Arris Nvg510 At&t Uverse High Speed Wireless Gateway Modem/router Logo
Posted on Jan 05, 2013
Need to connect my nvg510 brodband
Im triing to get wierless signal to my blue ray dvd
Anonymous
Level 1:
New Friend:
  • Contributor 7 Answers
  • Posted on Jan 05, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
7
Questions
0
Helped
7983
Points
21
Does your bluray player have an internal wireless system, or does it require an add-on? Need to know model of bluray player
How do I connect my blue ray DVD player to the Denon AVR-1705-685 receiver?
This will depend on the Blue ray player and other equipment. For a direct connection to the receiver, if your player has either type of digital audio output (coaxial or optical), get the appropriate cables. Then connect the chosen cable between the Blue ray player and the receiver. Connect the Blue ray player to the TV with an HDMI cable. See page 10 of the manual, available at http://pdfstream.manualsonline.com/6/69f43064-f593-49b8-8d4a-23174b496e65.pdf , to see the connections for the audio sources. (I'll assume your Blue ray player doesn't have component video out or you would use the component audio to the receiver.)
If your player doesn't have a digital audio output, check your TV audio output. You can get the same result by sending the videos via HDMI to the TV and using the TV audio out to the receiver. Set the audio source to TV and leave it there for both TV and Blue ray and DVD videos. (Sometimes there could be a slight delay in the audio compared with the video signal when you do this. I've never noticed it with my Blue ray player signal going to the TV and the TV digital audio out to the Denon receiver.)
If you can't send the audio out to the receiver from either your Blue ray player or TV, then you will need some sort of HDMI audio extractor. You can find models with Analog Audio Out, Digital Audio Out or both. ( https://www.amazon.com/J-Tech-Digital-Extractor-Converter-JTDAT5CH/dp/B00BIQER0E lists units with both types of audio output. One models requires a 3.5 mm to RCA audio adapter.)
I hope this helps.
I have a phillips hts5560 home theatre system and im getting no sound through the speakers! I have tried everything the blue ray player workz but no sound at all through speakers can anyone help?
Hi Candice, Does your blue-ray DVD player have volume control as well as your television, I have blue-ray DVD with volume control as well as the television volume control.... I have the television volume turned up full and control the volume through my blue-ray DVD.... Hope this helps... CHEERS...
1helpful
How to connect a blue ray player with the sc pt760 sound system with dvd?
According to the models you provided it looks like the DVD player has only HDMI out and the sound system you have does not directly support that. I would suggest purchasing a HDMI audio extractor so that you can covert the digital signal from your blu-ray to an analog signal. However, there are other ways of doing this. If you provide me with your TV that you use I might be able to advise another work around.
Go on google and look for "hdmi audio converter" or "hdmi audio Extractor".
Make sure to look at review to determine the quality of the product and decide what device fits your budget.
1helpful
Insignia Wifi Blue Ray DVD player connects to internet but sometimes it quits and tells me internet is too slow. What can I do to solve this issue
Must have a higher speeds internet connections for the Wifi or have wire connect directly to the internet connection for a stronger signal down load data's far ahead of the data's being for the Blu Ray player in used.
1helpful
2answers
I cannot get sound from a sony BDS350 (Blue ray
This must be configuration problem on the BD player. In this case receiver just outputs the signal it receives digitally. If it displayes PCM 2ch, that means it receives only 2 channel audio from BD player.
You can try to configure the BD player not to decode audio and to output the RAW stream over coax cable to the receiver. Then the receiver should get raw Dolby Digital encoded data and be able to decode it into 5.1 channels. It should also display Dolby D instead of PCM in such case.
2helpful
2answers
Wierless doesn't connect even when there is a signal, acts like wierless is off.dv6000
If, when you turn on the switch you should see a blue light. If it is an amber color, in the control panel, in administrative tools go to the device manager, click on network settings, and reinstall the wifi. If you still don't see a blue light, it may be your wifi card. After many years of use they seem to burn out and need to be replaced. It's located on the backside of your laptop. They don't cost much if you know where to look.
1helpful
While watching blue ray, the receiver loses the Signal
check the continuity of the AV Cables and check for any loose connection/dry solder in the connectors
2helpful
Wireless speakers not communicating to Receiver
Speakers have a unique RF frequency that needs to pair with the receiver (kind of like a blue tooth headset with a cell phone). At times, the signal may reset, so, you may have to go through the initial pairing sequence. Try this:
1. Unplug rear speakers
2. Make sure the sound signal connector is plugged in to the back of the system properly.
3. Press and hold the ID button for 3 seconds until the blue LED light flickers.
4. Connect the power chord to the rear speakers.
Top Arris Computers & Internet Experts
Jesse Walters
Jesse Walters
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
