Question about Sewing Machines
How do I thread Globe Lock M-23A Overlocker?
I have just tried to change the cotton spools from white to black. The stitching looks terrible. I don't know what settings the tension knobs should be on either. I have downloaded a manual, but unfortunately the quality of the scanned document is low and I am having difficulty reading it. Any help appreciated.
  • Lisa Nay Jan 05, 2013
    I have fixed the problem. The overlocker needed a new needle. Hope this helps anyone with the same problem.
  • Sewing Machines Master
  • 7,365 Answers
Thank you for sharing the information
Posted on Jan 05, 2013
5 Suggested Answers
SewTechWayne
  • 186 Answers
SOURCE: 5932 knotting every other inch
Try oiling the hook if you haven't recently.
Check you needle plate and hook for damage, they may need to be buffed or sanded smooth.
Check your upper tension discs for lint and double check your upper thread path (proper threading).
There are other things like hook timing, needle clearance or broken check spring that may be wrong but you need a technician for those things.
best of luck!
Posted on Jan 31, 2009
CA92793
  • 78 Answers
SOURCE: thread loops on back using quilt stitch
You need to put more tention into the Corners, Try puttin a tention of 10 into the Quilt. And it should work fine. 10-12 Maximum, don't go pass 12 because it will probably Rip, or Shrill up. Hope this Helped.
Thanks for Using FixYa! -CA
Posted on Jul 14, 2008
SOURCE: Brother LOCK-523N overlocker threading
Looking for the manual for the brother lock-523
Posted on May 28, 2010
  • 324 Answers
SOURCE: My machine will not stitch - keeps breaking the
Lower the tension as much as you can without ending up with a knotted string. You should be able to pull the thread by hand through the needle and have just enough tension so the bobbin does not keep spinning when you give a short, sharp tug to the thread.
Hope I helped!
Posted on Jun 08, 2011
How can I set the right tension on an overlocker globe lock m-34?
The right tension on an overlocker will vary depending on the result that you want. The standard tension for just a plain 4-thread overlock stitch would generally have all the thread tensions set at the halfway mark between the high and lower number. From that point, you may need to tighten or loosen each thread tension to get all the threads to stitch evenly.
Probably the best advice would be consult your owner's manual. It should have instructions on adjusting the tensions and what to look for.
Another suggestion would be to search YouTube for a video that shows how to adjust overlocker tension.
Nov 14, 2015 | Sewing Machines
Hi, my overlocker isn't stitching corrrectly, I have cleaned, oiled and re threaded, do you think a new needle would help?
Have you tried setting thread tension?
Maybe that's problem
The thread tension should be equal from bobbin or from spool of thread.
Hope this helps.
Mar 17, 2015 | Sewing Machines
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
Toyota Globe 877
Two things I can suggest.
First, look at this search result and see if any of the manuals refer to the machine you have:
https://www.google.com/search?num=100&safe=off&q=sewing+machine+overlock+manual+filetype%3Apdf
Second, check with your local sewing circle or quilting group. You can usually find them at the local library or via Google.
Nov 01, 2017 | Sewing Machines
Overlocker cotton onleft needle snaps
1. Try rethreading the machine
2. Is the needle inserted correctly
3. Is the needle bent
4.is the tension adjusted correctly
5.is the tension adjusted to accommodate the thickness
Of the thread being used
6.is the thread good quality thread
7.is the thread feeding off the cone or spool freely
8.is the needle size correct for the type of fabric being used
Oct 10, 2012 | Sewing Machines
My Elna 6003 Quilter's Dream has been used for quite a few years with no problems until now. Lately, when I try to stitch thin poly/cotton fabric, the thread begins to strip at the needle and will...
sounds like the top thread is under too much tension, check the threading trail from the spool to the needle for anything not threaded correctly or snagging the thread. Do you have an aerial arm to take the thread through above the thread spool, and if so, is it extended? Is the thread catching on the thread spool label or some part of the spool as its coming off, they often have a little nick to catch the loose thread end and if the thread catches in this during sewing the thread will snap. Now check the tension discs, turn to zero and clean between the discs by running the edge of a piece of waste thread through them. Now rethread, set tension to the normal number you are used to and try again.
Is your needle in the right way, flat shank to the back. Change to new needle and try again.
If thread is still breaking, I'd visit a serviceman.
Feb 28, 2011 | Elna Quilter's Dream 6003Q
What are the spool holder caps and nets for?
i have never used nets on my overlocker. I have used them to stop the thread from coming off when not on the machine. Are the spool holders like a tee ****? If so they are to hold the cone shaped thread spools.If they are like a disc, you can put them over the cotton to stop it being pulled off the stand, although i never used them on an overlocker
Sep 15, 2010 | Janome MyLock 644D
Sewing Machines Logo
310 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
