Question about Whirlpool LER5636P Electric Dryer
Always in high heat
I have an old Kenmore dryer that won't provide low heat. It's always in high heat! Anty ideas?
  • thunderfur01
    thunderfur01 Aug 02, 2012
    it is a frgidare front lod and i repaced the element ant heat sensore
  • thunderfur01
    where is the house fuse on a frigidare dryer
    President:
  • 1,214 Answers
I am assuming this is an electric dryer.
1) Thermostat may have failed.
2) Element may have broken at one point and shorted to ground.
Please reply your specific model number and I can help further.
Posted on Jan 19, 2009
Kenmore whirlpool dryer won't start and has a bad burning smell
You may have an overheat sensor that is burning up. The dryer won't start because the heat would be uncontrollably high otherwise
Jan 29, 2013 | GE Profile DPSF495EW Dryer
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
I have a Kenmore Electric Dryer #76974150. It only works right the higher heat setting. Will not heat at all on the low heat settings? Any ideas?
If the dryer is running then the thermal fuse is okay.
The temperature is controlled by three parts. There is the operating thermostat which is on the blower housing and is rated at 150 degrees. This is high heat.
The operating thermostat sits in a thermostat heater which is controlled by the temperature switch. The temperature switch controls how much voltage passes it to the thermostat heater. This is how we achieve lower temperatures. There is about a 15/20 degree difference between high heat and low heat.
The restricted vent may have caused the appearance of the dryer running hot.
I would suggest you check the temperature coming out of the exhaust. It can be checked with the vent hose pulled off. Any thermostat with a range between 120 degrees and 160 can be used. With the vent removed check the temperature of the air in the exhaust. At high temperature it should cycle between 135 degrees to approximately 155 degrees. This is high heat.
If you turn the temperature switch to a lower setting such as delicate you should see a lower temperature in the exhaust. It may only be 15 degrees lower but it should show a lower temperature.
I hope this information helps to resolve this problem.
Jan 08, 2011 | Kenmore Dryers
We have the dryer stacked on top of the washer and though we have always cleaned the screen, the dryer doesn't dry very well now. it's 5 years old now.
its likley to be one of your heaters has burned out, it has two one for low heat one for high heat on low only one works,,, both work for high heat
Oct 25, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer doesnt heat
Nothing you did wrong! Probably needs a new heating element. Prices vary by model. Call Sears/Kenmore parts center nearest you. Tell 'em you need a heat element for your dryer. Be sure to provide your dryer's model number.
Unplug your appliance first before attempting repairs! Safety first and always!
Dec 19, 2008 | Kenmore Dryers
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Kenmore elite HE4 electric dryer
If this is a Kenmore Elite front loader, taking the back off isn't going to tell you much. The heating element is inside the dryer under the drum on the right hand side. More than likely you have an accumulation of lint on the heating element housing and its beginning to smolder. Running the dryer on low will not change the fact that you have lint in close proximity to a glowing element. It will still burn. Here is a link you can look at that gives you some advice on dryers:
http://www.fixya.com/support/r385301-thorough_dryer_advice
You will need to unplug the dryer and remove the lower panel under the door to gain access to the heating circuits. If you have lint backing up into the dryer, you need to investigate why. If its been a while since you've inspected your dryer ventilation ducting, it would probably be a good idea to do so. Everything is in the link I provided for you. I hope this helps.
PS Conitued running of a dryer in this condition can cause the heating circuits to overheat and fail and/or cause a fire.
Jul 12, 2008 | Kenmore Elite HE4 Electric Dryer
Low heatworks, high heat does not.
it sounds like you need a set of thermo switches. one may have stopped functioning. a service tech can test them easily. should be low cost
Jun 28, 2008 | Kenmore 64202 Electric Dryer
Dryer produces low heat but not high heat
check the vent outside it seems to be getting too hot and cycling the element off and on your safety therm.
Oct 22, 2007 | Kenmore 62802 Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
76 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
