Question about Saws
On Craftsman tablesaw/model 137.248830, was ripping some 2x4's, went to make next cut and saw wouldn't turn on. Pressed reset button, but that didn't help. Button seemed "soft". Cleaned out sawdust from box around switch and reset button. Still will not start.
  • Anonymous Mar 01, 2009
    I have the same problem. This had happened once earlier and I don't remember what I did to make it run again. It was working fine - cut once and for the next cut,it just wouldn't fire up.
  • Ron Carstens May 02, 2009
    I have the identical problem. For no apparent reason this model seems to just cut out with no solution. I have tested the power source, no problem there, have crawled around under and into the underside of the saw to check the electrical connections and see no apparent problems, have cleaned the underside of the saw where the electrical cords and switches are to no avail. This is the second table saw I've had problems with from Craftsman. Hope someone out there has a solution!
I just bought this saw used off of e-bay. Got it home check to see if it would run, It did. The next day got the saw out and nothing. By passed the breaker and the switch and it ran fine. Ended up taking the switch out and apart I found that there is a rocker inside that either rocks in one direction (off) or the other direction is (on). the on side has a contact similar to a points contact on an older vehicle. Mine had some saw dust between the contact thus no power. wiped it out and the saw was fine.
Posted on Jul 12, 2009
  • mdavis394 May 13, 2011
    That was the ticket. Worked great, thanks for your help Mike. Greatly appreciated!!!
  • wrmccall Sep 03, 2011
    Had exactly the same issue. Thanks for posting your solution which made my fix very quick! I also duct taped the box after reassembling everything in hope it won't get any more saqwdust inside.
  • 4 Answers
This just happened on mine and I took apart the switch from underneath. It snaps in by 2 plastic clips. There is a metal lever/bar that slipped to the side. I just re-seated it and was up and running again.
Posted on Jul 07, 2009
My Craftman 10-in Tablesaw (Model # 137.248830) was working but it just stopped all of a sudden. Sound like the same problem you had? Well, I took the switch out like other here suggested. I carefully pulled back the plastic snaps on the sides and opened it up and sure enough, there was all kinds of dust in it. I also saw that the contact areas were blackened a little so I used some sand paper to clean them off as well. I put everything back together and it worked. I am so happy now. If you are having similar problem that is probably what it is. At first I didn’t think any dust could get in there but it sure did. Be carful pulling the switch apart. Do loose the little copper rocker piece. It can fall out really easy. Watch out for the little black plastic rounded rod that comes out of the top of the switch as well.
Thank you for everybody that posted these suggestions. They helped me.
JV
Posted on Aug 01, 2009
  • 3 Answers
First be sure there's power at the saw. Next, if your "older model"
reset button popped, you can try jumping the terminals on the reset button and then giving a moments power to the saw. Just a moment now... the reset button exists for a reason, one of which is to prevent a fire, so don't go running the saw with the jumper in place. If the saw starts for a moment with the jumper in place, then you probably still have crud in the reset button housing. In that case, put a needlepoint attachment on your air compressor, safety glasses on your face, and really go to town on that reset button. Tap it, shake it, press the button, blow it with your needlepoint nozzle. Repeat and repeat and repeat. And when you think you're done repeat some more. I mean repeat a LOT. Sawdust gets jammed deep in the switch housing and it takes quite a while to clean it out speck by speck. Patience grasshopper! (And for your next project consider making some kind of sawdust deflector to help prevent the problem from recurring.)
Posted on Jun 19, 2009
I had the same problem and I just bypassed the fuse switch as well (I should have bypassed trying to call someone at Sears that know tools). Anyway, it worked like a charm. A powerstrip is my new off/on and I'm back to work.
Posted on Aug 04, 2009
    President:
  • 1,214 Answers
Did you check that the circuit breaker did not trip, and there is power at the plug you are using?
A long extension cord or low voltage will sometimes cause the breaker to trip.
Posted on Jan 19, 2009
2 Suggested Answers
  • 548 Answers
SOURCE: Can I use a dado blade on my craftsman tablesaw
yes you can and here is a nice online manual that is free and you can even print out if you like
http://dl.owneriq.net/e/e99c86ed-3ba5-4bb5-a567-3b4fffebfc1f.pdf
it will show you all of the saws usues and attachments including dado
Posted on Sep 25, 2009
Testimonial: "Thanks, I was pleasantly surprised with the promptness of your response. "
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
I own a 10" craftsman tablesaw (model #
Wait for the motor to cool then try again..... you may use compress air to blow across the motor to speed the process.
Jan 19, 2011 | Craftsman 10" Table Saw
Have a craftsman 10 inch table saw model #137.218250, serial #RCW3145. When we attempt to cut plywood or a 2X4 length ways, the motor dies a number of times. Most of the time the reset button will not...
sounds like the reset button needs replaced. Also when is the last time you cleaned the motor area?? When you reset the button is the motor "hot" to the touch and if so could also be a motor problem,, try the reset first
Aug 26, 2010 | Saws
Need motor for craftsman table saw model rm871
Go to midlandhardware.com.For about $4.00 more than just price ofthe motor,you get the complete saw 15amp.motor with a laser guide!The table saw has a 3yr. warranty,3 extension wings,and a sturdy stand.Shipping to your door $24.00,$198.58 total.
Jul 03, 2009 | Craftsman Saws
No power after last cut
I have seen reset buttons not work because they are full of saw dust, Take the cover off the reset button and vacuum or blow it out with compressed air, good luck, cb
May 05, 2009 | Jet 708315LSB 10" Benchtop Tablesaw with...
Table saw not turning on
yes that is a thermal fuse. wait a couple of minutes and reset it. If the blade is dull, replace it.
May 02, 2009 | Vacuums
Saw will not run
I had the same problem several months ago with a craftsman (shut down during a long rip), and the reset switch had tripped but did not actually pop out. I tested everything in the line between the power supply and the motor, and found out that the reset switch was not conducting. I was able to reset it manually before re-installing it into the saw, and it's been fine ever since. I'd test that before you start pulling the motor out, it would be a much easier fix if the switch was just sticking.
Apr 13, 2009 | Craftsman 10" Table Saw
I have a Craftsman table saw with a burned out motor. The motor model number is RM871. Where can I find one for less that the $130.00 that Sears wants for the motor. That's the price of the saw.
SOUNDS LIKE THE PROBLEM I HAD, BUT WAS JUST A SEIZED-UP BEARING. I WENT TO LOCAL ELECTRIC MOTOR REPAIR ($15.74) PARTS AND LABOR, THEY REPLACED THE BEARING, THERE ARE 2 BEARINGS ON IT, COST IS THE SAME FOR EACH. THE BEARING IS PRESSED ON, SO REPLACEABLE. HOPE THIS HELPED
Mar 27, 2009 | Craftsman 10" Table Saw
Saws Logo
5,324 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
