Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I HAVE AN EPSON RX 500 AND MY PAPER IS JAMMED
    Sergeant:
    Champion:
  • 357 Answers
Pull out the paper, if you are not sure how to do this, look in the manual for pictures.
Good Luck.
Posted on Feb 16, 2009
I get message to pull out jammed paper but I cannot find end of the paper to pull out
Try blowing the printer out with a can of compressed air. Tiny bits of paper will often get stuck in the "eye" of the optical reader that tells the printer that it has a jam. Compressed air can blow this debris loose.
Another thing to double-check is the paper tray. Remove the paper tray and inspect the place where the paper gets pulled into the printer. Sometimes you will find a sheet of paper stuck there that isn't readily apparent anywhere else.
Aug 03, 2015 | Epson PictureMate 500 InkJet Photo Printer
How to remove paper jammed in epson workforce 500 printer. i dont see the paper in scanner, back feeder and ink cartridge. what shall i do?
Unplug it and open it up until you see the paper. Don't be rough, but use the rollers to help you roll it back out carefully, If any piece is broken off, fish it out... you can't leave any bits in there.
Apr 10, 2015 | Epson WorkForce 500 Series
Epson stylus photo rx 500 bue color makes stripes
1. Get a damp paper towel.
2. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
3. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
4. Next dab the cartridge on the towel to make sure that the ink is flowing.
5. Snap the cartridges back into the printer.
Good Luck!!!!!
Sep 20, 2011 | Epson Office Equipment & Supplies
I had some paper jam in the machine, so I pulled it out. now it won't scan. It makes a lot of noise, Seems there is small amout of paper still stuck in there, How do I open it on the bottom to clear it...
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Oct 22, 2010 | Epson RX620 All-In-One InkJet Photo...
EPSON R 300 SAYIN PAPER JAM WHEN NO PAPER JAMMED
Make sure that the paper path is completely clear and clean the paper sensors with a q tip. They get very dusty!
Aug 29, 2009 | Epson Stylus Photo R300 InkJet Printer
Large spring found in back paper tray, now paper wont feed thru.
You must open case first, dismantle paper feeder, and refit it. For printer diagram, try to find at printersiam.com.
Aug 10, 2009 | Epson Stylus C86 InkJet Printer
RX 420 PRINTER WONT PRINT AS PAPER JAMMED WARNING KEEPS FLASHING
hi i hope i can help you? remove the cover from the machine and load paper as normal. and watch if the mechanics is sticking or anything that you can see give a clean with wd40clean all rollers check that you are puting in the correct amount off paper.check for loose connections.check for dirt on the switches.
May 04, 2009 | Xerox Phaser 8400 Laser Printer
Epson Workforce 500 paper out...still thinks it's jammed
Couldn't fix the problem, but the Epson people have agreed to send us a new unit when the tech supprt people couldn't provide a solution. We are to send the old one back. I'm glad this happened while the printer was still under warranty. Hope this doesn't happen to someone else, but we're pleased with Epson's reponse.
Apr 09, 2009 | Epson Office Equipment & Supplies
Epson jammed paper
Check for the compatibility of the paper you're using by visiting www.epson.com and selecting your region. Also, I might add that make sure paper is properly loaded.
Dec 24, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson RX-500 ink's full but won't print
u just have to replace the refilled cartridges.and insert new orignal cartridges.this is a very common problem in epson printers that refilled cartridges work sometimes and sometimes dont.so insert new orignal cartridges to have good printouts.
Sep 09, 2008 | Epson Stylus RX580 InkJet Photo Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
44 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
