Question about Vizio M370NV 37 in. LCD TV
Vizio logo lights up but no picture/display
My TV will turn on by switch or by remote to the point of lighting the Vizio logo and the red laser/LED on the optical cable connection. However, the LED backlight for the panel does not turn on so I am not able to see anything on the screen. No sound either but can not tell if the TV is in a mode where there should be sound. Disconnecting AC power while the TV is on yields a flash from the LED backlight indicating the LEDs work and power can get to them. No visually obvious blown/leaking capacitors on the power supply board. System may have been victim of lightning strike through cable or AC. Thanks
2 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: Visio p42hd, no picture
Yes it does sound like the mainboard. But we have to confirm. I will see if there is a service manual for this unit in my collection but do you think you can safely work on it? Have you worked on electronics before? The last thing I want is you hurting yourself trying to fix it. HV circuits are not to be messed with unless you know about them.
Posted on Nov 03, 2010
How to find out what printed circuit board is causing tv picture outage? Vizio m3d550kde. Vizio logo blinks 19 times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Jun 17, 2016 | Vizio New Original M3D550KD Remote Control
Vizio m550nv amber light is on but tv will not power on
EASY HOW TO FIX LED Vizio TV- no power - YouTube
? 6:13
https://www.youtube.com/watch?v=9xZcTWr2yV0
Nov 5, 2013 - Uploaded by Tampatec
DiY How to Fix led / lcd Vizio TV service repair - no powerservice repair review guide no red blinking led ... Theorange/amber light turns on when plugged in. But the TV won'tturn on after that (the light does not turn white).
Vizio TV logo Flashing (Blinking), TV will not turn on, not ...
? 4:01
https://www.youtube.com/watch?v=MDzCzZdgbdg
Jan 5, 2012 - Uploaded by Leo P
This is model XVT3D424SV, I was watching a DVD, I switched the input to TV, tried to connect to netflix, it was ...
HOW TO FIX VIZIO TV - What causes no power - YouTube
? 5:53
https://www.youtube.com/watch?v=5k1Mc1f6O3E
Jan 17, 2016 | Vizio M550NV 55 in LCD HDTV
How to fix my vizio tv that has power but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Aug 09, 2015 | Vizio Televison & Video
My Vizio E320i-A0 tv, has barley any picture when i pug in and turn on, VERY faint logo on screen, How do I fix it?
The picture settings may have been set very low. You can reset to the factory default settings using the steps below. You may also try selecting different inputs to see if the brightness is the same on all of them.
1. From the Picture Settings menu, use the
Arrow buttons to highlight 'More' , then press OK.
2 . Use the Arrow buttons on the remote to highlight 'Reset Picture Mode', then press OK. The TV displays, "Are you sure
you want to RESET Picture Settings to the factory defaults?"
3 . Highlight Yes and press OK.
4 .Press the EXIT button on the remote.
A manual is available here:
http://cdn.vizio.com/documents/downloads/hdtv/E320iA0/UM_E320iA0.pdf
Jan 17, 2015 | Vizio E320i-A0 32 Class LED Smart TV
Sony bravia screen just stays on black and wont go to picture.
It sounds like a main board failure but could be a power supply issue as well. The set will need to be diagnosed
Oct 01, 2012 | Sony Bravia Kdl - 60Ex700 60 inch 1080P...
Hi I have a vizio tv control with the key board and it all just stopped working so I thought it was the batteries changed them still not working ????? Help Please
Test ur tv remote control first see,if it is working,malfuctions or completely dead?U have a Digital Camer wright?Yes.Digital Camera can read Infer Red signal Output by the tv remote.Yes?Turn the Digital Camera on and take the tv remote point it at the Digital camer and pushes all the remote buttons the Infer Red signal will read all buttons Infer Red signal flashes u can see on Digital Camer viewing screen.Pushes all remote buttons see flashes of white lights.Mean the tv remote control it it good or not.Take some cottons ball soak it with some rubbing alchachol clean the tv Infered Red sensor on the tv frame near the power LED incation light.Might be dirty,Still not reading the Infer Red signal.If 100% it is the tv remote control is the cause,it CPU is dead.Try website like Remotes.com to buy another the tv original remote.
Jul 29, 2011 | Vizio VO47L 47 in. LCD TV
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
Do you have innovage remote codes for Vizio VO320E
I don't see Vizio TV codes in the Innovage Jumbo Remote manual.
Here are the Code Search instructions:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. the LED light will turn off.
Oct 10, 2009 | Innovage Jumbo Remote Control
Omnitech jumbo universal remote control and vizio hdtv
Here are the instructions for auto code search from the Omnitech manual:
Automatic Search
There is another way to set up your controller, that does not use the brand code lists. You can let your
controller search through all of its available codes automatically in order to set the connection to the
target device. To do this, follow these steps:
1.Turn on the target device.
2.Point the controller at the target device and press and hold the Code Search button for around 3
seconds, until the LED light stays red.
3.Next select the type of device the target unit is by using the Cable/TV/VCR/DVD/Sat Buttons (i.e. if
it is a TV that you are trying to control, press the TV button). The LED light should then blink once,
then stay red.
4.Press the On/Off button on the controller slowly and repeatedly until the device you are trying to
connect with turns off. (Note: the LED light will blink each time you press the On/Off button). When
this happens, press the ENTER button in order to store the code and the LED light will turn off.
Jan 02, 2008 | Big Button TV Universal Remote
Vizio M370NV 37 in. LCD TV Logo
63 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
