Question about Proton MM2701VT 27" TV
SHORTED OUTPUT MAGNAVOX TV
I have a magnavox MS3252S431 tv with a shorted output.It was whining before i desoldered the output.The output and driver coil solder looked ok.Do i need to change any other component before i replace the output and turn the set on?
    Genius:
  • 1,139 Answers
Hello valexandrur,
You are in the correct section, now your problem may be a shorted Integrated High Voltage Transformer (IHVT) also called a Fly-back Transformer and or a shorted Horizontal Output Transistor (HOT). I would first check the Transistor to see if it is shorted between the emitter and collector (to do this use a multimeter set to "Rx1") and the reading between the emitter and collector should be near infinite no reading, if the reading is 000 ohms then the transistor is shorted and should be replaced. Now for the hard part, you technically can not check for shorted transformer turns in the IHVT using a multimeter, you will have to use a device which will allow you to do what is called a ring test. If you do not have this piece of equipment (IHVT tester), I would replace the IHVT just as a matter of good measure, since the HOT had drawn a lot of current I would assume that the IHVT was damaged to since it is in the serial path between the collector of the transistor and the VCC supply.
I hope this helps,
Thank you,
Shuttle83
llc
.com/">http://www.electron-age-technologies-llc.com
Posted on Jan 19, 2009
No power ticking sound when plug into outlet
Hello
Your Philips Tvs line output section has some trouble with it. All philips power supply circuits are so designed that, even a small short circuit in the ciruit board occurs, the power regulator will sense it, and the entire system will shut down, and that is happening now in your TV.
You just start with the horizontal output transistor, fitted very close to Line Output Transformer [LOT], for any short. You must desolder it out from the circuit for this check, and check it for collector to emitter leak. If this will happen, the main regulated power supply ie 120VDC, will gets shorted through this transistor, cause a dead short circuit. If it is shorted, you must find out the reason for that short.
If LOT said above has damaged, this transitor will also get shorted. In otherwords, if LOT is damaged, its driver transitor,will also will get leaky. You just replace this transitor with an identical one. Switch on the tv for a while, say 10 seconds or so, check its heat effect. If it heats up abnormally, surely LOT has damaged, and you should replace it also with an identical type and number. Ok
Nov 24, 2010 | Philips 32PT563S 32" TV
WHEN TV IS PLUGGED IN TO OUTLET, EVEN WHEN TV IS OFF, i GET A LOUD WHINING NOISE AND STILL NO PICTURE
There is a short inside the set. Most likely the horizontal output transistor has shorted. The whining is the power supply being overloaded. Lots of things can cause this.
Oct 20, 2009 | Televison & Video
Color serperation of red and green
The convergence output IC's have failed which is a common problem with all projection tv's. They need to be replaced and this is somewhat of a major job. Unless you are real handy those big amps are not easy to get to or desolder and replace. A reputable tv repair shop usually charges around $200 to $350 to do the job.
May 27, 2009 | Philips Magnavox 9P6034C 60" Rear...
My Magnavox TV is Model MS3252S431. Is it capable of receiving over-the-air digital broadcast signals? Martha B. Swart dickandmartha@bellsouth.net
Most likely not. How old is the TV? If it doesn' have a ATSC digital tuner you will have to purchase the digital to analog tuner available at most electronic stores now. Apply for a $40 voucher from the government to apply towards the purchase. Here is a link to apply for a coupon online.
https://www.dtv2009.gov/ApplyCoupon.aspx
Jun 11, 2008 | Televison & Video
Magnavox MS3252S431
Replace:
Q7461 C33725
O7463 C32725
C2455 47uF@50V
May 23, 2008 | Proton MM2701VT 27" TV
Magnavox MS3252S431
Replace:
Q7461 33725
Q7463 32725
C2455 47uF@50V
May 22, 2008 | Proton MM2701VT 27" TV
High pich whine from CT-36D32 36" TV
jdosk-the high pitch noise you hear is generally from the horizontal output being shorted,the horizontal output is usually near the flyback transformer,get a digital multimeter to checkthis part.Let me know I'll try to help. cooltek Feb.16/08
Feb 05, 2008 | Panasonic CT-36D32 36" TV
MAGNAVOX 50 INCH REAR PROJECTION Hor. Output Tran Keep Going Out
Try checking some of the tunning and coupling capacitors around the horizontal section as well for some crystalized solder joints in that area.
Jan 06, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox tv problem a green vertcal streak on rt side
Dickson do you have a speaker next to your tv anything magnet will change color it may need demagnatised
Maxol your tv more then likely has a bad picture tube or you have a shorted transistor for green output shorted on CRT board.
ThankYou for using FixYa. Have a Nice Day.
Dec 28, 2007 | Philips Magnavox 27MS343S 27" TV
Rca f27442
Check for shorted base-collector junction on horizontal output transistor designator Q14401. Also coil L14401 going to base of transistor needs to be desoldered, scrape ends, resoldered. If horizontal transistor is shorted, real possible flyback transformer bad.
Dec 16, 2006 | RCA F27442 27" TV
Proton MM2701VT 27" TV Logo
123 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
