Question about iHome Clock Clock Radio for iPhone iPod (iP9BR)
Ihome ia92led screen not working
Clock not lighting up
Is there an app you can download for an alarm clock?
I dont know this phone but if its Android, ios or windows then yes loads.
Jan 28, 2014 | iHome App-Enhanced Dual Alarm Clock with...
My iHome is charging my iPod but won't do anything else. The clock face isn't working which means I have no alarm clock.
I just had this same problem, I removed the battery and my IHome now works
I hope this helps
Feb 25, 2011 | Audio Players & Recorders
My brand new ihome ip87 just stopped working. It will charge my ipod but it shows no clock and it won't turn on.
Mine is doing the same thing. So I looked it up. And it said to take out your iPod and unplug the ihome then take out the batteries from the ihome and leave it for an hour.. Then it will reset itself.. I just did it and it worked.. I also had to put in new batteries in the ihome
Jan 02, 2011 | Audio Players & Recorders
Ihome ip9 will not turn on even with power chord attached. I have tried following what the manual says and unplugging it and that has not worked either. Any help will be appreciated
you might wanna try checking that the outlet actually works. try the outlet with something you know for sure works, like a lamp or something. if it works, then try the ip9 in a different outlet.
Mar 22, 2010 | iHome Clock Clock Radio for iPhone iPod...
My iPhone 3G will not respond to iHome play/pause
Just solved exactly the same problem by powering off and on the iPhone
Jan 24, 2010 | Brookstone iHome Alarm Clock Radio Remote...
Ihome won't play ipod, even after resetting ipod
When I first got my ipod touch and my ihome I had no problems and then all of a sudden everything worked except for the ihome wouldn't play music. It charged properly and the alarm and clock worked fine just the music wouldn't play. So I assumed it was the ihome and took it back and exchanged it only to get home and have the exact same problem. So I reset my Ipod and it worked. To do it you have to hold the sleep button until the red slider appears. Slide your finger across it to turn off. Press and hold the sleep button until the apple comes on. Next I sync'ed and looke dfor an update. After all this I docked it and it worked.
Jun 30, 2008 | Audio Players & Recorders
iHome Clock Clock Radio for iPhone  iPod (iP9BR) Logo
105 people viewed this question
Top iHome Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
