Question about Compaq Presario M2000 Notebook
CAN'T REMOVE THE BATTERY
I HAVE A PRESARIO C500 LAPTOP AND NEED TO REMOVE BATTERY
TO INSTALL MORE MEMORY. WHAT I THINK IS THE BATTERY LATCH IS POSITIONED ALMOST ENTIRELY TO THE RIGHT WITH THE COMPUTER UPSIDE DOWN. THE LATCH (IF THAT'S WHAT IT IS) ILL MOVE TO THE RIGHT ABOUT I/16 OF AN INCH AND WILL NOT MOVE TO THE LEFT AT ALL (ALTHOUGH THERE IS A SPACE OF ABOUT
1/2 AN INCH). HOW DO I RELEASE THE BATTERY, IT'S NOT COVERED IN MY OWNER'S MANUAL
  • 1 more comment
  • echeshire4 Jan 19, 2009
    HOW DO I REMOVE THE BATTERY?
    HOW DO YOU SCROLL THE LATCH DOWN? IT OVIOUSLY WILL ONLY MOVE SIDE WAYS
    PRESSING DOWN DOES NOT WORK
  • Compaq Master
  • 13,433 Answers
You need to disconnect the laptop battery from the computer and also the ac adapter so there is no power.
Then you will need to unscrew the generally 2 screws on the memory cover to get to the ram. I will have to get a service manual for your unit and confirm how its done.
Posted on Jan 19, 2009
  • Ekse Jan 19, 2009
    Are you trying to remove the 3volt battery? Don't remove that.
    1 pull lever
    2 pull the battery up
    3 remove battery.
    Sergeant:
  • 221 Answers
Http://www.videojug.com/film/how-to-replace-the-batteries-in-your-laptop
just click the link to get the video showing of how to remove the battery from a laptop.
thanks.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
It would appear that what you have been doing is correct. It is just that something is preventing the latch moving fully to the open position. If this assumption holds true then, it could be the battery itself is not seated properly. Might I suggest that instead of pressing on the latch, press on the battery to allow the latch to lock fully, then when it has done so, slide the latch to unlock. The hook/lock has not settled into its proper place (locked position) and the pressure is keeping the battery in place but all the same also keeps the latch from moving freely. In some instances, a drop of WD40 oil could also help stuck locks. It is electrically safe and therefore could be used.
Pls post back results. Good luck and thank you for using FixYa.
Posted on Jan 22, 2009
    Genius:
  • 1,269 Answers
Try to press the latches downward on each end then pull it.
    Scholar:
  • 160 Answers
Just will have to scroll the latch down wards and take the battery out.if its not coming out just pry it out with a thin knife like material.carefully.its silmple.
My m2000 battery is not working
The possible causes are as follows:
Determine if the laptop battery is defective. While less than 1 percent of batteries are defective, the possibility is still there. If the battery is new and only charges some of the way, it may just require a BIOS update to charge fully. New batteries that refuse to charge at all may be defective. Purchase a new laptop battery to replace the defective one.
Test the laptop power adapter to see if it's faulty. Run the laptop directly from the laptop power adapter and without the battery. If the laptop does not work with the adapter plugged in, the adapter is dead and you will need to replace it. The laptop battery may refuse to charge if the adapter is faulty. Charge the battery with the laptop turned off.
Insert the laptop battery into another laptop to test it. If the laptop battery charges in another laptop, the laptop's motherboard may be bad. Replacing a motherboard in a computer can be very expensive. If the cost to fix the computer is not worth the cost of replacing the motherboard, consider purchasing a new laptop.
Reinstall the battery to ensure all connectors latch properly. The latch mechanism that holds the laptop battery should click into place. If the latch does not close, remove the battery and examine the compartment for signs of damage.
5
Troubleshoot the BIOS to determine if there is a hardware problem. Turn on the laptop and immediately enter BIOS setup by holding down the "Del" and "F1" or "F2" keys, depending on the make and model of the laptop. When the BIOS screen appears, see how long it takes for the battery to charge down. If the battery does not last as long as the BIOS setup, a hardware failure may be the problem.
http://www.aurabuy.com/cheap-12-cell-battery-for-hp-compaq-presario-b3300-c300-c500-m2000-paypal.html
Mar 31, 2013 | HP Compaq Presario V2000 Notebook
Jumpers on c500 compaq presario laptop
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Mar 28, 2013 | Compaq Presario M2000 Notebook
How to clean the fan air
Regular maintenance of your Compaq Presario laptop helps to keep the machine running properly.
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
or Remove an HP Presario C500 Fan Assembly to clean it
HP Presario C500 is a laptop that, like most other laptops, requires a clean, functioning fan in order to work properly.
If your fan is too full of dust to function properly or needs to be replaced because it is no longer working, then your computer could be in danger of overheating and crashing.
Instead of having to purchase a new laptop because your C500's fan has failed, remove it and clean the fan or replace it with a new one.
Turn off your computer and unplug all the cords and cables from it, even the power cable.
Turn the laptop over and remove the battery, then remove all the screws at the bottom of the computer with a Phillips-head screwdriver.
Remove the two face plates from the bottom of the computer and you'll see the hard drive and RAM below.
The face plates will come out easily once the screws are removed.
Remove the two screws holding the hard drive in place and then lift the hard drive out.
Remove the screw found directly below the hard drive.
Turn the laptop over again and pop off the keyboard.
If all the screws at the bottom of the computer where removed, then the keyboard will come right out.
Remove all the screws underneath the keyboard and case and then lift the case enough to access the fan assembly in your HP Presario C500.
Unhook the cable coming from the fan into the motherboard and remove the screws holding the fan in place, then pop the fan out of the computer.
Hope this helps
Oct 20, 2012 | Compaq PRESARIO C500 COMPATIBLE LAPTOP LCD...
Removing bio's password
locate the cmos battery, remove it for at least 30 seconds, and reinstall it.
All bios settings should now be reset.
Feb 12, 2010 | Compaq Computers & Internet
Cmos or bios reset for compaq presario C500
To reset the BIOS you will need to remove the main battery & the CMOS battery. To find out how to remove the CMOS battery refer to a service manual if you can find one.
Oct 31, 2009 | HP Compaq Presario C500t Notebook
Broken keyboard keys on Compaq Presario C500 laptop
yes, all laptop keyboards can be replaced. do you have the manual for the laptop? it shows you have to remove it and take it apart. or you can download the manual from their website. you can buy a used keyboard from ebay. I don't think they are thay expensive.
Good luck
Apr 10, 2009 | HP Compaq Presario C500t Notebook
Compaq presario C500
if you don't have driver disc,then you can find it in driver databases
Feb 03, 2009 | Compaq Presario 700 470024-192 Notebook
Installing an audio driver for presario c500
i need more info what program are you running {os} and which audio are you installing.
Dec 08, 2007 | HP Compaq Presario C500t Notebook
Compaq Presario M2000 Notebook Logo
879 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
