would need to be configured if you need wireless, and then a temporary connection to a tower or laptop would be needed.
Aug 10, 2009 | Linksys Wireless-G Broadband Router
Linksys wireless on my desktop,trying to use another computer in dining room that has a router or rooter dont know what it is, cant get online please help,the wireless rooter is connected to my main...
You do not need 2 routers to connect to the internet infact you need only 1. having 2 conflicts with pcs and causing them not to work.
From the wall you have your cable fro your internet that plugs into your modem, from the modem it plugs into the router by ethernet cable to the uplink slot and then your computers connect to the router. Most routers can connect 4 computers at once. If running them all wirelessly just reboot them and they should connect automatically. If your wiring them plug them into the back by an ethernet cable in the slots 1 for the first PC, 2 for the second so on and so on. You may have to cold boot everything at first meaning shut down all the computers, unplug the router and modem. Then Plug in the modem let it boot up, plug in the router let it boot up then the pcs.
If you need more hook ups if 4 isnt enough yo uneed a switch or access point not another router.
Let me know If this helps and if I can help further.
Joe
Apr 19, 2009 | D-Link DI 514 Wireless Router (DI-514)
Problems with Belkin Wireless G Plus MIMO Router
- Nope, it is not possible, you may need an Access Point to do it.
Mar 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Changing over from a 2wire modem with a basic phone line; running desktop with Ethernet cord, 2 laptops wireless. Can not figure out how to interface into my Linksys G 2.4 Router. Is there such a cord that...
run the telephone line from your modem into the wall jack. From the modem connect a network cable (cat5) into the back ( via the uplink port) of your linksys router . Your router can now route the IP from the modem.
Jan 26, 2009 | Linksys Wireless-G Broadband Router
Question on setting up two computers
Yes, I have pretty much the same setup at home. Wired desktop and wireless laptop. On the back of your wireless router, there should be 4 or 5 wired connections which you can use. You will only have to use the setup disk on one computer. Basically, the setup disk is for the router, not the computers, it simply guides you through the router configuration process. You can also do this manually, the manual for the router will give those instructions as well.
Apr 07, 2008 | NetGear WGR614 Wireless Router
How to use this unit as a Access Point for an existing Wireless Home Network
set the second router through the web menus to a different ip address, cant have 2 devices on the same (default) 192.168.0.1 address, try 192.168.0.2 (example only) to stop data collisions
connect by cable secondary router lan port 1 to the primary router lan port 4 (any lan port to any lan port),
drag secondary router upstairs on its cable and install it wherever you want
set two routers on different channels.
set all wep settings on both routers the same.
set all pcs to 'auto channel' select
wireless adaptors in pcs will then select strongest signal at any point and transmit thru that router
Feb 15, 2008 | D-Link AirPlus DI-614+ Wireless Router
Connections
YES> If you will install a router into your network, it will share the internet conenction among the two computers. Both wireless and wired. So the connection will be from
Modem ----> Router (wireless/wired capable)   ------> PCs (two Pcs both the desktop and the laptop
and you can also add up another PC if you want to.
Oct 13, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
D-Link AirPlus DI-524 Wireless Router Logo
113 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
