Question about Akai LCT2715 27 in. LCD Television
AKAI Rear Projection 46"TV has a blank picture with sound only
I have an Akai Rear Projection 46" TV that I have had for about 3 yrs now. Last week tried to turn it on and the green light just stayed flashing and the sound came on but no picture. It continues to do the same. When the picture would come on the light that is labeled lamp is red on the front panel, now that light does not come on the green light just continues to flash.
  • kreilly209 Jan 27, 2009
    I have the same problem - I turned on the TV and the red light keeps going on and off - no screen - prior to this happening the tv went red line or had way too much red in the screen. It seems like a lot of other people are having this problem as well - is this something that can be fixed - I don't want to buy another tv if I don't have too.
  • 3 Answers
Is it a CRT or a DLP/LCD projector? If not a CRT, a worn-out projection lamp can cause this symptom. When it is a DLP projector, a faulty Colour Wheel sensor can be the additional problem. If it is a CRT projection unit the High Voltage and deflection circuit must be examined...
Please tell me more about your unit...
Thomas
Posted on Jan 22, 2009
Power and lamp lights flashing red and timer flashing green
Hi,normally when the 3 led lights show up they indicate its time to replace the lamp.The lamp that is inside your tv normally last around 3000 hrs 1-2 yrs .Pay attention to any weird sounds which could indicate another problem.
Dec 16, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Akai 54' projection tv picture no sound
U obviously don't have all ur sund cables connected right or if ur running it through ur sound system put it on phono
Mar 05, 2009 | Akai PTH5498 54" Rear Projection...
AKAI PT5598HDI 55" PROJECTION TV HAS POWER AND SOUND, NO PICTURE
Open the back of the tv and check Fuses, sound like the high volt over loaded
Jan 11, 2009 | Akai PT5598HD 55" Rear Projection...
Akai PT50DL24 50 in DLP Rear Projection TV-NO PIC OR SOUND
check for popped or raised tops on caps in power supply. also try unplugging set for 5 minutes and resetting it. How about does your color wheel spin up? if your color wheel don't startup then your tv will also shut down. also check all fans they all should be running at turn on. if all fails i would say its your light engine.
Apr 10, 2008 | Akai PT5598HD 55" Rear Projection...
Akai 46in rear projection
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy.
Hope ya fix it!
Jan 06, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Akai 46 rear projection tv 1.5 years old
HERE WE ARE AGAIN WITH NO MODEL #................
Nov 10, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Akai LCT2715 27 in. LCD Television Logo
126 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
