Question about Toshiba Computers & Internet
Toshiba turns itself off, not over heating.
2 yr old laptop that i've just reset to factory settings due to 'trojan infection?' continues to turn itself off. can occur as soon as i turn on for the day or half way through days usage. can take between 10 - 60 minutes to come back on. any ideas please. lorraine
  • Toshiba Master
  • 27,725 Answers
Check to see if there are any keys stuck/depressed. If so, use a paperclip and fit it underneath the key and gently pry the end that is stuck. Make sure the laptop is off before attempting this. Observe where the boot process ends and starts over. In most cases, this will give an indication where the problem occurs. If the laptop reboots early on in the process, for example when it is detecting the hard drive, chances are good it is a hardware issue. If the reboot occurs further along in the process, like when it is loading operating system files, there may be an issue with operating system software. Test all power and data leads that attach to your hard drive SATA the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty Make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty. even something as small as faulty fan lead can cause you problems computers need all of the data and power to travel through every working device and to have an end for a computer to be able work properly. Motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all power and data leads make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working Check your computer ram modules for secure dust free seating you might even remove the ram modules to check for dirt on modules and in the module socket and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in If your computer runs long enough scroll to bottom toolbar (bottom of screen) right click select task manager applications you will see whats running if you see anything you dont need running select end now and you might uninstall that specific program if you or computer does not require it to run and some unnecessary programs that could be running your computer over its limits causing memory dumps also under processes see what is ticking over in the background you might have a virus again if you see something you dont need to be and users you will see who is using your computer
You might need to add more computer ram if you're not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system You should always ask for a guarantee on the compatibility of the ram before making any purchase Might be getting hot check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Capacitors look like small metallic canisters and they are found in many different computer components including computer monitors, computer motherboards, video cards, power supplies and a variety of other consumer products. A bad capacitor can cause a variety of computer problems, but if you can identify the faulty capacitor you may be able to replace it and save your computer.
Capacitor
Capacitors, sometimes also called condensers, are used to store energy in an electric field. In the context of computing, capacitors are used to block the direct current being circulated around the motherboard. A typical capacitor should last up to 15 years, but some computer manufacturers use substandard capacitors resulting in shorter lifetimes. Computer Problems b> When a capacitor has gone bad on a computer you may experience a large range of problems. The computer may have trouble booting up, or it may shut down without notice after running for only a short period of time. The most common problems associated with faulty capacitors are that they cause unexpected computer crashes and general reliability issues ranging from read/write issues to distorted screen images. b> Identifying a Bad Capacitor b> To identify a bad capacitor you will need to open your computer case and locate the capacitors on your motherboard. A bad capacitor may exhibit swelling at the top or the base of the capacitor or it may sit at an awkward angle with the motherboard, so compare the various capacitors in your computer in terms of and placement. Additionally, a bad capacitor may have a funny smell or it may have a brownish residue leaking from the top or the base. b> Prevention b> Manufacturers claim that capacitors may go bad because a computer is not receiving enough power from a power supply, because of an overclocked processor or because a computer is operating in an environment with too much heat or humidity. However, some capacitors prematurely fail due to faulty work on the part of the manufacturer. If you have a bad capacitor be sure to do research as to the lifespan of other products made by your manufacturer. Identifying bad capacitors http://www.youtube.com/watch?v=ngA4k32jLGc Capacitor replacement http://www.youtube.com/watch?v=s0Pn2tEjY04 How to check a capacitor http://www.youtube.com/watch?v=U4tnHA0phcc Replacing a leaking capacitor http://www.youtube.com/watch?v=s0Pn2tEjY04 Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/
Hope this helps. Hope this helps.
Posted on Jan 05, 2013
  • lorraine pieters Jan 05, 2013
    your reply is mostly over my head as far as tech. side. did check out minor things. thank you. lorraine
detour342
  • 200 Answers
SOURCE: My 3 yr old Toshiba - A135-S2386 - Vista - has
Just a suggestion................I have seen the RAM cause these problems in many laptops try your old RAM that came with it see if the problems persist....Good Luck
Posted on Jul 23, 2010
SOURCE: My laptop turns itself of after 8 minutes - every time i turn my laptop on it lasts for about 8 ....
Maybe your computer is overheating and turning itself off, happens to mine sometimes but not as often as 8 mintues.
Posted on Jun 09, 2008
cpenzes
  • 1102 Answers
SOURCE: toshiba laptop hard reset needed
check in your my computer
see its there will say restore or recovery
can also right click my computer properties
you'll see retore in there
Posted on Jan 17, 2009
gordonbaxter
  • 46 Answers
SOURCE: Hi, I have a 1.5
Hi aiomason.
Remove the AC cord and the battery from the notebook. Re-attach battery and AC cord and power up the notebook. This will clear the Ram memory and force the operating system to "Cold Boot", in other words start the operating system loading up from the beginning instead of resuming from Ram the last time it was active. This proceedure should restore your Gateway Notebook to normal operation. Post back your results and good luck.
Posted on Jan 24, 2011
djredskyy
  • 670 Answers
SOURCE: I have ei-3103 laptop - 4 years old. A few days
It very well could be the fan is dying or not working properly, I sugguest getting a cooling pad
Posted on May 08, 2011
Testimonial: "Thanks, I'll look into it tomorrow"
Toshiba Satellite l300 1ap windows 7
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Oct 15, 2012 | Toshiba Satellite Pro L300 (L300-EZ1502)...
How to restore fujitsu n6410 to factory settings
ok its very simple, just go to this link:
http://en.kioskea.net/forum/affich-58528-reset-toshiba-laptop-to-factory-settings
hope it works, i believe i've tried this once before and it helped me so it might help you good luck : )
May 03, 2012 | Fujitsu LifeBook N6410 Notebook
Trojans
Possibly, but possibly not. I recommend downloading and running Spybot Search and Destroy which can be downloaded free here: http://www.safer-networking.org/en/index.html it's donation only, it isn't one of those sites that has you download a diagnostic and then tells you your computer is full of spyware, adware and viruses and to FIX the problem you need to pay them. It is absolutely donation only. After seeing how well it work I have chosen to make a few donations over the past year that I have been using it as an extra step to protect my computers. It has absolutely saved my PC and laptop from hidden Trojans that my F-Secure missed as well as my tech service.
Jan 17, 2012 | Toshiba Computers & Internet
I've been at this all day and still have'nt gotten my laptop to reset to a factory default setting. Can you please guide me through this process, step by step. Thankyou.
You can always restore the computer to a point when it was working fine.
For a laptop when you say factory defaults we've two things
1)Factory defaults on the Bios - as soon as u turn on the laptop we press F8 key or DEL(depends on the brand of the laptop) to get to the BIOS and you've an option to revert to the factory defaults.
It is advisable not touch the BIOS if you are not sure about this firmware
2)The operating system (lik windows xp,vista & 7) there is nothing called factory defaults for this all we've is a installation of the Operating system itself. However we can revert or restore back to last know good configuration mode.
How to start your computer by using the Last Known Good Configuration feature To start your computer by using the Last Known Good Configuration feature, follow these steps:
  1. Start your computer.
  2. When you see the "Please select the operating system to start" message, press the F8 key.
  3. When the Windows Advanced Options menu appears, use the ARROW keys to select Last Known Good Configuration (your most recent settings that worked), and then press ENTER.
  4. If you are running other operating systems on your computer, use the ARROW keys to select Microsoft Windows XP, and then press ENTER
Aug 18, 2011 | Computers & Internet
How do i reset my acer aspire to its factory settings
Hi and Welcome to Fixya!
To restore your machine back to the factory settings, just follow the simple step mentioned below. Be sure that you've backed up your personal files though before doing this because resetting your machine will wipre out any changes you have made on the machine.
For an Acer machine, just press Alt+F10 when you boot up the laptop. You will see Acer Recovery Management, select "restore system to factory default settings" then follow the on-screen instructions and you should be good to go.
Hope this helps!
Takasashi
Jul 21, 2011 | Acer Aspire One Netbook 8.9" Notebook
My Toshiba L300D laptop needs resetting to factory settings.. how do i do this?
if yr laptop still can logon, recover yr system use system recovery on yr laptop, if not use cd recovery or recovery partition on yr laptop hard disk
Feb 19, 2011 | Toshiba Satellite L300D-ST3501 Notebook
How can i make factory setting for Aspire 5610 without recovery disc and/or with recovery disc
You do not have to make factory setting, infact you can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+F10 (try both), it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
Thanks and regards,
Anil.B.R
Aug 18, 2010 | Acer Aspire 5610 Notebook
2 yr old spayed approx 60ml of windex over the
The windex may have seeped up into the screen. It should dry in a few weeks.
Oct 03, 2009 | Joy Toshiba M105 S3002 Notebook
Hi my girlfreinds samsung v25 laptop does not load up it restarts itself all the time how can i do factory setting on it please email me bck
Dear sir
her i think your problem is on operating system(OS) lavel and u need to recover yr os with recover dvd or recover disk whitch provide with yr laptop and if you need to reset factory setting you have to go on bios setup screen
1 start laptop
2 press F10 button
3 then go to last screen ad find " setup defullt opetimeze"
4 then got to save and exti button
simple.. if u need more help please contact feel free.. thianks..
Dec 15, 2008 | Samsung V25 CXTD 2000 Notebook
Restore to factory setting
If you want to completely reset it back to the original windows settings you must re-format your computer. This won't put the original programs back on it that you had before, but it will give your computer a COMPLETE reset. Meaning also that if you want to keep some data you must put it on some external drive because your hard drive will be completely overwritten.
If you want to get it back to just the factory settings, you could try to contact their customer services if they don't anything on their site to help you, although I would not recommend it. Factory settings aren't the best because they usually put stuff on your computer that you don't really want. Re-formatting is the best thing to do.
Nov 09, 2008 | Toshiba Satellite L25-S119 Notebook
Computers & Internet Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
