Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
Drawer wont shut - Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
  • Fisher and P... Master
  • 3,247 Answers
If it is one of the two drawers that will not shut, them most likely the lid seal is locked in close position or the lid seal is damaged and pieces of it are blocking the drawer.
Try to shut the power to the dishwasher and take the power chord out from the socket. Then insert back and turn power on.
See if this makes a difference. If not the lid actuator motor or the lid seal need to be replaced. Will need a technician if you are not familiar with repairs especially the dishwashers are very sophisticated and are sensitive to how one repairs it.
Posted on Jan 05, 2013
Dd603 bottom drawer locked shut, no displays with power on. How do I get the drawer open?
The thermal fuse that cuts of power to the drawer has been tripped. This means you will need to replace the heater assembly at the base of the drawer. It is not cheap - could set you back by $350-400 to replace.
To open the drawer you need to turn the mains power off and then simply pull the drawer out with a little force. The lid seal is jammed shut because the lid seal actuator motors are locked after the power failed. Do not shut the drawer back as this will damage the lid seal. You will have to call a technician to replace the heater assembly and restore power to the drawer. Hopefully the top drawer is working ok.
Aug 01, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Both drawers keep running, wont shut off F1 appears as error message with a small wrench showing
water leak into the base, wrench means call service engineer. You can remove the bottom drawer by pushing in locking clips at side of rails after you pull the drawer out and lift it off the rails. DISCONNECT from electric supply before attempting to remove the cover of the anti flood sensor on rear LHS on floor. Dry completely and assemble in reverse order. It may be a faulty lid motor or simply stacking to high that caused the leak.
Oct 26, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
F1 error
The heater unit in the bottom drawer is blown. This causes power to shut off to the controller. The effect of this is the F1 error on the top drawer.
If you get the heater on bottom drawer fixed, that should take care of the F1 error in the top drawer.
Jul 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The disk drawer wont stay shut
Hello friend,
Your disk drawer must have some how come off track, and if it wont stay shut your next option will be to have it opened up and slide the drawer back on the rail.
Mar 06, 2010 | Microsoft Xbox 360 Console
We have a fisher Pakel dd603 2 drawer , the top draw wont close so we r trying to remove it to see what is blocking it can't figure out how to take top draw out
Hi!
There are two small clips down in the front of each drawer, one on each side. You depress these clips/tabs which are attached to the drawer slides, and then the drawer can be lifted away from the rails. You need to be very careful not to damage the hose/wire harness guide behind the drawer.
What may have happened is one of the "spring clips" on the rear of the rails has popped up when the drawer was open so the drawer will not have that "snap shut" feel you are used to when the drawer is almost all the way closed.
If you require more assistance, please ask.
Jan 29, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Upright freezer door won't stay shut
the door maybe disaligned. Look at the the door side on to see if it has dropped a little. It may just need adjusting.
Oct 24, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
42 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
