Bose media center av3-2-1 disk door won't open. Disk is stuck. How do I get to it to fix it.
  • 3 Answers
Engine is mising frome fuel ihjection systim so what i cah do?
Posted on Jan 05, 2013
  • 3 Answers
SOURCE: Won't power up. Disk stuck inside. Can i open that tray to rescue my rental?
take a small flat head and pry the door open if not the only other way is to unscrew cover and manually push tray open
Posted on May 13, 2009
  • 413 Answers
SOURCE: the disk door couldnot open
On the front of most DVD players there is a button with EJECT printed under it.
The same button is normally on remotes.
Try pressing this button.
Posted on May 04, 2009
SOURCE: Pioneer DVL v888 disk tray will not open. There is a disk in it.
There isn't a way to open it by hand without removing the cover.
As for fixing the tray, there might be a few reasons why its not working. When you press one of the eject buttons, do you hear the usual whirring of motors? If you do and the tray still does not open, then the problem may be a broken rubber belt near the front.
If you don't hear the whirring of motors, then try playing the disk. If the disk does not play either, then the disk loading mechanism is out of sync and may require manually resetting it. This is accomplished by carefully pulling the spring loaded carriage upwards or downwards until it responds to the play button. Be very careful not to touch any of the exposed electrical components and capacitors, electrical shock may occur.
Posted on Jun 03, 2009
  • 53 Answers
SOURCE: Door closed before disk was in correctly & now
Straighten a paperclip. On the face of most disk players there is a small hole. Push the paper clip into the hole, and the disk tray should release. Pull the tray out to it's full extension. Power being on or off is immaterial. Hope this help.
Read Ya,
Z
Posted on Jan 02, 2010
ekmoetweet
  • 124 Answers
SOURCE: The DVD gets stuck inside
Open up the dvd player (first unplug) by loosening screws on side and back take out disk and clean round spindle the disk is sticking too.
Posted on May 11, 2011
Have a Bose media center model AV3-2-1 that won't eject DVDs. Any ideas on how to get the current one out?
Your disc is stuck in the DVD ROM drive.It is recommended that you contact a qualified Bose service Technician who will be able to get your disk out without damaging other parts of the Media Center.
Jan 02, 2017 | Bose Audio Players & Recorders
Bose system plays disk one beautifully,but when changing to disk 2 it says reading disk and then "disk error"....difficult to remove disk...
hi,
There is some problem with the timing of the changer mechanisum of the player. As it is very complicated mechanisum you should need a good reparing experence to rectify the same.The mechanisum is not properly selecting the disk 2. Try to consult the bose autorised servicing center or any trusted electronics reparing shope near you.
ok
Sep 04, 2011 | Bose Wave music system Multi-CD Changer...
How do you get a stuck disk out of the player?
you will need to remove the cover and manually turn the gear that opens the door...this problem sounds like the belt for the door opening gears has broke and will need to be replaced...you can obtain a belt from mcmelectronics.com
May 15, 2011 | Bose & Wave& Music System
Dvd stuck in media center how can I get it out
If the tray won't open then the safest way is to take the top off the media center and then the cover off the DVD player inside.
It's more than likely the tray belt has stretched. Take the old one off, measure it and get one a couple of mm smaller.
Apr 22, 2011 | Bose 3·2·1 II System
Disk stuck in Koss c928. DVD powers up and says waiting. How do I get the disk out and how do I reset unit
There should be a small hole on the door of the disk tray. insert a paper clip in the hole to manually open the disk tray. remove the disk and see if the tray will open and close normally. If it does put another disk in and see if all is well. If not I would have a repair center look at it.
Jan 31, 2010 | Koss C928 System
The bose av321 disk door wont open
Follow these steps:
1. Turn off the unit.
2. Unplug the Acoustimass module power cord from the outlet for 60 seconds, then reconnect it. This
allows the unit to reset itself.
3. Before powering on, press and hold Eject on the media center
Mar 28, 2009 | Bose 3 2 1 GSX System
Cd Stuck
Look at the "door" or "flap" of the cd rom drive. You should see a small round hole. If you straighten out a paper clip and insert it in the hole, push in gently, that will open the door and eject the disk. Please rate this if it helped you.
Jan 17, 2009 | HP Media Center m7060n PC Desktop
DVD/CD door stuck on Bose 3 2 1
On the 321 systems turn off the power and unplug the power cord from the bass module. Wait 5 minutes and plug it back in. Then, simply hit the "stop/eject" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
Thanks to Matthew O;Neil for the the tip,...Italo
On a Lifestyle system with a tray that won't open, try this: Turn off the power to the system and unplug the power cord to the back of the media center itself. Wait 5 minutes and plug it back in. Then, simply hit the "open/close" button on the media center itself (do not turn it on first)..this should release the tray unless there is a mechanical failure inside the tray mechanism itself.
If this does not work, then call Bose when you are home with the system at 800-367-4008.
Nov 05, 2008 | Bose (321GS) System
Cd stuck for good in bose 3-2-1 (first edition)
This is an Update to my above problem:
I've managed at last to pry open - with a huge scredriver - the very sturdy black metal clasp that holds down the cd-dvd driver onto the shaft. Now I could lift it up, see the small frontal hole that manually frees the disk tray. I stuck in a pin and at last it opened!!
But... Allas....
I could see that the "captivated" disk had very deep "skid" mark on its playable side, as if sometihng was carving into it. The same carving happened to a new disk I inserted, although it played and ejected normally - only with strange machnical noises. I think that some of the plastic cogwheels that turn or eject the disk got loose. I stuck them in and now it works fine, but I lost confidence in the machine - fearing it may stuck again or ruin my disks.
Aug 20, 2008 | Bose 3·2·1 II System
Disk player door
You would need to disassemble the unit to take out both the CDs. Trying to force the disk out without opening the unit might damage it. If you are not comfortable with open it, please get someone who can actually do it for you. please revert back with the results.
Mar 22, 2007 | Bose (321GS) System
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
Electro Med Services...
