Question about York Furnace Draft Inducer Blower Fasco # A224
York furnace trippin roll out switches - York Furnace Draft Inducer Blower Fasco # A224
    Problem Solver:
  • 7 Answers
Is your filter plugged? If so, change it out. is the bottom door on the furnace? Is the draft motor running at normal speed?
Posted on Jan 05, 2013
York furnace won't ignite
Is the igniter receiving 120 volts after the pressure switch closes? If not, either the board is bad or the pressure switch is open
Nov 27, 2012 | Heating & Cooling
Hi, I have a York furnace and I am having problems with it staying on. The warning message I get is a red light blinking 4 times, Limit switch open. What does that mean? Any suggestions?
a limit open is saying that your furnace is over heating. a few things could be wrong. dirty filters, blocked air return or closed vents. the roll out switch,if your furnace has one , is also in this loop .it normaly will be needed to reset and is on top of the roll out sheild in the burner compartment. call a repair company if this is the problem.
Feb 03, 2011 | Heating & Cooling
I have a York Gas Furnace that is 6 months old. The furnace will run for 5 hours like it should and then shuts down. I get 6 red light flashes. According to the manual the presure switch is bad. I...
These pressure switches are safety features on ALL new furnaces, if replacing the switch didn't solve the problem, you might want to make sure there is no blockage in the exhuast pipe like a birds nest, anything that would restrict airflow, is there inline fan motor in the exhaust pipe ? perhaps it's not working also.
Jan 23, 2011 | York Furnace Draft Inducer Blower Fasco #...
Had a no heat call the other day on a York GY9S080B12up11a. unit was off on code 3, pressure switch. differential switch is rated for -1.2. hooked up the manometer and was getting -1.2. still wouldn't...
Make sure there is water in the drain trap. If the drain is "WIDE OPEN" the fan can draw air from the trap and not from outside, and the pressure differential will not be enough. This happens as the trap dries out over the summer, then when you start the furnace, the condensate drain from the fan is dry.On some furnaces this trap is a square box,anyway fill that tubing till you see water running to drain.If you read your manual it should tell you to prime the trap. Position of the switch, shouldn't matter, as it is s diaphragm that the vacuum pulls on to engage the switch. You're probably close to the setting, and by just moving the switch, made it operate.
Oct 17, 2010 | York Furnace Draft Inducer Blower Fasco #...
York "high Aux or spill limit switch open"
how can I fix the spill limit switch, also how do I found it
Mar 05, 2010 | York Furnace Draft Inducer Blower Fasco #...
Gas furnace
Hi check out the pressure switch clean the air filter and check out the fan control see if this is clean
Feb 16, 2010 | York Furnace Draft Inducer Blower Fasco #...
York furnace model p2mpd12h06401f flashes 4 times for trouble code does'nt have code list inductor motor comes on but ignitor does'nt come on
Check pressure switch for inducer motor. If switch closes, check for crack in ignitor. If gas valve opens and you can hear/smell gas, the ignitor is bad probably. If pressure switch isn't closed you need to check for blocked vent/chimney/heatexchangers.
Dec 18, 2009 | York Furnace Draft Inducer Blower Fasco #...
York 92 % eff. furnace shuts down on # 3 error (pressure switch)
i have fixed almost every one of pc9 -----we have installed in our company,code three{flashes} at first new presure switches installed, same thing,york knows about this,induction motor bearings,could be bad.our local york dist, has boards,inducer, ***.motor, dual press.switch,free.as is known as the only way to fix.after all else is ruled out.one local competator called us if we wanted to join class action suit . good luck.furnaces work good at first, season or two then bam
Nov 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
INSTALLATION MANUAL FOR PV9C YORK FURNACE
I just replaced a thermostat on a york furnace model gy9s100c16up11h. During the process i connected the red and white wire and the unit came on after making the connections it will not come on even if I jump the red and white wires without the thermostat. Thanks Dan
Jun 10, 2009 | Heating & Cooling
York  Furnace Draft Inducer Blower Fasco # A224 Logo
95 people viewed this question
Top York Tools & Hardware - Others Experts
Paul Carew
Lawrence Oravetz
Are you a York Tool and Hardware - Other Expert? Answer questions, earn points and help others
